Dirichlet BC in DOLFINX
I would like anyone to verify my implementation. I am currently performing a multi-physical analysis where am supposed to consider mixed element space. I want to apply for Dirichlet bc as shown below. I find that my results are wrong and I doubt the implementation of Dirichlet bc of the mixed element space. Can anyone help me to verify it? I want to apply component-wise and scalar values ad Dirichlet BC.
import dolfinx.fem as fem
from ufl import (Form, SpatialCoordinate, VectorElement, FiniteElement, TensorElement, MixedElement,as_tensor,as_vector,dot,TestFunctions, TrialFunctions,dx, ds, grad, FacetNormal,inner, max_value,nabla_grad, nabla_div, Identity)
rom ufl import (Circumradius, FacetNormal, SpatialCoordinate, TrialFunction,
                 TestFunction, div, ds, grad, inner,dot, nabla_grad, nabla_div,Identity,dot, dx)
from dolfinx.mesh import CellType, create_box, locate_entities_boundary
from dolfinx.mesh import MeshTags, locate_entities
from dolfinx.fem import (Constant, dirichletbc, Function, LinearProblem, FunctionSpace, VectorFunctionSpace,
                         locate_dofs_topological,assemble_scalar)
L, B, H = 1,1,1
mesh = dolfinx.mesh.create_box(MPI.COMM_WORLD, [np.array([0,0,0]), np.array([L, B, H])], [1,1,1], cell_type=CellType.hexahedron)
U = VectorElement("CG", mesh.ufl_cell(), 1) # displacement vector element
V = FiniteElement("CG", mesh.ufl_cell(), 1) # voltage finite element
U1, V1 = FunctionSpace(mesh, U), FunctionSpace(mesh, V)
W = FunctionSpace(mesh, MixedElement([U, V]))
#Displacement Dirichlet BC
def clamped_boundary(x):
    return np.isclose(x[0], 0)
fdim = mesh.topology.dim - 1
boundary_facets = locate_entities_boundary(mesh, fdim, clamped_boundary)
u_D = np.array([0,0,1e-3], dtype=ScalarType)
bc1 = dirichletbc(u_D, locate_dofs_topological((W.sub(0)), fdim, boundary_facets), W.sub(0))
# Voltage Dirichlet BC
def Ground(x):
    return np.isclose(x[1], 0)
v_D = Function(V1)
ground_facets = locate_entities_boundary(mesh, fdim, Ground)
with v_D.vector.localForm() as loc:
     loc.set(1)
bc2 = dirichletbc(v_D, locate_dofs_topological((W.sub(1),V1), fdim, ground_facets), W.sub(1))
bcs =[bc1,bc2]
Issue submitted at:
As a workaround for now, you can use:
def f(x):
    vals = np.zeros(x.shape)
    vals[2] = 1e-3
    return vals
u_D = Function(U1)
u_D.interpolate(f)
    (W.sub(0), U1), fdim, boundary_facets), W.sub(0))
Does dirichilet bc syntax has removed FunctionSpace?
dolfinx.fem.dirichiletbc(u_D, locate_dofs_topological(
    (W.sub(0), U1), fdim, boundary_facets))
Because, when I put function space W.sub(0), it is giving error.
Q: Does dirichiletbc doesn’t require Function space in 3rd argument, considering (Function (1st arg) and (boundary_dofs in 2nd arg) ?
Can you share the original working syntax up to dat for dirichiletbc in dolfinx?
Please provide a minimal reproducible example of your error, and information about how you installed dolfinx and what version you are using.
