Dynamic Elasticity Not Converging
Hello, I am trying to solve a dynamic linear elastic problem. I have gone through numerous tutorials. But the solution is simply diverging. Any help would be appreciated.
import dolfinx as fe
from dolfinx.fem.petsc import assemble_vector, assemble_matrix, create_vector, apply_lifting, set_bc
def main():
    L = 1
    W = 0.2
    mesh = fe.mesh.create_box(MPI.COMM_WORLD, [np.array([0, 0, 0]), np.array([L, W, W])],
                         [20, 6, 6], cell_type=fe.mesh.CellType.hexahedron)
    element = ufl.VectorElement("Lagrange", mesh.ufl_cell(), 1)
    V = fe.fem.functionspace(mesh, element)
    def boundary_1(x):
        return np.isclose(x[0], 0)
    fdim = mesh.topology.dim - 1
    boundary_1_facets = fe.mesh.locate_entities_boundary(mesh, fdim, boundary_1)
    bc = fe.fem.dirichletbc(fe.default_scalar_type((0.0, 0.0, 0.0)), fe.fem.locate_dofs_topological(V, fdim, boundary_1_facets), V)
    u = ufl.TrialFunction(V)            # Incremental displacement
    v  = ufl.TestFunction(V)             # Test function
    u_dot  = fe.fem.Function(V)                # First time derivative of displacement
    u_2dot  = fe.fem.Function(V)                # Second time derivative of displacement
    u_old  = fe.fem.Function(V)
    u_dot_old  = fe.fem.Function(V)
    u_2dot_old  = fe.fem.Function(V)
    rho = 1
    d = len(u)
    I = ufl.variable(ufl.Identity(d))             # Identity tensor
    F = ufl.variable(I + ufl.grad(u))             # Deformation gradient
    E = ufl.variable(F.T*F)                   # Right Cauchy-Green tensor
    J = ufl.variable(ufl.det(F))
    ds = ufl.Measure('ds', domain=mesh, metadata=metadata)
    dx = ufl.Measure("dx", domain=mesh, metadata=metadata)
    maximum_pressure = 15
    minimum_pressure = 5
    time_step = fe.default_scalar_type(0.0005)
    num_steps = int(1/0.0005)
    pressure = np.append(np.linspace(minimum_pressure, maximum_pressure, num=10), np.linspace(maximum_pressure, minimum_pressure, num=num_steps))
    p = fe.fem.Constant(mesh, pressure[0])
    normal = ufl.FacetNormal(mesh)
    E = fe.default_scalar_type(1.0e4)
    nu = fe.default_scalar_type(0.3)
    mu = fe.fem.Constant(mesh, E / (2 * (1 + nu)))
    lmbda = fe.fem.Constant(mesh, E * nu / ((1 + nu) * (1 - 2 * nu)))
    S = 2.0 * mu * ufl.sym(ufl.grad(u)) + lmbda * ufl.tr(ufl.sym(ufl.grad(u))) * I
    F = rho * ufl.inner(u_2dot, v) * dx + ufl.inner(ufl.grad(v), S) * dx - ufl.inner(v, p * normal) * ds
    bilinear_form = fe.fem.form(ufl.lhs(F))
    linear_form = fe.fem.form(ufl.rhs(F))
    A = assemble_matrix(bilinear_form, bcs=[bc])
    b = create_vector(linear_form)
    solver.setInitialGuessNonzero(True)
    solver.setOperators(A)
    solver.getPC().setType(PETSc.PC.Type.SOR)
    solver.view()
    displacement = fe.fem.Function(V)
    alpha = fe.default_scalar_type(0.5)
    betta = fe.default_scalar_type(0.5)
    def update_u_2dot(u_prime, u_old_prime, u_dot_old_prime, u_2dot_old_prime):
        return 2/(betta * time_step**2) * (u_prime - u_old_prime)\
         - 2/(betta * time_step) * u_dot_old_prime\
          - (1/betta - 1) * u_2dot_old_prime
    def update_u_dot(u_dot_old_prime, u_2dot_old_prime, u_2dot_prime):
        return u_dot_old_prime\
         + time_step * (1-alpha) * u_2dot_old_prime\
          + time_step * alpha * u_2dot_prime
    t = 0
    for i in range(num_steps):
        print(i)
        t += time_step
        p.value = pressure[i]
        with b.localForm() as loc_b:
            loc_b.set(0)
        assemble_vector(b, linear_form)
        apply_lifting(b, [bilinear_form], [[bc]])
        set_bc(b, [bc])
        # Solve linear problem
        solver.solve(b, displacement.vector)
        displacement.x.scatter_forward()
        print(displacement.x.array)
        u_2dot_prime = update_u_2dot(displacement.x.array[:], u_old.x.array[:], u_dot_old.x.array[:], u_2dot_old.x.array[:])
        u_dot_prime = update_u_dot(u_dot_old.x.array[:], u_2dot_old.x.array[:], u_2dot_prime)
        u_2dot.x.array[:] = u_2dot_prime
        u_dot.x.array[:] = u_dot_prime
if __name__ == "__main__":
    main()
