I get the following type error when trying to define dirichletbc.
The code is a modified version of this example Setting multiple Dirichlet, Neumann, and Robin conditions
The mathematics:
Equation and problem definition
For a domain \Omega \subset \mathbb{R}^n with boundary \partial
\Omega = \Gamma_{D} \cup \Gamma_{N} \cup \Gamma_{M}, the Poisson equation with
particular boundary conditions reads:
- \Omega = [0,2] \times [0,1] (a rectangle)
- \Gamma_{D} = \{(x, 0) \subset \partial \Omega\}
- \Gamma_{M} = \{(2, y) \cup(x, 1) \subset \partial \Omega\}
- \Gamma_{N} = \{(0, y) \subset \partial \Omega\}
- h = 0.1*(u-0) = r*(u-0)
The full code:
import pyvista
from dolfinx.fem import (Constant, Function, FunctionSpace, assemble_scalar,
dirichletbc, form, locate_dofs_topological)
from dolfinx.mesh import create_unit_square, locate_entities, meshtags, create_rectangle, CellType
from ufl import (FacetNormal, Measure, SpatialCoordinate, TestFunction, TrialFunction,
div, dot, dx, grad, inner, lhs, rhs)
mesh = create_rectangle(comm=MPI.COMM_WORLD,
points=((0.0, 0.0), (2.0, 1.0)), n=(32, 16),
cell_type=CellType.triangle)
u_ex =Constant(mesh, ScalarType(1)) #dirichlet
x = SpatialCoordinate(mesh)
# Define physical parameters and boundary condtions
s = Constant(mesh, ScalarType(0))
f = Constant(mesh, ScalarType(0))
g = Constant(mesh, ScalarType(0))
kappa = Constant(mesh, ScalarType(1))
r = Constant(mesh, ScalarType(0.1))
# Define function space and standard part of variational form
V = FunctionSpace(mesh, ("CG", 1))
F = kappa * inner(grad(u), grad(v)) * dx - inner(f, v) * dx
boundaries = [(1, lambda x: np.isclose(x[1], 0)),
(2, lambda x: np.logical_or(np.isclose(x[0], 2),np.isclose(x[1], 1))),
(3, lambda x: np.isclose(x[0], 0))]
fdim = mesh.topology.dim - 1
facets = locate_entities(mesh, fdim, locator)
facet_indices.append(facets)
facet_tag = meshtags(mesh, fdim, facet_indices[sorted_facets], facet_markers[sorted_facets])
ds = Measure("ds", domain=mesh, subdomain_data=facet_tag)
# use a simple class to define bc
class BoundaryCondition():
def __init__(self, tipo, marker, values):
self._type = tipo
if tipo == "Dirichlet":
facets = facet_tag.find(marker)
dofs = locate_dofs_topological(V, fdim, facets)
self._bc = dirichletbc(value=Constant(mesh, ScalarType(1)), dofs=dofs)
elif tipo == "Neumann":
self._bc = inner(values, v) * ds(marker)
elif tipo == "Robin":
self._bc = values[0] * inner(u-values[1], v)* ds(marker)
raise TypeError("Unknown boundary condition: {0:s}".format(type))
@property
def bc(self):
return self._bc
@property
def type(self):
return self._type
# Define the Dirichlet condition
boundary_conditions = [BoundaryCondition("Dirichlet", 1, u_ex),
BoundaryCondition("Robin", 2, (r, s)),
BoundaryCondition("Neumann", 3, g)]
Thank you!
