Read before posting: How do I get my question answered?
Here are a few tips to help get your question answered:
  • Write your message in English.
  • Phrase the title of your post as a question and make it meaningful.
  • Check that your question hasn’t been asked before using the search functionality.
  • Post a “minimum working code example” (MWE) to illustrate the problem:
    A MWE is the simplest piece of code that reproduces or explains the problem you have.
    It must be possible to take the MWE, paste it into a file and run it, without any extra modifications. Good MWEs can be as little as 10 lines of code. If you can remove a line of code from your MWE and still show your problem, then you don’t have an MWE!
  • Do not post lengthy application code!
  • Post the full error message created by your MWE.
  • Report the version of FEniCS you are using, how you installed it (Docker, conda-forge, hashdist, manual source install etc.), and the platform.
  • Use code formatting and math typesetting where possible.
  • Did you end up solving your own query? Great! Please, do not delete the post and do not edit it to read “post deleted by the author” (or similar sentence). Instead, answer your own question, so that future users looking for a similar problem through the search functionality can find it.
The following is a list of well constructed questions adhering to the guidelines above:
  1. Getting cell dofs for vector valued function space in dolfinx
  2. Problem with 3D nedelec element
  3. What is the “default” linear solver/preconditioner?
  4. Setting Dirichlet boundary condition/constraint on 3D edges
