Discretization scheme for cross derivative with time
Hi everyone,
I am modeling a PDE where the cross derivative with respect to time is involved. Specifically, the term of interest is of the form
\nabla\left(\frac{\partial Y}{\partial t}\right)
where Y is the variable to be solved. Currently, I approximate the term as
\nabla\left(\frac{\partial Y}{\partial t}\right)=\frac{\partial \nabla Y}{\partial t}\approx\frac{\nabla Y^{n+1}-\nabla Y^n}{\Delta t}
and it works, but the solution accuracy is not satisfactory. I am looking for a better discretization scheme for this type of cross derivative. Any help is greatly appreciated. Thanks.
Could you perform integration by parts, to get the derivative on the testfunction? You’d get some dYdt boundary conditions, or some interesting Robin-type weak conditions. Maybe you can somehow leverage those?
Thanks for the suggestion, but this term appears in my weak form as
\nabla v\cdot \nabla \left(\frac{\partial Y}{\partial t}\right)
and performing integration by parts will gives terms with \nabla^2v, more complicated than before.
For now I manage to increase the accuracy to match analytical results by using a Crank-Nicolson method.
