Divegence problem in nonlinear solver
Hello everybody,
I am trying to solve a strongly coupled, nonlinear problem (6 PDEs) with monolithic time discretization. I encountered a convergence problem as below:
*** Error: Unable to solve nonlinear system with NewtonSolver.
*** Reason: Newton solver did not converge because maximum number of iterations reached.
*** Where: This error was encountered inside NewtonSolver.cpp.
*** Process: 0
so I tried to reduce my problem but the same error existed. So I tried it on a linear problem that I have already solved. However, the nonlinear iterative solver still doesn’t converge.
According to https://fenicsproject.discourse.group/t/default-absolute-tolerance-and-relative-tolerance/3829/3 the newton solver should converge in one iteration for linear problems.
I am sharing my code here. It is a bit long but it is the smallest one that I can share here.
I appreciate any help and hint to solve the problem. My original problem is nonlinear and way complicated than this one
This is the linear version which works well
import fenics as fe
import logging
# geometry
b1 = 1 # width of the domain (m)
h1 = 7 # height of the domain (m)
N_POINTS_X_AXIS = 5
N_POINTS_Y_AXIS = 29
# Initial condition and time increment
t_0 = 0.0
delta_t = 1e-3
t_final = 1
n_t = int(t_final/delta_t) #1000
# parameters
# Density
rho = fe.Constant(0.0)
# Lame parameters
LAME_MU =  5.0e6
LAME_LAMBDA = 8.0e6
DENSITY = 0.0 # b
ACCELERATION_DUE_TO_GRAVITY = 0.016
K_s = 1.0e-5 # intrinsic permeability (m2)
MU_FR = 1.0 # effective dynamic fluid viscosity [Ns/m2]
mesh = fe.RectangleMesh(fe.Point(0,0), fe.Point(b1,h1), N_POINTS_X_AXIS, N_POINTS_Y_AXIS)
u_vector_element = fe.VectorElement("CG", mesh.ufl_cell(), 2)
p_scalar_element = fe.FiniteElement("CG", mesh.ufl_cell(), 1)
mixed_function_space = fe.FunctionSpace(mesh, u_vector_element * p_scalar_element)
'''u_p_init = Expression(('0', '0', 'p_0'), p_0=0, degree=1)  # degree=1
u_p_trial = interpolate(u_p_init, mixed_function_space)
u_p_old.assign(u_solution)'''
u_p_test = fe.TestFunction(mixed_function_space)
(u_test, p_test) = fe.split(u_p_test)
u_p_trial = fe.TrialFunction(mixed_function_space)
(u_trial, p_trial) = fe.split(u_p_trial)
u_p   = fe.Function(mixed_function_space)
u0_p0  = fe.Function(mixed_function_space)
# initialization
u_p_init = fe.Expression(('0', '0', 'p_0'), p_0=0, degree=1)  # degree=1
u_p = fe.interpolate(u_p_init, mixed_function_space)
u0_p0.assign(u_p)
u, p = fe.split(u_p)
u0, p0 = fe.split(u0_p0)
# Boundary functions
tol = 1e-14
# Top boundary
def Top_boundary(x, on_boundary):
    return (on_boundary and fe.near(x[1], h1, tol))
# Bottom boundary
def Bottom_boundary(x, on_boundary):
    return (on_boundary and fe.near(x[1], 0.0, tol))
# Left boundary
def Left_boundary(x, on_boundary):
    return (on_boundary and fe.near(x[0], 0.0, tol))
# Right boundary
def Right_boundary(x, on_boundary):
    return (on_boundary and fe.near(x[0], b1, tol))
boundary_subdomains = fe.MeshFunction("size_t", mesh, mesh.topology().dim() - 1)
boundary_subdomains.set_all(0)
force_boundary = fe.AutoSubDomain(Top_boundary)
force_boundary.mark(boundary_subdomains, 3)
# Define measure for boundary condition integral
dss = fe.ds(subdomain_data=boundary_subdomains)
bc_u_bottom = fe.DirichletBC(mixed_function_space.sub(0).sub(1), fe.Constant(0.0), Bottom_boundary)
bc_u_left = fe.DirichletBC(mixed_function_space.sub(0).sub(0), fe.Constant(0.0), Left_boundary)
bc_u_right = fe.DirichletBC(mixed_function_space.sub(0).sub(0), fe.Constant(0.0), Right_boundary)
bc_p_top = fe.DirichletBC(mixed_function_space.sub(1), fe.Constant(0.0), Top_boundary)
bc_vector = [bc_u_bottom, bc_u_left, bc_u_right, bc_p_top]
# Neumann boundary condition (loading)
g = fe.Expression(('0.0*x[0]' ,'-5e6'), element = mixed_function_space.sub(0).ufl_element())
# define strain and stress
        engineering_strain = 0.5 * (fe.nabla_grad(u) + fe.nabla_grad(u).T)
        return engineering_strain
def sigma(u, p):
        cauchy_stress = (
            LAME_LAMBDA * fe.tr(epsilon(u)) * fe.Identity(2)
            2 * LAME_MU * epsilon(u)
            p * fe.Identity(2)
        return cauchy_stress
# Weak forms
from ufl.operators import nabla_grad , nabla_div
weak_form_momentum_balance = (fe.inner(sigma(u_trial, p_trial), nabla_grad(u_test)) * fe.dx -
                      fe.dot(g, u_test) * dss(3))
weak_form_volume_balance = (nabla_div((u_trial - u0)/delta_t) * p_test * fe.dx +
                            K_s / MU_FR * fe.dot(nabla_grad(p_trial), nabla_grad(p_test)) * fe.dx)
weak_form = weak_form_momentum_balance + weak_form_volume_balance
# We have a linear PDE that is separable into a lhs and rhs
weak_form_lhs = fe.lhs(weak_form)
weak_form_rhs = fe.rhs(weak_form)
# Save results in a XDMF file
results = fe.XDMFFile("My_results.xdmf")
results.parameters["flush_output"] = True
results.parameters["functions_share_mesh"] = True
# Solve for each point in time
time_current = t_0
for i in range(int(n_t)):
    time_current += delta_t
    # Finite Element Assembly, BC imprint & solving the linear system
    fe.solve(
        weak_form_lhs == weak_form_rhs,
        u_p,
        bc_vector)
    'ME'
    results.write(u_p.split(deepcopy=True)[0], time_current)
    results.write(u_p.split(deepcopy=True)[1], time_current)
    u0_p0.assign(u_p)
Here is the same problem which I tried to solve by nonlinear solver
import fenics as fe
import logging
# geometry
N_POINTS_X_AXIS = 5
t_0 = 0.0
delta_t = 1e-3
t_final = 1
# parameters
# Density
# Lame parameters
LAME_MU =  5.0e6
LAME_LAMBDA = 8.0e6
DENSITY = 0.0 # b
# initialization
u0_p0.assign(u_p)
tol = 1e-14
# Top boundary
# Bottom boundary
# Left boundary
# Right boundary
def sigma(u, p):
        cauchy_stress = (
            p * fe.Identity(2)
# Weak forms
weak_form_momentum_balance = (fe.inner(sigma(u, p), nabla_grad(u_test)) * fe.dx -
weak_form_volume_balance = (nabla_div((u - u0)/delta_t) * p_test * fe.dx +
                            K_s / MU_FR * fe.dot(nabla_grad(p), nabla_grad(p_test)) * fe.dx)
J  = fe.derivative(weak_form, u_p, u_p_trial)   # Gateaux derivative in dir. of u
time_current = t_0
    fe.solve(
        weak_form==0,
        u_p,
        bc_vector)
    'ME'
    u0_p0.assign(u_p)
And the error appears as:
<ipython-input-2-e5c71400c768> in <module>
    138         weak_form==0,
    139         u_p,
--> 140         bc_vector)
    141     'ME'
    142     results.write(u_p.split(deepcopy=True)[0], time_current)
1 frames
/usr/local/lib/python3.7/dist-packages/dolfin/fem/solving.py in _solve_varproblem(*args, **kwargs)
    312             solver = NonlinearVariationalSolver(problem)
    313             solver.parameters.update(solver_parameters)
--> 314             solver.solve()
    315
    316
RuntimeError:
*** Process: 0
*** Git changeset:  74a6ac2095059ea6582fe4ea11686c1c723e14f5
