Dear community, I recently reinstalled the lagacy version of fenics on my cluster with conda as I messed up my conda environment with some other installations last week.
I used conda install -c conda-forge fenics for the installation. (Before doing so, I deleted my miniconda folder and reinstalled conda).
After that, I found that my fenics code no longer runs with an “dijitso failed to load existing file” error. I tried to run the demo code from fenics tutorial and got the same error:
dijitso failed to load existing file:
/home/spshu/.cache/dijitso/lib/libdijitso-dolfin_expression_c49ebd8fd6c25a3c31b612f2a1752a2c.so
error is:
/home/spshu/.cache/dijitso/lib/libdijitso-dolfin_expression_c49ebd8fd6c25a3c31b612f2a1752a2c.so: undefined symbol: _ZNK6dolfin8Variable3strEb
File "/home/spshu/miniconda3/lib/python3.9/site-packages/dolfin/jit/jit.py", line 168, in compile_class
submodule = dijitso.extract_factory_function(module, "create_" + module_name)()
File "/home/spshu/miniconda3/lib/python3.9/site-packages/dijitso/jit.py", line 47, in extract_factory_function
function = getattr(lib, name)
AttributeError: 'NoneType' object has no attribute 'create_dolfin_expression_c49ebd8fd6c25a3c31b612f2a1752a2c'
File "/home/spshu/tmp_scratch/demo.py", line 18, in <module>
u_D = Expression('1 + x[0]*x[0] + 2*x[1]*x[1]', degree=2)
File "/home/spshu/miniconda3/lib/python3.9/site-packages/dolfin/function/expression.py", line 400, in __init__
File "/home/spshu/miniconda3/lib/python3.9/site-packages/dolfin/function/jit.py", line 158, in compile_expression
File "/home/spshu/miniconda3/lib/python3.9/site-packages/dolfin/jit/jit.py", line 170, in compile_class
raise RuntimeError("Unable to compile C++ code with dijitso")
Do you have any insights on this error? How can I fix it? Thanks!
