Hi everyone,
I am very new to Fenics and I am currently trying to model the heating of a metal block in 2D via a laser including conduction and convection in order to find a steady state temperature solution for the whole block. As a result, my resultant weak form equation looks like:
F = T*v*dx + dot(grad(T), grad(v))*dx*dt + dt*(1/kappa)*Q*v*ds(3) + (1/kappa)*sum(integrals_R)-T_n*v*dx
where integrals_R is defined via:
boundary_conditions = {0: {'Robin': (es, T_a4)},
1: {'Robin': (es, T_a4)},
2: {'Robin': (es, T_a4)},
3: {'Robin': (es, T_a4)}}
ds = Measure('ds', domain=mesh, subdomain_data = boundary_markers)
integrals_R = []
T = TrialFunction(V)
T_ = Function(V)
T_n = interpolate(T_am, V)
#Account for Radiation
for i in boundary_conditions:
if 'Robin' in boundary_conditions[i]:
integrals_R.append(es*dt*(T**4 - T_a4)*v*ds(i))
This dictionary section may not be necessary I was originally using this for Robin boundary conditions, which is not what I have here. The first issue I have is with the multiplication of ds(i) and dt which gives me an error:
File "test2D.py", line 110, in <module>
TypeError: unsupported operand type(s) for *: 'Form' and 'float'
I am unsure of how I can rectify this error.
In addition, I am aware that I need to solve this problem in a Non-linear solver, but I am unsure of how to do this. I have written some code down but I am unsure if this is on the right lines or not.
my full code follows:
rom __future__ import print_function
import math
time = 100.0 # final time
num_steps = 100 # number of time steps
dt = time / num_steps # time step size
#build rectangular mesh to model 2D slice
nx = 32
ny = 16
x0 = 0
y0 = 0
x1 = 4
y1 = 2
pi = 3.141592653589793
T_am = Constant("300")
T_a4 = T_am**4
epsilon = 1 # material emissivity
sigma = 5.67E-8 # W/(m2.K4)
es = epsilon*sigma
Q = Expression('2*A*t*Pmax/(pi*w*w)*exp(-2*pow(x[0]-2, 2)/(w*w))',degree=2, A=1, Pmax=200,w=1,x0=0, y0=0,t=0)
#----------THERMAL--PROPERTIES----------
kappa = 94 #conductivity [W/m K]
c = 0.444 #Specific Heat Capacity [J/gK]
rho = 7 #Density [g/cm^3]
sw = Point (x0, y0)
ne = Point (x1,y1)
mesh = RectangleMesh(sw, ne, nx, ny, diagonal= "right")
V = FunctionSpace(mesh, 'P', 2)
#-----BOUNDARY-CONDITIONS--------------------------
#-----Define Markers for the different parts of the boundary-------
boundary_markers = MeshFunction("size_t", mesh, mesh.topology().dim()-1)
tol = 1E-14
class BoundaryX0(SubDomain):
tol = 1E-14
return on_boundary and near(x[0], x0, tol)
bx0 = BoundaryX0()
bx0.mark(boundary_markers, 0)
class BoundaryX1(SubDomain):
tol = 1E-14
return on_boundary and near(x[0], x1, tol)
bx1 = BoundaryX1()
bx1.mark(boundary_markers, 1)
class BoundaryY0(SubDomain):
tol = 1E-14
return on_boundary and near(x[1], y0, tol)
by0 = BoundaryY0()
by0.mark(boundary_markers, 2)
class BoundaryY1(SubDomain):
tol = 1E-14
return on_boundary and near(x[1], y1, tol)
by1 = BoundaryY1()
by1.mark(boundary_markers, 3)
# For the implimentation of these boundary conditions to be general, we can let the user specify what kind of boundary condition that applies to each of the four boundaries. We set up a Python dictionary for this purpose.
#ENCODE BOUNDARY CONDITIONS (MAY NEED ALTERING OR REMOVAL)
integrals_R = []
T_ = Function(V)
T_ = Function(V)
F = action(F,T_)
J = derivative(F, T_, T)
t = dt
while t <= time:
print 'time =', t
problem = NonlinearVariationalProblem(F, T_, J)
solver.solve()
T_n.assign(T_)
Any suggestions would be most welcome. Thank you in advance!
