Spatially varying BC
I tried to create define Dirichlet BC as a spatially varying vector. To do so, I defined a SpatialCoordinate and wrapped the function is ufl.as_vector.
The MWE
from dolfinx import mesh
domain = mesh.create_unit_square(MPI.COMM_WORLD, 8, 8, mesh.CellType.quadrilateral)
V = functionspace(domain, ("Lagrange", 1, (domain.geometry.dim,))) #vector function space
p0 = fem.Constant(domain, default_scalar_type(1)) #maximal deflection
delta = fem.Constant(domain, default_scalar_type(0.3)) #width
p = p0 * ufl.exp(-delta**2 * (x[0]**2))
u_D  = ufl.as_vector([0,p])
tdim = domain.topology.dim
fdim = tdim - 1
boundary_dofs = fem.locate_dofs_topological(V, fdim, boundary_facets)
bc = fem.dirichletbc(u_D, boundary_dofs)
After running this code I get the error
AttributeError: Boundary condition value must have a dtype attribute.
How should I fix this?
Thank you
Interpolate the u_D into the function space of the bc. This is for instance covered in: Diffusion of a Gaussian function โ€” FEniCSx tutorial
Thank you!
I also found this helpful
I created a function and interpolated it into the function space, but I got an error. This is a mwe
def rect( x):
    return [0,(x[0] < 0.6)* (x[0] > 0.4)]
u_D = fem.Function(V)
u_D.interpolate(rect)
def upper_boundary(x):
    return np.isclose(x[1], 1)
boundary_facets_up = mesh.locate_entities_boundary(domain, fdim, upper_boundary)
dofs_up = fem.locate_dofs_topological(V, fdim, boundary_facets_up)
bc_up = fem.dirichletbc(u_D, dofs_up, V)
and I get the following error:
TypeError Traceback (most recent call last)
/usr/local/lib/python3.10/dist-packages/dolfinx/fem/function.py in interpolate(self, u, cells, nmm_interpolation_data) 452 # u is a Function or Expression (or pointer to one) โ†’ 453 _interpolate(u, cells) 454 except TypeError:
3 frames
TypeError: interpolate(): incompatible function arguments. The following argument types are supported: 1. interpolate(self, f: ndarray[dtype=float64, writable=False, shape=(), order=โ€˜Cโ€™], cells: ndarray[dtype=int32, writable=False, shape=(), order=โ€˜Cโ€™]) โ†’ None 2. interpolate(self, f: ndarray[dtype=float64, writable=False, shape=(, ), order=โ€˜Cโ€™], cells: ndarray[dtype=int32, writable=False, shape=(), order=โ€˜Cโ€™]) โ†’ None 3. interpolate(self, u: dolfinx.cpp.fem.Function_float64, cells: ndarray[dtype=int32, writable=False, shape=(), order=โ€˜Cโ€™], nmm_interpolation_data: tuple[ndarray[dtype=int32, writable=False, shape=(), order=โ€˜Cโ€™], ndarray[dtype=int32, writable=False, shape=(), order=โ€˜Cโ€™], ndarray[dtype=float64, writable=False, shape=(), order=โ€˜Cโ€™], ndarray[dtype=int32, writable=False, shape=(), order=โ€˜Cโ€™]]) โ†’ None 4. interpolate(self, expr: dolfinx.cpp.fem.Expression_float64, cells: ndarray[dtype=int32, writable=False, order=โ€˜Cโ€™]) โ†’ None Invoked with types: dolfinx.cpp.fem.Function_float64, function, ndarray, dolfinx.fem.function.PointOwnershipData
ValueError Traceback (most recent call last)
/usr/local/lib/python3.10/dist-packages/dolfinx/fem/function.py in interpolate(self, u, cells, nmm_interpolation_data) 456 assert callable(u) 457 x = _cpp.fem.interpolation_coords(self._V.element, self._V.mesh.geometry, cells) โ†’ 458 self._cpp_object.interpolate(np.asarray(u(x), dtype=self.dtype), cells) # type: ignore 459 460 def copy(self) โ†’ Function:
ValueError: setting an array element with a sequence. The requested array has an inhomogeneous shape after 1 dimensions. The detected shape was (2,) + inhomogeneous part.
Your function rect is wrong. See dolfinx/python/demo/demo_navier-stokes.py at main ยท FEniCS/dolfinx ยท GitHub for an example on how to define it correctly.
(Hint: do not get confused by the newlines, that is a vector expression with two components, look for commas to determine where the first component ends and the second begins)
Thank you. I also found another problem: instead of
I should have written
bc_up = fem.dirichletbc(u_D, dofs_up)
(without the vector space)
