To store my solution, I’m using the write_checkpoint method in XDMFFile(). I really like that I can read the same file easily in both FEniCS and ParaView. However, when I set the parameter rewrite_function_mesh to False it still writes the mesh for each function. Here is a MWE with FEniCs 2018.1.0, installed with conda:
import dolfin as df
mesh = df.UnitCubeMesh(5, 5, 5)
f = XDMFFile(MPI.comm_world, "test.xdmf")
f.parameters["rewrite_function_mesh"] = False
for i in range(2):
f.write_checkpoint(u, "velocity", i, append=True)
f.close()
Given the above code the content of test.xdmf will be the following:
<?xml version="1.0"?>
<Xdmf Version="3.0">
<Domain>
<Grid GridType="Collection" CollectionType="Temporal" Name="velocity">
<Grid Name="velocity_0" GridType="Uniform">
<Topology NumberOfElements="750" TopologyType="Tetrahedron" NodesPerElement="4">
<DataItem Dimensions="750 4" NumberType="UInt" Format="HDF">test.h5:velocity/velocity_0/mesh/topology</DataItem>
</Topology>
<Geometry GeometryType="XYZ">
<DataItem Dimensions="216 3" Format="HDF">test.h5:velocity/velocity_0/mesh/geometry</DataItem>
</Geometry>
<Time Value="0.000000" />
<Attribute ItemType="FiniteElementFunction" ElementFamily="CG" ElementDegree="1" ElementCell="tetrahedron" Name="velocity" Center="Other" AttributeType="Scalar">
<DataItem Dimensions="3000 1" NumberType="UInt" Format="HDF">test.h5:velocity/velocity_0/cell_dofs</DataItem>
<DataItem Dimensions="216 1" NumberType="Float" Format="HDF">test.h5:velocity/velocity_0/vector</DataItem>
<DataItem Dimensions="751 1" NumberType="UInt" Format="HDF">test.h5:velocity/velocity_0/x_cell_dofs</DataItem>
<DataItem Dimensions="750 1" NumberType="UInt" Format="HDF">test.h5:velocity/velocity_0/cells</DataItem>
</Attribute>
</Grid>
<Grid Name="velocity_1" GridType="Uniform">
<DataItem Dimensions="750 4" NumberType="UInt" Format="HDF">test.h5:velocity/velocity_1/mesh/topology</DataItem>
</Topology>
<DataItem Dimensions="216 3" Format="HDF">test.h5:velocity/velocity_1/mesh/geometry</DataItem>
</Geometry>
<Time Value="1.000000" />
<DataItem Dimensions="3000 1" NumberType="UInt" Format="HDF">test.h5:velocity/velocity_1/cell_dofs</DataItem>
<DataItem Dimensions="216 1" NumberType="Float" Format="HDF">test.h5:velocity/velocity_1/vector</DataItem>
<DataItem Dimensions="751 1" NumberType="UInt" Format="HDF">test.h5:velocity/velocity_1/x_cell_dofs</DataItem>
<DataItem Dimensions="750 1" NumberType="UInt" Format="HDF">test.h5:velocity/velocity_1/cells</DataItem>
</Attribute>
</Grid>
</Grid>
</Domain>
</Xdmf>
However, if I change velocity_1 to velocity_0 in the test.xdmf for the mesh, cell_dofs, x_cell_dofs, and cells, it will still be read correctly into both ParaView and FEniCS.
I’m wondering if there is something I’m missing here, or if this is a bug?
