The Solution computed is not periodic despite the implementation of periodic boundary conditions
Let’s summarize my issue, I’ve been trying to solve the Toner-Tu equation, basically the Navier-Stokes equation with a nonlinear term, and it worked pretty well. Previously I was solving with Dirichlet boundary conditions.
Now I want to implement Periodic Boundary Conditions. I’ve faced two major issues. First, the solution returned ain’t periodic. Then, after multiple time steps, I a peak in density appears on the border and few steps later the simulations diverge. I join an Image of what’s happening then…
I work with mixed space and it wasn’t a problem before. I join some parts of my code in case you have any ideas of where it could come from…
The implementation of the periodic boundary conditions:
        return bool((near(x[0], SIZE/2) or near(x[1], SIZE/2))
                    and not(near(x[0], -SIZE/2) or near(x[1], SIZE/2)) and on_boundary)
    def map(self, x, y):
        if near(x[0], SIZE/2) and near(x[0], SIZE/2):
            y[0] = x[0]-SIZE
            y[1] = x[1]-SIZE
        elif near(x[0], SIZE/2):
            y[0] = x[0]-SIZE
            y[1] = x[1]
        elif near(x[1], SIZE/2) and not(near(x[0], -SIZE/2) or near(x[0], SIZE/2)):
            y[0] = x[0]
            y[1] = x[1]-SIZE
            y[0] = x[0]-100*SIZE
            y[1] = x[1]-100*SIZE
Then I implement the domain:
    V1 = VectorElement("Lagrange", mesh.ufl_cell(), DEG)
    V2 = FiniteElement("Lagrange", mesh.ufl_cell(), DEG)
    V = VectorFunctionSpace(mesh, 'P', DEG)
    Vs = FunctionSpace(mesh, 'P', DEG)
    # Make a mixed space
    TH = V1*V2
    if CL_P:
        # Create periodic boundary condition
        pbc = PeriodicBoundary()
        W = FunctionSpace(mesh, TH, constrained_domain=pbc)
        V = VectorFunctionSpace(mesh, 'P', DEG, constrained_domain=pbc)
        Vs = FunctionSpace(mesh, 'P', DEG, constrained_domain=pbc)
And even if it’s ugly the form that worked pretty well before:
    lamb = Constant(LAMBDA)  # SD
    alph = Constant(1e2)  # s-1
    pho_c = Constant(3e-3)  # SD
    pho = Constant(0.1)  # SD
    a2 = Constant(alph*(pho-pho_c))  # s-1
    a4 = Constant(10)  # mm-2 s
    D = Constant(1e-2)  # mm2 s-1
    D2 = Constant(4e-6*FAC_D_RHO)  # mm2 s-1
    sigma = Constant(5)  # mm2 s-2
    Dt = Constant(DT)
    # Declare the form
    F = dot((u-u_1)/Dt, v)*dx \
        +lamb*dot(dot(u, nabla_grad(u)), v)*dx \
        +D*(dot(grad(u[0]), grad(v[0]))+dot(grad(u[1]), grad(v[1])))*dx \
        -D*(dot(grad(u[0]),n)*v[0]+dot(grad(u[1]),n)*v[1])*ds\
        -(alph*(p-pho_c)-a4*dot(u, u))*dot(u, v)*dx \
        +sigma*dot(grad(p), v)*dx \
        +(((p-p_1)/Dt+div(p*u))*q+D2*dot(grad(p), grad(q)))*dx \
        -D2*dot(grad(p),n)*q*ds
    np.savetxt("./Solutions/coordo.txt", np.reshape(np.array(x.vector()), (-1, 2)))
    for i in range(0, NUM_STEP):
        plotfigure = False
        try:
            if CL_P:
                solve(F == 0, w)
                solve(F == 0, w, bcu)
        except RuntimeError:
            break
        assign(w_1, w)
Any help would be appreciated.
Thanks!
Without a minimal working example which we can copy and paste without editing, you’re unlikely to get a response. Can you reproduce your issue with a simple problem?
Something that stands out separate from your question is that it looks like you’re trying to use a Taylor-Hood type element with equal order pressure and velocity approximation. Isn’t this unstable?
Hmm Yeah it would be easier I guess sorry Here is a full example:
#!/usr/bin/env python3
# -*- coding: utf-8 -*-
def fig_defaut(u, p, ifig=-1, plotfigure=False, nom='no_name'):
    if plotfigure:
        plt.figure(figsize=(13, 13))
        pl = plot(project(u/dot(u, u)**0.5))
        pl.set_clim(0.0, 10.0)
        plot(p, alpha=0.3)
        axes = plt.gca()
        axes.set_xlabel("x (mm)", fontsize=14)
        axes.set_ylabel("y (mm)", fontsize=14)
        plt.savefig(f"./Image/{nom}_v_{ifig:05}.png", bbox_inches='tight', format='png')
        plt.close()
def get_value(x, y, XX, YY, L):
    for i in range(len(L)):
        if abs(XX[i]-x) < 1e-3 and abs(YY[i]-y) < 1e-3:
            return L[i]
    print(x, y)
    raise ValueError
# Sub domain for Periodic boundary condition
    # Left boundary is "target domain" G
    # Map right boundary (H) to left boundary (G)
            y[0] = x[0]-SIZE
            y[1] = x[1]-SIZE
            y[0] = x[0]-SIZE
            y[1] = x[1]
            y[0] = x[0]
            y[1] = x[1]-SIZE
if __name__ == '__main__':
    # définition de l'expérience
    CL_P = True  # False pour CL tangeante
    FROM_DATA = False
    FROM_SOLU = False
    # définition de la physique
    SIZE = 3
    DX = 0.05
    DT = 1e-4  # pas de temps
    LAMBDA = 0.7
    RHO_0 = 0.1
    FAC_D_RHO = 1
    # définition de la simulation
    N = int(SIZE/DX)  # Nombre d'élément par ligne/colonne
    DEG = 1  # degré des éléments
    NUM_STEP = 50000
    # définition de la sauvegarde
    NB_IM = 400
    NB_SOL = 10
    NOM = 'TT_'
    # Define the mesh
    tx = SIZE
    ty = tx
    nbx = N
    nby = nbx
    mesh = RectangleMesh(Point(-tx/2, -ty/2), Point(tx/2, ty/2), nbx, nby)
    TH = V1*V2
    if CL_P:
        W = FunctionSpace(mesh, TH)
    X = Expression(('x[0]', 'x[1]'), element=V.ufl_element())
    x = interpolate(X, V)
    # Initial conditions
    if FROM_DATA:
        nb_pr = 127
        mesh_pr = RectangleMesh(Point(-tx/2, -ty/2), Point(tx/2, ty/2), nb_pr, nb_pr)
        V_pr = VectorFunctionSpace(mesh_pr, 'P', 1)
        Vs_pr = FunctionSpace(mesh_pr, 'P', 1)
        X_pr = Expression(('x[0]', 'x[1]'), element=V_pr.ufl_element())
        x_pr = interpolate(X_pr, V_pr)
        coordo_xy = np.array(x_pr.vector()).reshape((-1, 2))
        a = np.loadtxt("./data.csv", delimiter=',')
        rho = np.zeros(128**2)
        vx = np.zeros(128**2)
        vy = np.zeros(128**2)
        for i in range(128**2):
            rho[i] = get_value(10/tx*(tx/2+coordo_xy[i, 0]), 10/tx*(tx/2+coordo_xy[i, 1]), a[:, 0], a[:, 1], a[:, 4])
            vx[i] = get_value(10/tx*(tx/2+coordo_xy[i, 0]), 10/tx*(tx/2+coordo_xy[i, 1]), a[:, 0], a[:, 1], a[:, 5])
            vy[i] = get_value(10/tx*(tx/2+coordo_xy[i, 0]), 10/tx*(tx/2+coordo_xy[i, 1]), a[:, 0], a[:, 1], a[:, 6])
        v = np.vstack((vx, vy)).T.flatten()
        f_v = Function(V_pr)
        f_v.vector()[:] = v
        f_rho = Function(Vs_pr)
        f_rho.vector()[:] = rho
        u_0 = project(f_v, V)
        p_0 = project(f_rho, Vs)
    elif FROM_SOLU:
        p = Function(Vs)
        p.vector()[:] = np.loadtxt('./soluce_ini_p.txt')
        u.vector()[:] = np.loadtxt('./soluce_ini_v.txt').flatten()
        p_0 = interpolate(p, W.sub(1).collapse())
        u_0 = interpolate(u, W.sub(0).collapse())
        r = 2
        u_in = Expression(('r*(rand()-0.5)', 'r*(rand()-0.5)'), degree=DEG, r=r)
        u_0 = interpolate(u_in, W.sub(0).collapse())
        rho_0 = Constant(RHO_0)
        p_in = Expression('rho_0', degree=0, rho_0=rho_0)
        p_0 = interpolate(p_in, W.sub(1).collapse())
    # Declare functions
    w = Function(W)
    w_1 = Function(W)
    assign(w, [u_0, p_0])
    assign(w_1, [u_0, p_0])
    w_t = TestFunction(W)
    (u, p) = split(w)
    (u_1, p_1) = split(w_1)
    (v, q) = split(w_t)
    # Declare constants
    if not (CL_P):
        mur_g = f"near(x[0],-{SIZE/2})"
        mur_d = f"near(x[0],{SIZE/2})"
        mur_b = f"near(x[1],-{SIZE/2})"
        mur_h = f"near(x[1],{SIZE/2})"
        bcu_b = DirichletBC(W.sub(0), Constant((1, 0)), mur_b)
        bcu_d = DirichletBC(W.sub(0), Constant((0, 1)), mur_d)
        bcu_h = DirichletBC(W.sub(0), Constant((-1, 0)), mur_h)
        bcu_g = DirichletBC(W.sub(0), Constant((0, -1)), mur_g)
        bcu = [bcu_d, bcu_b, bcu_g, bcu_h]
        bcu_d = DirichletBC(W.sub(1), RHO_0, mur_d)
        bcu_g = DirichletBC(W.sub(1), RHO_0, mur_g)
        bcu_h = DirichletBC(W.sub(1), RHO_0, mur_h)
        bcu_b = DirichletBC(W.sub(1), RHO_0, mur_b)
        bcu += [bcu_d, bcu_b, bcu_g, bcu_h]
    Dt = Constant(DT)
    # Declare the form
        plotfigure = False
        try:
            if CL_P:
                solve(F == 0, w)
            break
        assign(w_1, w)
        try:
            p_ana = project(w[2], Vs)
            u_ana = project(as_vector([w[0], w[1]]), V)
            if i%NB_IM == 0:
                plotfigure = True
                fig_defaut(u_ana, p_ana, ifig=i, plotfigure=plotfigure, nom=NOM)
        except:
            print("not plotted")
        if i%NB_SOL == 0:
            np.savetxt(f"./Solutions/soluce_v_{i+1:05}.txt", np.reshape(np.array(u_ana.vector()), (-1, 2)))
            np.savetxt(f"./Solutions/soluce_p_{i+1:05}.txt", p_ana.vector()[:])
I am not sure to have understood … Are you saying that I have to take like degree 1 elements for the density? Will it be consistent?
I will try but it has always been stable with Dirichlet BCs…
First, let me apologize for the bad quality of my former post, it was not very clear…
So here I come with a simpler issue.
I simplified my equation till obtaining only diffusion on the density which is now:
\partial_t {\bf v}=0
\partial_t \rho=D\Delta\rho
I chose a gaussian as my initial condition and all I want is periodic boundary conditions.
I obtain the periodicity on the edges but not on the corners. This creates some unwanted behaviours…
I try to change the belonging of the corners between the target domain and the source domain…
I also tried to give conditions of the corners on y instead of x…
Until now, nothing that I tried worked so I am asking for help, and maybe it’s just a little mistake from me.
Here is a sample of my code pastable, which plot the solution:
    if plotfigure:
        plot(p, alpha=0.3)
        axes = plt.gca()
        plt.close()
    # Left and bottom without edges is the target domain
        return bool((near(x[0], -SIZE/2) or near(x[1], -SIZE/2)) and
                (not ((near(x[0], -SIZE/2) and near(x[1], SIZE/2)) or
                        (near(x[0], SIZE/2) and near(x[1], -SIZE/2)))) and on_boundary)
    # # Map top and right to left and bottom
        if near(x[0], SIZE/2) and near(x[1], SIZE/2):
            y[0] = x[0] - SIZE
            y[1] = x[1] - SIZE
            y[0] = x[0] - SIZE
            y[1] = x[1]
        elif near(x[1], SIZE/2):
            y[0] = x[0]
            y[1] = x[1] - SIZE
            raise NotImplementedError
    SIZE = 5
    DX = 0.09
    DT = 1e-2  # pas de temps
    LAMBDA = 0.7
    RHO_0 = 0.1
    FAC_D_RHO = 1
    NUM_STEP = 100
    NB_IM = 10
    NOM = 'TT_'
    # Define the mesh
    tx = SIZE
    ty = tx
    nbx = N
    nby = nbx
    TH = V1*V2
    u_in = Expression(('1', '1'), degree=0)
    p_in = Expression('rho_0*exp(-4*(x[0]-1.5)*(x[0]-1.5)-4*(x[1]-1.5)*(x[1]-1.5))', degree=DEG, rho_0=rho_0)
    # Declare functions
    w = Function(W)
    w_1 = Function(W)
    (u, p) = split(w)
    (v, q) = split(w_t)
    # Declare constants
    D2 = Constant(1)
    Dt=Constant(DT)
    # Declare the form
    F = dot((u-u_1), v)*dx \
        +((p-p_1)/Dt*q+D2*dot(grad(p), grad(q)))*dx \
        plotfigure = False
        try:
            solve(F == 0, w)
            break
        assign(w_1, w)
        try:
            if i%NB_IM == 0:
                plotfigure = True
        except:
Thanks in advance!
Ok, so it was kind of a monologue… But I may found the solution but I have no idea why this works…:sweat_smile:
Here is the code that works:
    if plotfigure:
        plot(p, alpha=0.3)
        axes = plt.gca()
        plt.close()
            y[0] = x[0] - SIZE
            y[1] = x[1] - SIZE
            y[0] = x[0] - SIZE
            y[1] = x[1]
            y[0] = x[0]
            y[1] = x[1] - SIZE
    SIZE = 5
    DX = 0.09
    LAMBDA = 0.7
    RHO_0 = 0.1
    FAC_D_RHO = 1
    DEG = 2  # degré des éléments
    NUM_STEP = 100
    NB_IM = 10
    NOM = 'TT_deg1_'
    # Define the mesh
    tx = SIZE
    ty = tx
    nbx = N
    nby = nbx
    TH = V1*V2
    # Declare functions
    w = Function(W)
    w_1 = Function(W)
    (u, p) = split(w)
    (v, q) = split(w_t)
    # Declare constants
    D2 = Constant(1)
    Dt=Constant(DT)
    # Declare the form
        plotfigure = False
        try:
            solve(F == 0, w)
            break
        assign(w_1, w)
        try:
            if i%NB_IM == 0:
                plotfigure = True
        except:
The only thing I have done is changing the degree of the elements from 1 to 2.
And I obtain that: (which is perfect)
So, I’m gonna close this topic but if you have any idea why this works, please let me knwo.
Kind regard.
