RuntimeError: Newton solver did not converge because maximum number of iterations reached
Hello everyone,
i’ trying to solve the following nonlinear equation using dolfinx, and i keep getting the error that Newton solver did not converge because maximum number of iterations is reached.
Equation:
Unbenannt112
i defined c as a constant and g as a given Function on my domain.
Code defining the nonlinear problem:
F = ufl.inner(u*u/c,v)*ufl.dx - ufl.inner(ufl.dot(ufl.grad(g),ufl.grad(u)),v)*ufl.dx
problem = fem.petsc.NonlinearProblem(F, u, bcu)
from dolfinx import nls
solver = nls.petsc.NewtonSolver(MPI.COMM_WORLD, problem)
solver.convergence_criterion = "residual"
solver.atol = 1e-6
solver.rtol = 1e-6
solver.report = True
ksp = solver.krylov_solver
opts = PETSc.Options()
ksp.setFromOptions()
from dolfinx import log
n, converged = solver.solve(u)
assert(converged)
the Error i get:
2022-04-20 21:16:55.998 (  29.616s) [main            ]       NewtonSolver.cpp:36    INFO| Newton iteration 0: r (abs) = 0.060699 (tol = 1e-06) r (rel) = inf(tol = 1e-06)
2022-04-20 21:16:56.000 (  29.619s) [main            ]              petsc.cpp:677   INFO| PETSc Krylov solver starting to solve system.
2022-04-20 21:16:56.025 (  29.644s) [main            ]       NewtonSolver.cpp:36    INFO| Newton iteration 1: r (abs) = 0.600538 (tol = 1e-06) r (rel) = 1949.02(tol = 1e-06)
2022-04-20 21:16:56.028 (  29.647s) [main            ]              petsc.cpp:677   INFO| PETSc Krylov solver starting to solve system.
2022-04-20 21:16:59.059 (  32.677s) [main            ]       NewtonSolver.cpp:36    INFO| Newton iteration 2: r (abs) = 471024 (tol = 1e-06) r (rel) = 1.52869e+09(tol = 1e-06)
2022-04-20 21:16:59.060 (  32.679s) [main            ]              petsc.cpp:677   INFO| PETSc Krylov solver starting to solve system.
2022-04-20 21:16:59.070 (  32.689s) [main            ]       NewtonSolver.cpp:36    INFO| Newton iteration 3: r (abs) = 1.12878e+06 (tol = 1e-06) r (rel) = 3.66342e+09(tol = 1e-06)
2022-04-20 21:16:59.073 (  32.691s) [main            ]              petsc.cpp:677   INFO| PETSc Krylov solver starting to solve system.
2022-04-20 21:17:04.634 (  38.253s) [main            ]       NewtonSolver.cpp:36    INFO| Newton iteration 4: r (abs) = 1.13335e+06 (tol = 1e-06) r (rel) = 3.67824e+09(tol = 1e-06)
2022-04-20 21:17:04.637 (  38.255s) [main            ]              petsc.cpp:677   INFO| PETSc Krylov solver starting to solve system.
2022-04-20 21:17:04.669 (  38.287s) [main            ]       NewtonSolver.cpp:36    INFO| Newton iteration 5: r (abs) = 1.2926e+08 (tol = 1e-06) r (rel) = 4.19508e+11(tol = 1e-06)
2022-04-20 21:17:04.670 (  38.289s) [main            ]              petsc.cpp:677   INFO| PETSc Krylov solver starting to solve system.
2022-04-20 21:17:04.677 (  38.296s) [main            ]       NewtonSolver.cpp:36    INFO| Newton iteration 6: r (abs) = 5.30945e+10 (tol = 1e-06) r (rel) = 1.72316e+14(tol = 1e-06)
2022-04-20 21:17:04.679 (  38.297s) [main            ]              petsc.cpp:677   INFO| PETSc Krylov solver starting to solve system.
2022-04-20 21:17:04.690 (  38.308s) [main            ]       NewtonSolver.cpp:36    INFO| Newton iteration 7: r (abs) = 5.44664e+12 (tol = 1e-06) r (rel) = 1.76769e+16(tol = 1e-06)
2022-04-20 21:17:04.692 (  38.311s) [main            ]              petsc.cpp:677   INFO| PETSc Krylov solver starting to solve system.
2022-04-20 21:17:04.705 (  38.324s) [main            ]       NewtonSolver.cpp:36    INFO| Newton iteration 8: r (abs) = 6.0341e+14 (tol = 1e-06) r (rel) = 1.95835e+18(tol = 1e-06)
2022-04-20 21:17:04.708 (  38.327s) [main            ]              petsc.cpp:677   INFO| PETSc Krylov solver starting to solve system.
2022-04-20 21:17:04.740 (  38.359s) [main            ]       NewtonSolver.cpp:36    INFO| Newton iteration 9: r (abs) = 1.14422e+17 (tol = 1e-06) r (rel) = 3.71353e+20(tol = 1e-06)
2022-04-20 21:17:04.743 (  38.362s) [main            ]              petsc.cpp:677   INFO| PETSc Krylov solver starting to solve system.
2022-04-20 21:17:04.768 (  38.386s) [main            ]       NewtonSolver.cpp:36    INFO| Newton iteration 10: r (abs) = 5.19606e+17 (tol = 1e-06) r (rel) = 1.68636e+21(tol = 1e-06)
2022-04-20 21:17:04.770 (  38.389s) [main            ]              petsc.cpp:677   INFO| PETSc Krylov solver starting to solve system.
2022-04-20 21:17:04.792 (  38.410s) [main            ]       NewtonSolver.cpp:36    INFO| Newton iteration 11: r (abs) = 6.84943e+17 (tol = 1e-06) r (rel) = 2.22296e+21(tol = 1e-06)
2022-04-20 21:17:04.794 (  38.413s) [main            ]              petsc.cpp:677   INFO| PETSc Krylov solver starting to solve system.
2022-04-20 21:17:04.810 (  38.428s) [main            ]       NewtonSolver.cpp:36    INFO| Newton iteration 12: r (abs) = 2.11929e+18 (tol = 1e-06) r (rel) = 6.87807e+21(tol = 1e-06)
2022-04-20 21:17:04.811 (  38.430s) [main            ]              petsc.cpp:677   INFO| PETSc Krylov solver starting to solve system.
2022-04-20 21:17:04.825 (  38.444s) [main            ]       NewtonSolver.cpp:36    INFO| Newton iteration 13: r (abs) = 3.17833e+24 (tol = 1e-06) r (rel) = 1.03152e+28(tol = 1e-06)
2022-04-20 21:17:04.828 (  38.446s) [main            ]              petsc.cpp:677   INFO| PETSc Krylov solver starting to solve system.
2022-04-20 21:17:04.845 (  38.464s) [main            ]       NewtonSolver.cpp:36    INFO| Newton iteration 14: r (abs) = 8.03616e+23 (tol = 1e-06) r (rel) = 2.60811e+27(tol = 1e-06)
2022-04-20 21:17:04.848 (  38.467s) [main            ]              petsc.cpp:677   INFO| PETSc Krylov solver starting to solve system.
2022-04-20 21:17:04.870 (  38.488s) [main            ]       NewtonSolver.cpp:36    INFO| Newton iteration 15: r (abs) = 9.51312e+25 (tol = 1e-06) r (rel) = 3.08745e+29(tol = 1e-06)
2022-04-20 21:17:04.873 (  38.491s) [main            ]              petsc.cpp:677   INFO| PETSc Krylov solver starting to solve system.
2022-04-20 21:17:04.904 (  38.523s) [main            ]       NewtonSolver.cpp:36    INFO| Newton iteration 16: r (abs) = 7.54087e+26 (tol = 1e-06) r (rel) = 2.44736e+30(tol = 1e-06)
2022-04-20 21:17:04.907 (  38.525s) [main            ]              petsc.cpp:677   INFO| PETSc Krylov solver starting to solve system.
2022-04-20 21:17:04.928 (  38.546s) [main            ]       NewtonSolver.cpp:36    INFO| Newton iteration 17: r (abs) = 1.92042e+27 (tol = 1e-06) r (rel) = 6.23267e+30(tol = 1e-06)
2022-04-20 21:17:04.930 (  38.549s) [main            ]              petsc.cpp:677   INFO| PETSc Krylov solver starting to solve system.
2022-04-20 21:17:04.941 (  38.560s) [main            ]       NewtonSolver.cpp:36    INFO| Newton iteration 18: r (abs) = 1.22528e+27 (tol = 1e-06) r (rel) = 3.97661e+30(tol = 1e-06)
2022-04-20 21:17:04.946 (  38.564s) [main            ]              petsc.cpp:677   INFO| PETSc Krylov solver starting to solve system.
2022-04-20 21:17:04.969 (  38.587s) [main            ]       NewtonSolver.cpp:36    INFO| Newton iteration 19: r (abs) = 3.46014e+29 (tol = 1e-06) r (rel) = 1.12298e+33(tol = 1e-06)
2022-04-20 21:17:04.971 (  38.590s) [main            ]              petsc.cpp:677   INFO| PETSc Krylov solver starting to solve system.
2022-04-20 21:17:05.002 (  38.621s) [main            ]       NewtonSolver.cpp:36    INFO| Newton iteration 20: r (abs) = 6.40238e+30 (tol = 1e-06) r (rel) = 2.07787e+34(tol = 1e-06)
2022-04-20 21:17:05.005 (  38.624s) [main            ]              petsc.cpp:677   INFO| PETSc Krylov solver starting to solve system.
2022-04-20 21:17:05.025 (  38.643s) [main            ]       NewtonSolver.cpp:36    INFO| Newton iteration 21: r (abs) = 2.47446e+31 (tol = 1e-06) r (rel) = 8.03076e+34(tol = 1e-06)
2022-04-20 21:17:05.028 (  38.646s) [main            ]              petsc.cpp:677   INFO| PETSc Krylov solver starting to solve system.
2022-04-20 21:17:05.048 (  38.666s) [main            ]       NewtonSolver.cpp:36    INFO| Newton iteration 22: r (abs) = 1.74874e+31 (tol = 1e-06) r (rel) = 5.67548e+34(tol = 1e-06)
2022-04-20 21:17:05.051 (  38.669s) [main            ]              petsc.cpp:677   INFO| PETSc Krylov solver starting to solve system.
2022-04-20 21:17:05.069 (  38.688s) [main            ]       NewtonSolver.cpp:36    INFO| Newton iteration 23: r (abs) = 2.1068e+31 (tol = 1e-06) r (rel) = 6.83756e+34(tol = 1e-06)
2022-04-20 21:17:05.081 (  38.700s) [main            ]              petsc.cpp:677   INFO| PETSc Krylov solver starting to solve system.
2022-04-20 21:17:05.095 (  38.714s) [main            ]       NewtonSolver.cpp:36    INFO| Newton iteration 24: r (abs) = 2.10729e+31 (tol = 1e-06) r (rel) = 6.83912e+34(tol = 1e-06)
2022-04-20 21:17:05.104 (  38.722s) [main            ]              petsc.cpp:677   INFO| PETSc Krylov solver starting to solve system.
2022-04-20 21:17:05.122 (  38.741s) [main            ]       NewtonSolver.cpp:36    INFO| Newton iteration 25: r (abs) = 1.176e+32 (tol = 1e-06) r (rel) = 3.81665e+35(tol = 1e-06)
2022-04-20 21:17:05.124 (  38.742s) [main            ]              petsc.cpp:677   INFO| PETSc Krylov solver starting to solve system.
2022-04-20 21:17:05.139 (  38.757s) [main            ]       NewtonSolver.cpp:36    INFO| Newton iteration 26: r (abs) = 1.86258e+32 (tol = 1e-06) r (rel) = 6.04495e+35(tol = 1e-06)
2022-04-20 21:17:05.141 (  38.760s) [main            ]              petsc.cpp:677   INFO| PETSc Krylov solver starting to solve system.
2022-04-20 21:17:05.165 (  38.783s) [main            ]       NewtonSolver.cpp:36    INFO| Newton iteration 27: r (abs) = 5.69039e+34 (tol = 1e-06) r (rel) = 1.8468e+38(tol = 1e-06)
2022-04-20 21:17:05.170 (  38.789s) [main            ]              petsc.cpp:677   INFO| PETSc Krylov solver starting to solve system.
2022-04-20 21:17:05.186 (  38.805s) [main            ]       NewtonSolver.cpp:36    INFO| Newton iteration 28: r (abs) = 8.46494e+39 (tol = 1e-06) r (rel) = 2.74727e+43(tol = 1e-06)
2022-04-20 21:17:05.188 (  38.807s) [main            ]              petsc.cpp:677   INFO| PETSc Krylov solver starting to solve system.
2022-04-20 21:17:05.202 (  38.820s) [main            ]       NewtonSolver.cpp:36    INFO| Newton iteration 29: r (abs) = 8.46507e+39 (tol = 1e-06) r (rel) = 2.74731e+43(tol = 1e-06)
2022-04-20 21:17:05.214 (  38.832s) [main            ]              petsc.cpp:677   INFO| PETSc Krylov solver starting to solve system.
2022-04-20 21:17:05.235 (  38.854s) [main            ]       NewtonSolver.cpp:36    INFO| Newton iteration 30: r (abs) = 8.46744e+39 (tol = 1e-06) r (rel) = 2.74808e+43(tol = 1e-06)
2022-04-20 21:17:05.238 (  38.856s) [main            ]              petsc.cpp:677   INFO| PETSc Krylov solver starting to solve system.
2022-04-20 21:17:05.269 (  38.887s) [main            ]       NewtonSolver.cpp:36    INFO| Newton iteration 31: r (abs) = 3.58916e+41 (tol = 1e-06) r (rel) = 1.16485e+45(tol = 1e-06)
2022-04-20 21:17:05.275 (  38.894s) [main            ]              petsc.cpp:677   INFO| PETSc Krylov solver starting to solve system.
2022-04-20 21:17:05.290 (  38.908s) [main            ]       NewtonSolver.cpp:36    INFO| Newton iteration 32: r (abs) = 1.56324e+49 (tol = 1e-06) r (rel) = 5.07344e+52(tol = 1e-06)
2022-04-20 21:17:05.292 (  38.911s) [main            ]              petsc.cpp:677   INFO| PETSc Krylov solver starting to solve system.
2022-04-20 21:17:05.306 (  38.924s) [main            ]       NewtonSolver.cpp:36    INFO| Newton iteration 33: r (abs) = 1.96084e+56 (tol = 1e-06) r (rel) = 6.36384e+59(tol = 1e-06)
2022-04-20 21:17:05.307 (  38.926s) [main            ]              petsc.cpp:677   INFO| PETSc Krylov solver starting to solve system.
2022-04-20 21:17:05.316 (  38.935s) [main            ]       NewtonSolver.cpp:36    INFO| Newton iteration 34: r (abs) = 1.04376e+57 (tol = 1e-06) r (rel) = 3.38748e+60(tol = 1e-06)
2022-04-20 21:17:05.319 (  38.938s) [main            ]              petsc.cpp:677   INFO| PETSc Krylov solver starting to solve system.
2022-04-20 21:17:05.326 (  38.945s) [main            ]       NewtonSolver.cpp:36    INFO| Newton iteration 35: r (abs) = 1.04376e+57 (tol = 1e-06) r (rel) = 3.38748e+60(tol = 1e-06)
2022-04-20 21:17:05.328 (  38.946s) [main            ]              petsc.cpp:677   INFO| PETSc Krylov solver starting to solve system.
2022-04-20 21:17:05.338 (  38.957s) [main            ]       NewtonSolver.cpp:36    INFO| Newton iteration 36: r (abs) = 1.40747e+57 (tol = 1e-06) r (rel) = 4.56789e+60(tol = 1e-06)
2022-04-20 21:17:05.341 (  38.960s) [main            ]              petsc.cpp:677   INFO| PETSc Krylov solver starting to solve system.
2022-04-20 21:17:05.355 (  38.973s) [main            ]       NewtonSolver.cpp:36    INFO| Newton iteration 37: r (abs) = 2.87834e+57 (tol = 1e-06) r (rel) = 9.34154e+60(tol = 1e-06)
2022-04-20 21:17:05.357 (  38.976s) [main            ]              petsc.cpp:677   INFO| PETSc Krylov solver starting to solve system.
2022-04-20 21:17:05.371 (  38.990s) [main            ]       NewtonSolver.cpp:36    INFO| Newton iteration 38: r (abs) = 1.89304e+58 (tol = 1e-06) r (rel) = 6.14379e+61(tol = 1e-06)
2022-04-20 21:17:05.373 (  38.992s) [main            ]              petsc.cpp:677   INFO| PETSc Krylov solver starting to solve system.
2022-04-20 21:17:05.382 (  39.000s) [main            ]       NewtonSolver.cpp:36    INFO| Newton iteration 39: r (abs) = 1.81924e+60 (tol = 1e-06) r (rel) = 5.90429e+63(tol = 1e-06)
2022-04-20 21:17:05.384 (  39.003s) [main            ]              petsc.cpp:677   INFO| PETSc Krylov solver starting to solve system.
2022-04-20 21:17:05.395 (  39.013s) [main            ]       NewtonSolver.cpp:36    INFO| Newton iteration 40: r (abs) = 1.81942e+60 (tol = 1e-06) r (rel) = 5.90486e+63(tol = 1e-06)
2022-04-20 21:17:05.397 (  39.015s) [main            ]              petsc.cpp:677   INFO| PETSc Krylov solver starting to solve system.
2022-04-20 21:17:05.407 (  39.026s) [main            ]       NewtonSolver.cpp:36    INFO| Newton iteration 41: r (abs) = 1.83654e+60 (tol = 1e-06) r (rel) = 5.96044e+63(tol = 1e-06)
2022-04-20 21:17:05.410 (  39.028s) [main            ]              petsc.cpp:677   INFO| PETSc Krylov solver starting to solve system.
2022-04-20 21:17:05.420 (  39.039s) [main            ]       NewtonSolver.cpp:36    INFO| Newton iteration 42: r (abs) = 1.10833e+62 (tol = 1e-06) r (rel) = 3.59706e+65(tol = 1e-06)
2022-04-20 21:17:05.423 (  39.041s) [main            ]              petsc.cpp:677   INFO| PETSc Krylov solver starting to solve system.
2022-04-20 21:17:05.442 (  39.061s) [main            ]       NewtonSolver.cpp:36    INFO| Newton iteration 43: r (abs) = 2.59137e+63 (tol = 1e-06) r (rel) = 8.41019e+66(tol = 1e-06)
2022-04-20 21:17:05.444 (  39.062s) [main            ]              petsc.cpp:677   INFO| PETSc Krylov solver starting to solve system.
2022-04-20 21:17:05.455 (  39.073s) [main            ]       NewtonSolver.cpp:36    INFO| Newton iteration 44: r (abs) = 5.05397e+63 (tol = 1e-06) r (rel) = 1.64025e+67(tol = 1e-06)
2022-04-20 21:17:05.459 (  39.077s) [main            ]              petsc.cpp:677   INFO| PETSc Krylov solver starting to solve system.
2022-04-20 21:17:05.469 (  39.088s) [main            ]       NewtonSolver.cpp:36    INFO| Newton iteration 45: r (abs) = 5.29098e+63 (tol = 1e-06) r (rel) = 1.71717e+67(tol = 1e-06)
2022-04-20 21:17:05.472 (  39.090s) [main            ]              petsc.cpp:677   INFO| PETSc Krylov solver starting to solve system.
2022-04-20 21:17:05.491 (  39.109s) [main            ]       NewtonSolver.cpp:36    INFO| Newton iteration 46: r (abs) = 1.42779e+67 (tol = 1e-06) r (rel) = 4.63384e+70(tol = 1e-06)
2022-04-20 21:17:05.494 (  39.112s) [main            ]              petsc.cpp:677   INFO| PETSc Krylov solver starting to solve system.
2022-04-20 21:17:05.514 (  39.133s) [main            ]       NewtonSolver.cpp:36    INFO| Newton iteration 47: r (abs) = 2.86324e+68 (tol = 1e-06) r (rel) = 9.29255e+71(tol = 1e-06)
2022-04-20 21:17:05.517 (  39.136s) [main            ]              petsc.cpp:677   INFO| PETSc Krylov solver starting to solve system.
2022-04-20 21:17:05.533 (  39.151s) [main            ]       NewtonSolver.cpp:36    INFO| Newton iteration 48: r (abs) = 2.86324e+68 (tol = 1e-06) r (rel) = 9.29255e+71(tol = 1e-06)
2022-04-20 21:17:05.536 (  39.154s) [main            ]              petsc.cpp:677   INFO| PETSc Krylov solver starting to solve system.
2022-04-20 21:17:05.554 (  39.172s) [main            ]       NewtonSolver.cpp:36    INFO| Newton iteration 49: r (abs) = 2.92111e+68 (tol = 1e-06) r (rel) = 9.48037e+71(tol = 1e-06)
2022-04-20 21:17:05.556 (  39.175s) [main            ]              petsc.cpp:677   INFO| PETSc Krylov solver starting to solve system.
2022-04-20 21:17:05.573 (  39.191s) [main            ]       NewtonSolver.cpp:36    INFO| Newton iteration 50: r (abs) = 3.95506e+68 (tol = 1e-06) r (rel) = 1.2836e+72(tol = 1e-06)
Input In [13], in <cell line: 32>()
     29 from dolfinx import log
     31 log.set_log_level(log.LogLevel.INFO)
---> 32 n, converged = solver.solve(u)
     33 assert(converged)
     34 print(f"Number of interations: {n:d}")
File /usr/local/dolfinx-complex/lib/python3.8/dist-packages/dolfinx/nls/petsc.py:41, in NewtonSolver.solve(self, u)
     38 def solve(self, u: fem.Function):
     39     """Solve non-linear problem into function u. Returns the number
     40     of iterations and if the solver converged."""
---> 41     n, converged = super().solve(u.vector)
     42     u.x.scatter_forward()
     43     return n, converged
Could someone help me with that or gives me tips on how this could be solved, i would really appreciate it.
Thanks.
I would suggest reading: Default absolute tolerance and relative tolerance - #4 by nate by @nate
