DirichletBC with mesh tags in dolfinx - weird behavior
Dear community,
While transitioning from dolfin to dolfinx, I’m trying to solve a simple 3D quasi-static nonlinear elasticity problem of a cube being fixed on one end and loaded on the other.
For testing, I just try to reproduce a zero solution by fixing all DOFs on one end to zero and doing nothing else.
I read my surface mesh with
    with XDMFFile(comm,'path/input_boundary.xdmf','r',encoding=encoding) as infile:
        mt_s = infile.read_meshtags(mesh, "Grid_surf")
The problem: Setting a Dirichlet BC on Face 1 like
dbc = DirichletBC(zero, locate_dofs_topological(V_u, 2, mt_s.indices[mt_s.values == 1]))
with
zero = Function(V_u)
zero.vector.set(0.0)
yields an exploding solution! My Newton scheme output is
Predictor (disp 2-norm 0.0000e+00) yields residual 2-norm:
      6.4099e-16
iter  struct res 2-norm  struct incr 2-norm
1     2.4222e-13         3.7008e-16
### TIME STEP 1 / 10 successfully completed, TIME: 0.1000
Predictor (disp 2-norm 3.7008e-16) yields residual 2-norm:
      2.4222e-13
1     9.9914e-11         1.8821e-13
### TIME STEP 2 / 10 successfully completed, TIME: 0.2000
Predictor (disp 2-norm 1.8784e-13) yields residual 2-norm:
      9.9914e-11
1     4.0749e-08         7.7227e-11
2     1.6678e-05         3.1718e-08
3     6.8392e-03         1.3034e-05
4     2.8155e+00         5.3572e-03
5     3.9269e+02         2.2093e+00
6     1.4504e+14         3.6851e+02
7     nan         1.1696e+14
8     nan         0.0000e+00
9     nan         0.0000e+00
10     nan         0.0000e+00
Important: Eliminating the DBC produces the intended behavior: nothing happens and the res is always zero to machine precision.
I have tried a lot already and have the feeling that there may be a problem in locate_dofs_topological or my specific DBC syntax.
Since my Newton scheme is well tested with dolfin I’m pretty sure that the problem does not lie within the nonlinear solver loop. The only thing I had to change was the assemble. Now, in dolfinx I’m calling
K = assemble_matrix(Jac, dbcs)
K.assemble()
r = assemble_vector(-Res)
compared to the dolfin version
K, r = assemble_system(Jac, -Res, dbcs)
(The DBC from above is appended to the array dbcs.)
For reproducibility, I will add my xdmf domain and boundary file.
This is the domain file:
<Xdmf Version="3.0">
  <Domain>
    <Grid Name="Grid">
      <Geometry GeometryType="XYZ">
        <DataItem DataType="Float" Dimensions="14 3" Format="XML" Precision="8">
          0.0 0.0 1.0
          0.0 0.0 0.0
          0.0 1.0 1.0
          0.0 1.0 0.0
          1.0 0.0 1.0
          1.0 0.0 0.0
          1.0 1.0 1.0
          1.0 1.0 0.0
          0.0 0.5 0.5
          1.0 0.5 0.5
          0.5 0.0 0.5
          0.5 1.0 0.5
          0.5 0.5 0.0
          0.5 0.5 1.0
        </DataItem>
      </Geometry>
      <Topology NodesPerElement="4" NumberOfElements="24" TopologyType="tetrahedron">
        <DataItem DataType="Int" Dimensions="24 4" Format="XML" Precision="4">
          9 11 10 12
          8 13 11 10
          11 10 13 9
          8 10 11 12
          1 0 8 10
          0 2 8 13
          10 0 13 4
          3 11 8 2
          1 8 3 12
          11 13 2 6
          4 13 9 6
          6 11 9 7
          10 4 9 5
          11 7 3 12
          12 9 7 5
          12 1 10 5
          13 8 0 10
          8 2 11 13
          10 8 1 12
          11 3 8 12
          7 11 9 12
          13 9 10 4
          11 9 13 6
          12 10 9 5
        </DataItem>
      </Topology>
    </Grid>
  </Domain>
</Xdmf>
This is the BC file with the mesh tags:
  <Domain>
    <Grid Name="Grid_surf">
      <Topology NodesPerElement="3" NumberOfElements="24" TopologyType="triangle">
        <DataItem DataType="Int" Dimensions="24 3" Format="XML" Precision="4">
          1 0 8
          0 2 8
          3 1 8
          2 3 8
          0 1 10
          4 0 10
          1 5 10
          5 4 10
          1 3 12
          5 1 12
          3 7 12
          7 5 12
          5 9 4
          4 9 6
          7 9 5
          6 9 7
          2 11 3
          6 11 2
          3 11 7
          7 11 6
          0 13 2
          4 13 0
          2 13 6
          6 13 4
        </DataItem>
      </Topology>
      <Attribute AttributeType="Scalar" Center="Face" Name="boundaries_surf">
        <DataItem DataType="Int" Dimensions="24" Format="XML" Precision="4">
          1
          1
          1
          1
          2
          2
          2
          2
          3
          3
          3
          3
          4
          4
          4
          4
          5
          5
          5
          5
          6
          6
          6
          6
        </DataItem>
      </Attribute>
    </Grid>
    <Grid Name="Grid_edge">
      <Topology NodesPerElement="2" NumberOfElements="2" TopologyType="Polyline">
        <DataItem DataType="Int" Dimensions="2 2" Format="XML" Precision="4">
          1 3
          1 0
        </DataItem>
      </Topology>
      <Attribute AttributeType="Scalar" Center="Edge" Name="boundaries_edge">
        <DataItem DataType="Int" Dimensions="2" Format="XML" Precision="4">
          1
          2
        </DataItem>
      </Attribute>
    </Grid>
    <Grid Name="Grid_point">
      <Topology NodesPerElement="1" NumberOfElements="1" TopologyType="Polyvertex">
        <DataItem DataType="Int" Dimensions="1 1" Format="XML" Precision="4">
          1
        </DataItem>
      </Topology>
      <Attribute AttributeType="Scalar" Center="Node" Name="boundaries_point">
        <DataItem DataType="Int" Dimensions="1" Format="XML" Precision="4">
          1
        </DataItem>
      </Attribute>
    </Grid>
  </Domain>
</Xdmf>
Hope someone has an idea what’s going wrong with the DBC application.
Bw,
Marc
Dear @marchirschvogel,
Next time, please supply a minimal working example (MWE), as with these few snippets, one had extra code to get your example to run.
To debug your Dirichlet condition, consider the following code:
import dolfinx.io
import dolfinx.fem
encoding = dolfinx.io.XDMFFile.Encoding.ASCII
comm = MPI.COMM_WORLD
with dolfinx.io.XDMFFile(comm,'mesh.xdmf','r',encoding=encoding) as infile:
        mesh = infile.read_mesh("Grid")
with dolfinx.io.XDMFFile(comm,'input_boundary.xdmf','r',encoding=encoding) as infile:
V = dolfinx.VectorFunctionSpace(mesh, ("CG",1))
uh = dolfinx.Function(V)
uh.vector.set(1.0)
dbc = dolfinx.DirichletBC(uh, dolfinx.fem.locate_dofs_topological(V, 2, mt_s.indices[mt_s.values == 1]))
u2 = dolfinx.Function(V)
dolfinx.fem.set_bc(u2.vector, [dbc])
outfile = dolfinx.io.XDMFFile(comm, "u2.xdmf", "w")
outfile.write_mesh(mesh)
outfile.write_function(u2)
outfile.close()
Here I set all vectorial values at your boundary to 1, therefore a vector with magnitude \sqrt{3}. This can be confirmed by visualizing the output function in for example Paraview.
Thanks a lot for your reply and providing this example! I will provide a minimal working snippet the next time!
This was indeed the line I was missing! It obviously has to be set within the Newton loop after the solution update.
I wasn’t aware of this, since I thought the DBC was already properly incorporated into the system by the assemble_matrix routine.
Best wishes and I really appreciate your help!
Marc
