Diverging Laplacian of vector field
Dear FEniCS community,
I have a diffusion equation for unit vector \mathbf{n}(\mathbf{x}, t)
\frac{\partial}{\partial t} \mathbf{n}(\mathbf{x}, t) = \nabla^2 \mathbf{n} (\mathbf{x}, t), \quad |\mathbf{n}| = 1,
with periodic boundary condition and homogeneous initial condition
\mathbf{n}(\mathbf{x},0) = (0, 1).
The solution should not evolve due to the homogeneous initial condition. Thus the Laplacian of \mathbf{n} should be (0, 0).
However, when implemented using FEniCS, \mathbf{n} is not exactly (0,1) due to numerical round-off error. The laplacian of \mathbf{n}
ufl.nabla_div(ufl.nabla_grad(n))
seems to exaggerate the round-off error of \mathbf{n}, and diverges a lot from (0,0).
What is the right way to calculate Laplacian in this situation?
Please enlighten me on this. Thanks.
Below are the whole code can be run and sample output.
PS: I use fenics-2019.1.0-py39hf3d152e_18 installed via Conda if it helps.
code:
import dolfin as df
num_steps = 500   # number of time steps
dt = 1e-3  # time step size
# set mesh size
nn = 80
nx = nn
ny = nn
class ICn(df.UserExpression):
    def eval(self, values, x):
        values[0] = 0
        values[1] = 1
    def value_shape(self):
        return (2,)
class PeriodicBoundary(df.SubDomain):
        return bool((df.near(x[0], 0) or df.near(x[1], 0)) and
                    (not ((df.near(x[0], 0) and df.near(x[1], 1)) or
                     (df.near(x[0], 1) and df.near(x[1], 0)))) and
                    on_boundary)
    def map(self, x, y):
        if df.near(x[0], 1) and df.near(x[1], 1):
            y[0] = x[0] - 1.
            y[1] = x[1] - 1.
        elif df.near(x[0], 1):
            y[0] = x[0] - 1.
            y[1] = x[1]
        else:   # near(x[1], 1)
            y[0] = x[0]
            y[1] = x[1] - 1.
def laplacian(n):
    """Calculate laplacian of director."""
    return ufl.nabla_div(ufl.nabla_grad(n))
def normalize(w, dim=2, epsilon=0.01):
    """Check and normalize director to norm 1."""
    wv = w.vector()[:]
    wa = np.reshape(wv, (-1, dim))
    norms = np.linalg.norm(wa, axis=1, keepdims=True)
    if(np.max(np.abs(norms-1.)) > epsilon):
        wa = wa/norms
        for i in range(dim):
            wv[i::dim] = wa[:, i]
        w.vector().set_local(wv)
        w.vector().apply('')
    return w
# Create mesh and define function spaces
mesh = df.UnitSquareMesh(nx, ny)
# apply periodic boundary condition for director field
pbc = PeriodicBoundary()
W = df.VectorFunctionSpace(mesh, 'P', 3, constrained_domain=pbc)
DG = df.VectorFunctionSpace(mesh, 'DG', 1)
n = df.TrialFunction(W)
m = df.TestFunction(W)
# Define functions for solutions at previous and current time steps
n_n = df.Function(W)
n_ = df.Function(W)
ntmp = df.Function(W)
n_init = ICn()
n_n.interpolate(n_init)
k = df.Constant(dt)
F0 = ufl.dot((n-n_n)/k, m)*ufl.dx \
        + ufl.inner(ufl.nabla_grad(n_n), ufl.nabla_grad(m))*ufl.dx \
a0 = ufl.lhs(F0)
L0 = ufl.rhs(F0)
# Assemble matrices
A0 = df.assemble(a0)
# Time-stepping
t = 0
for i in range(num_steps):
    # Update current time
    b0 = df.assemble(L0)
    df.solve(A0, ntmp.vector(), b0)
    # normalize unit director
    ntmp = normalize(ntmp)  # check and normalize to norm 1
    n_.vector()[:] = ntmp.vector()
    laplace = df.project(laplacian(n_), DG)
    print('------ n ----------------------')
    print(n_.vector()[:])
    print('------ laplacian of n -----------')
    print(laplace.compute_vertex_values())
    # Update previous solution
    n_n.assign(n_)
Sample output:
[0. 1. 0. ... 1. 0. 1.]
[ 0.00000000e+00  0.00000000e+00  0.00000000e+00 ...  1.97993207e-07 1.98205422e-07 -1.97993207e-07]
[ 0.   0.   0.  ...  -0.00022009  -0.00022037  0.00031604]
[0.   1.000001  0.  ... 1.000001  0.  1.000001]
[ 0.   0.    0.  ...  0.34403651  0.34418522    -0.56959499]
[0.  0.99798558 0.   ...  0.99798608  0.  0.99798836]
[0.   0.   0.  ...  -624.23276296   -624.17340055  1037.42146611]
[ 0.   0.  0. ...  230399.99999999    230400.   -806400.00000001]
It looks like this may just be a manifestation of the instability of the explicit Euler method for a parabolic problem like this. If I switch to implicit Euler, i.e.,
     + ufl.inner(ufl.nabla_grad(n), ufl.nabla_grad(m))*ufl.dx
(where I’ve changed n_n to n in the argument of the first gradient), the issue goes away. Even though ufl.nabla_grad(n_n) should remain zero for all time steps in exact arithmetic, an unstable integrator will rapidly amplify any small perturbation.
Thanks a lot. I understand it now. Really solved my problem. (And sorry for the late response.)
