Hi, I have met a strange problem when solving time dependent non-linear Poisson form equation with the Picard iteration. The equation includes several highly non-linear parameters. Here I use k[f(u)] to represent the parameter, where u is the unknown variable, f(u) is a function of u, and k is a function of f(u). As the Picard iteration refers to assigning a already known uk into the parameter k and get k[f(uk)] in each iteration, I’ve tried three ways to define and update the k[f(uk)]:
- define and update
fandkas Expression:
f_ex=Expression('...u.....',degree=2,u=uk)
k_ex=Expression('...f.....',degree=2,f=f_ex)
k=interpolate(k_ex,V)
while ....:
uk.assign(ux) #ux refers the solution
f_ex.u=uk
k_ex.f=f_ex
k.assign(interpolate(k_ex,V))
This method leads to satisfying stable iteration.
- define and update
fandkas:
while ....:
uk.assign(ux)
f_ex.u=uk
k_ex.f=interpolate(f_ex,V)
The only difference between this method and the method 1 is the interpolated f is used to get k_ex but not the f_ex. Howver, this leads to finally unstable iterations (nan results).
- define and update
fandkby project:
k=project(f(uk),V)
while ....:
uk.assign(ux)
k.assign(project(f(uk),V))
However, this also leads to finally unstable iterations (nan results).
Why these methods which shoud have same k but lead to different iteration results even with nan results while method 1 iterated successfully?
