I do some coupled magneto-mechanical, nonlinear, 3D simulation on a cubical periodic domain of size L^3. I am currently facing this problem: For coarse meshes (up to 55k elements) the solution is fine and meets the expectations. However, contain the meshes more elements (>75k) the solution somehow gets on a wrong path and finally diverges (see figure).
I use tetrahedrons as elements. A scalar potential approach is used to compute the magnetic quantities.
The periodic boundary conditions are this way implemented and seem to be working fine:
class PeriodicDomain(SubDomain):
# return true for left, bottom and front (x = 0, y = 0, z = 0)
# but not edges shared with sides to map
# on left, bottom or front side
bool_1 = bool( (x[0] < tol) or (x[1] < tol) or (x[2] < tol) )
# on shared edges of x=0-side
bool_2 = bool( ((x[0] < tol) and (x[2] > L - tol)) or ((x[0] < tol) and (x[1] > L - tol)) )
# on shared edges of y=0-side
bool_3 = bool( ((x[1] < tol) and (x[0] > L - tol)) or ((x[1] < tol) and (x[2] > L - tol)) )
# on shared edges of z=0-side
bool_4 = bool( ((x[2] < tol) and (x[0] > L - tol)) or ((x[2] < tol) and (x[1] > L - tol)) )
# combine bools
return bool_1 and not(bool_2) and not(bool_3) and not(bool_4) and on_boundary
# map right, top, back side to sides defined by inside
# map edges shared by this sides extra
def map(self, x, y):
# edge between z = L and x = L
if (x[0] > L - tol) and (x[1] > L - tol) and (x[2] > L - tol):
y[0] = 0
y[1] = 0
y[2] = 0
elif (x[0] > L - tol) and (x[2] > L - tol):
y[0] = 0
y[1] = x[1]
y[2] = 0
# y[0] = x[0] - L
# y[1] = x[1]
# y[2] = x[2] - L
cnt[0] += 1
# edge between x = L and y = L
elif (x[0] > L - tol) and (x[1] > L - tol):
# y[0] = x[0] - L
# y[1] = x[1] - L
# y[2] = x[2]
y[0] = 0
y[1] = 0
y[2] = x[2]
cnt[1] += 1
# edge between y = L and z = L
elif (x[1] > L - tol) and (x[2] > L - tol):
# y[0] = x[0]
# y[1] = x[1] - L
# y[2] = x[2] - L
y[0] = x[0]
y[1] = 0
y[2] = 0
cnt[2] += 1
# right side x = L
elif x[0] > L - tol:
# y[0] = x[0] - L
# y[1] = x[1]
# y[2] = x[2]
y[0] = 0
y[1] = x[1]
y[2] = x[2]
cnt[3] += 1
# top side y = L
elif x[1] > L - tol:
# y[0] = x[0]
# y[1] = x[1] - L
# y[2] = x[2]
y[0] = x[0]
y[1] = 0
y[2] = x[2]
cnt[4] += 1
# back side z = L
elif x[2] > L - tol:
# y[0] = x[0]
# y[1] = x[1]
# y[2] = x[2] - L
y[0] = x[0]
y[1] = x[1]
y[2] = 0
cnt[5] += 1
# should not happen, catch case and prompt to user
y[0] = 2000
y[1] = 0
y[2] = 0
cnt[6] += 1
print("\n!!!\n>>>>>Error within assignment of periodic boundaries.\n>>>>>Consider using different tolerance.\n!!!\n")
pbc = PeriodicDomain()
The function spaces and elements are implemented this way:
V_fluc = VectorElement('P', tetrahedron, 2) # vector elements for fluctuation field
V_pot = FiniteElement('P', tetrahedron, 2) # (scalar) finite elements for magnetic potential
FE = MixedElement([V_fluc, V_pot]) # combine elements to mixed finite elements
W = FunctionSpace(mesh, FE, constrained_domain = pbc)
Additionally one node is fixed in displacement and the potential set to 0. I use the direct ‘mumps’ solver with a relative tolerance of 1E-6. Fenics is used in the version 2018.1.0
