Hello all, another noobie question I am sorry. I had a question about setting boundary conditions when I import a mesh file. I am using Fenics 2019.1.
In the SOLVING PDES IN PYTHON book p. 23, the authors indicate that a user should specify a boundary function, to indicate whether some coordinate is on or off the boundary. The boundary function then goes in the arguments for the DirichletBC function. That boundary function
can be very simple like:
def boundary(x, on_boundary):
return on_boundary
Now, I was watching a video tutorial for using Meshes in Fenics, and in that presenter’s code he imports the mesh but does not use a boundary function when setting the DirichletBC. In this case, he is showing the transient heat equation on a mesh. The code for that tutorial is below–taken from the linked source.
My question is, should there be a boundary function in the code below? I am not clear on what the rule is. Like if there is a mesh, then should I never include a boundary function? Or if there is a mesh, then the boundary function is optional, and it should look like …" Is there some specific form for the boundary function when using a mesh? That is my basic question.
t_end = 10.0
dt = 0.1
k = 300
u_in = 20
u_out = -20
xml_file = "helix.xml"
mesh = Mesh(xml_file)
fd = MeshFunction('size_t', mesh, "helix_facet_region.xml");
bc1 = DirichletBC(V, Constant(u_in), fd, 3)
bc2 = DirichletBC(V, Constant(u_out), fd, 2)
bc = [bc1, bc2]
u_n = Function(V)
F = u*v*dx + dt*k*dot(grad(u), grad(v))*dx - u_n*v*dx
a, L = lhs(F), rhs(F)
t = 0
vtkfile = File('output/output.pvd')
num_steps = int(t_end/dt)
for n in range(num_steps):
solve(a == L, u, bc)
u_n.assign(u)
vtkfile << (u, t)
Again the question is, is it good practice to include a boundary function when specifying a DirichletBC with a mesh? If yes, then what would that boundary function look like?
Thanks.
