Divergence in simple Hyperelasticity problem
Dear all,
I am currently working on an incompressible hyperelastic problem on a complicated mesh, which at the moment I cannot get to converge. As part of the debugging process I tried the following code on a simple cube mesh, with Dirichlet boundary conditions set to 0 at the bottom plane x = 0:
from basix.ufl import quadrature_element, element, mixed_element
body = dolfinx.mesh.create_box(MPI.COMM_WORLD,[[0.0,0.0,0.0], [1, 1, 1]], [2, 2, 2], dolfinx.mesh.CellType.hexahedron)
d = body.geometry.dim
def bttm(x):
    tol = 1e-10
    collapsedV, collapsedMap = V.sub(0).collapse()
    zmin = collapsedV.tabulate_dof_coordinates()[:, 0].min() #Z coordinate of the bottom plane
    print(zmin)
    return np.isclose(x[0],zmin, atol = tol)
U_el = element("CG", body.basix_cell(), 1, shape=(d,))
P_el = element("CG", body.basix_cell(), 1)
V_el = mixed_element([U_el,P_el])
V = dolfinx.fem.functionspace(body, V_el) #Define vector element for displacement field u
up = dolfinx.fem.Function(V)
u, p = ufl.split(up)
v, dp = ufl.TestFunctions(V)
# Deformation gradient
I = ufl.variable(ufl.Identity(d))
F = ufl.variable(I + ufl.grad(u))
gram_A = ufl.variable(F.T*F)
I1 = ufl.variable(ufl.tr(gram_A))
J = ufl.variable(ufl.det(F))
w = (I1 - 3.0)/2.0
dx = ufl.Measure("dx", domain=body, metadata=metadata)
dE = (ufl.inner(ufl.diff(w,F)+p*ufl.diff(J,F),ufl.grad(v))+dp*(J-1.0))*dx
V1, _ = V.sub(0).collapse()
u_D = dolfinx.fem.Function(V1)
u_D.x.array[:] = 0.0
fdim = body.topology.dim - 1
boundary_facets_bttm = dolfinx.mesh.locate_entities_boundary(body, fdim, bttm)
boundary_dofs_b = dolfinx.fem.locate_dofs_topological((V.sub(0), V1), fdim, boundary_facets_bttm)
bc1 = dolfinx.fem.dirichletbc(u_D, boundary_dofs_b, V.sub(0))
dolfinx.log.set_log_level(dolfinx.log.LogLevel.INFO)
problem = NonlinearProblem(dE, up, [bc1])
solver = NewtonSolver(body.comm, problem)
solver.atol = 1e-8
solver.rtol = 1e-8
solver.relaxation_parameter = 1.0
solver.convergence_criterion = "residual"
solver.solve(up)
u, p = up.split()
So in principle nothing should happen (since there are no forces and the only prescribed displacement is 0). However, the following occurs:
[2025-03-04 10:44:14.550] [info] Column ghost size increased from 0 to 0
[2025-03-04 10:44:14.551] [info] Newton iteration 0: r (abs) = 0.7806247497997992 (tol = 1e-08), r (rel) = inf (tol = 1e-08)
[2025-03-04 10:44:14.551] [info] PETSc Krylov solver starting to solve system.
[2025-03-04 10:44:14.552] [info] Newton iteration 1: r (abs) = -nan (tol = 1e-08), r (rel) = -nan (tol = 1e-08)
[2025-03-04 10:44:14.552] [info] PETSc Krylov solver starting to solve system.
[2025-03-04 10:44:14.553] [info] Newton iteration 2: r (abs) = -nan (tol = 1e-08), r (rel) = -nan (tol = 1e-08)
[2025-03-04 10:44:14.553] [info] PETSc Krylov solver starting to solve system.
[2025-03-04 10:44:14.554] [info] Newton iteration 3: r (abs) = -nan (tol = 1e-08), r (rel) = -nan (tol = 1e-08)
[2025-03-04 10:44:14.587] [info] PETSc Krylov solver starting to solve system.
[2025-03-04 10:44:14.587] [info] Newton iteration 49: r (abs) = -nan (tol = 1e-08), r (rel) = -nan (tol = 1e-08)
[2025-03-04 10:44:14.588] [info] PETSc Krylov solver starting to solve system.
[2025-03-04 10:44:14.588] [info] Newton iteration 50: r (abs) = -nan (tol = 1e-08), r (rel) = -nan (tol = 1e-08)
  File "/home/fenics/shared/Underconstrained_Networks/FEM_Geometries/Hyperelastic_square.py", line 61, in <module>
    solver.solve(up)
  File "/usr/local/dolfinx-real/lib/python3.12/dist-packages/dolfinx/nls/petsc.py", line 51, in solve
    n, converged = super().solve(u.x.petsc_vec)
Why is the 0th iteration resulting in a non zero value and why is this diverging so quickly? I also tried changing the convergence criterion to incremental but that didnt help.
Thanks for any help that you can provide!
Is this really true? It seems to me that the dp*(J-1.0)*dx term produces a right-hand-side.
Hopefully that gives you a handle on tackling your problem…
Hi, is there a reason you use degree 1 for both u and p? It converges nicely if I change to quadratic elements for u:
U_el = element("CG", body.basix_cell(), 2, shape=(d,))
This worked, Thanks! I was using CG1 elements because they didnt give me any problem when I solved hyperelasticity problems in legacy fenics. Is there any particular reason why this isnt the case any more?
