Laplacian of solution extremely noisy
I have been trying to plot the residual of the solution over my entire domain, but I constantly keep finding that computing the Laplacian of even a well-converged solution ends up creating nonsensically large values. The problem at hand is a system of two Poisson equations with an extra nonlinear forcing term Ku1u2. Here’s the code I used:
import fenics
ndims = 2
domain_extent = [[-2.0,2.0],[-2.0,2.0]]
p_bottomleft = fenics.Point(*[extent[0] for extent in domain_extent])
p_topright = fenics.Point(*[extent[1] for extent in domain_extent])
mesh = fenics.RectangleMesh.create(p=[p_bottomleft,p_topright],n=[100 for _ in range(ndims)],cell_type=fenics.CellType.Type.triangle)
P1 = fenics.FiniteElement('CG', fenics.triangle, 2)
element = fenics.MixedElement([P1 for _ in range(ndims)])
FuncSpace = fenics.FunctionSpace(mesh, element)
TestFuncs = fenics.TestFunctions(FuncSpace)
SolnFuncs = fenics.Function(FuncSpace)
u = fenics.split(SolnFuncs)
tol = 1e-14
bc1l = fenics.DirichletBC(FuncSpace.sub(0), fenics.Constant(-0.15), lambda x, ob: ob and fenics.near(x[0],-2.0, tol))
bc1r = fenics.DirichletBC(FuncSpace.sub(0), fenics.Constant(0.15), lambda x, ob: ob and fenics.near(x[0],2.0, tol))
bc1t = fenics.DirichletBC(FuncSpace.sub(0), fenics.Constant(0.30), lambda x, ob: ob and fenics.near(x[1],-2.0, tol))
bc1b = fenics.DirichletBC(FuncSpace.sub(0), fenics.Constant(0.30), lambda x, ob: ob and fenics.near(x[1],2.0, tol))
bc2l = fenics.DirichletBC(FuncSpace.sub(1), fenics.Constant(0.30), lambda x, ob: ob and fenics.near(x[0],-2.0, tol))
bc2r = fenics.DirichletBC(FuncSpace.sub(1), fenics.Constant(0.30), lambda x, ob: ob and fenics.near(x[0],2.0, tol))
bc2t = fenics.DirichletBC(FuncSpace.sub(1), fenics.Constant(-0.15), lambda x, ob: ob and fenics.near(x[1],-2.0, tol))
bc2b = fenics.DirichletBC(FuncSpace.sub(1), fenics.Constant(0.15), lambda x, ob: ob and fenics.near(x[1],2.0, tol))
bcs = [bc1l,bc1r,bc1t,bc1b,bc2l,bc2r,bc2t,bc2b]
diffusion_coeff = 10.0
source_coeff = 1.0
forcing_expression_1 = fenics.Expression('0.33*sin(3.1415*(x[0]-0.8*x[1])/4.0)', degree = 3)
forcing_expression_2 = fenics.Expression('-0.175*cos(3.1415*x[0]*x[1]/4.0)', degree = 3)
eq1_linear_part = \
    + fenics.inner(fenics.grad(u[0]),fenics.grad(TestFuncs[0]))*diffusion_coeff*fenics.dx \
    - forcing_expression_1 * TestFuncs[0] * fenics.dx
eq1 = eq1_linear_part + source_coeff * u[0] * u[1] * TestFuncs[0] * fenics.dx
eq2_linear_part = \
    + fenics.inner(fenics.grad(u[1]),fenics.grad(TestFuncs[1]))*diffusion_coeff*fenics.dx \
    - forcing_expression_2 * TestFuncs[1] * fenics.dx
eq2 = eq2_linear_part + source_coeff * u[0] * u[1] * TestFuncs[1] * fenics.dx
solver_parameters = {
            "newton_solver":{"maximum_iterations":50, 'relative_tolerance': 1e-6, 'absolute_tolerance': 1e-5, "error_on_nonconvergence": False, "linear_solver": "lu"}
SolnFuncs.vector().set_local(2*np.random.rand(SolnFuncs.vector().size())-1.0)
SolnFuncs.vector().apply("")
fenics.solve(eq1 + eq2 == 0, SolnFuncs, bcs, solver_parameters = solver_parameters)
#plot the solution
p = fenics.plot(SolnFuncs[0])
plt.colorbar(p)
plt.savefig('/build/tmp/u0.png')
plt.figure()
#compute laplacian of u0 and plot it
lFF0 = fenics.project(fenics.div(fenics.grad(u[0])), FuncSpace.sub(0).collapse())
p = fenics.plot(lFF0)
plt.colorbar(p)
plt.savefig('/build/tmp/u0_laplacian.png')
plt.figure()
Below are the solution and the corresponding Laplacian (see 1st reply to this post for the Laplacian):
u0
As you can see below, the Laplacian has very large spikes at the corners and the values in the rest of the domain, I have found, do not really lead to mean residual values anywhere near the value printed to stdout during the solution process. Is there a way to improve the quality of the values computed?
p.s. this was computed with fenics installed from the package available via apt on Ubuntu 20.04
The forums didn’t allow me to upload 2 pictures so here’s the plot of the Laplacian of u0:
u0_laplacian
Note that the Laplacian of a CG 2 function is not a CG 2 function.
The gradient of a CG 2 function is in the vector DG 1 space.
The trace of this function is constant inside each cell, but not well defined between cells.
Which element would you suggest for this type of application, in that case? I noticed that higher order CG elements result in even worse behaviour than CG 2. Naturally CG 1 has 0 laplacians everywhere.
Alternatively, is there a better/recommended way to get the cell-wise residuals?
I guess I would use a DG 0 space, but I am not sure why you want to visualize this. The reason for using finite elements is that you reduce continuity of the solution space.
I need the cell-wise residuals to integrate it into a reinforcement learning style control scheme as an objective for the model.
I get the following error if I use the DG 0 space for the solution variable:
ufl.log.UFLException: This integral is missing an integration domain.
Is there a way to e.g. solve the equation for u1 and u2 using CG 2 elements but then compute the laplacian using some other type of element after projecting the solutions to another function space? As a very naive solution I tried the following:
P2 = fenics.FiniteElement('DG', fenics.triangle, 0)
FuncSpace_Laplacian = fenics.FunctionSpace(mesh, element)
lFF0 = fenics.project(u[0], FuncSpace_Laplacian)
lFF0_values = fenics.project(fenics.div(fenics.grad(lFF0)), FuncSpace_Laplacian)
p = fenics.plot(lFF0_values)
which did not work unfortunately, with the following error:
File “dataset/residual_question.py”, line 61, in
File “/usr/lib/python3/dist-packages/dolfin/fem/projection.py”, line 129, in project
L = ufl.inner(w, v) * dx
File “/usr/lib/python3/dist-packages/ufl/operators.py”, line 169, in inner
return Inner(a, b)
File “/usr/lib/python3/dist-packages/ufl/tensoralgebra.py”, line 161, in new
error(“Shapes do not match: %s and %s.” % (ufl_err_str(a), ufl_err_str(b)))
File “/usr/lib/python3/dist-packages/ufl/log.py”, line 172, in error
ufl.log.UFLException: Shapes do not match: and .
I think you’re missing a fundamental point that @dokken is making. The broken Laplace operator (\nabla^2 defined on each element)
\nabla^2_h : {V}^{h,2} \rightarrow {V}_\text{DG}^{h,0}.
Your MWE is rather confusing so I’ll just write out something simpler
mesh = UnitSquareMesh(32, 32)
x = SpatialCoordinate(mesh)
V = FunctionSpace(mesh, "CG", 2)
VDG0 = FunctionSpace(mesh, "DG", 0)
a = dot(grad(u), grad(v))*dx
L = sin(pi*x[0])*sin(pi*x[1])*v*dx
bcs = DirichletBC(V, Constant(0.0), "on_boundary")
solve(a == L, u, bcs)
laplace_u = project(div(grad(u)), VDG0)
plt.gcf().add_subplot(1, 2, 1)
plot(u)
plt.title("$u_h(x,y)$")
plt.gcf().add_subplot(1, 2, 2)
plot(laplace_u)
plt.title(r"$\Pi_{V_{DG}^{0,h}} (\nabla^2 u_h(x,y))$")
Thank you for the instructive example. For my own problem, I was able to fix the issue but I had to use the CG3 space for the solution variables and then project to DG0 for the Laplacian - using CG2 and DG0 still ended up being problematic. I am a bit unsure why the added nonlinear term causes that - I suppose I need to brush up on my FEM knowledge a little bit to get to the bottom of the issue.
