Read mesh from XDMF file (write_checkpoint)
Hi all,
I want to read a mesh from a output xdmf file as follow:
mesh = UnitSquareMesh(10, 10)
XDMFFile("out.xdmf").write_checkpoint(u, "u", 0)
mesh2 = Mesh()
XDMFFile("out.xdmf").read(mesh2)
but this yields the following error:
  File "plot.py", line 10, in <module>
RuntimeError:
*** Error:   Unable to recognise cell type.
*** Reason:  Unknown value "".
*** Where:   This error was encountered inside XDMFFile.cpp.
*** Process: 0
*** DOLFIN version: 2019.1.0
*** Git changeset:  74d7efe1e84d65e9433fd96c50f1d278fa3e3f3f
any idea how to read a mesh from a xdmf file created with write_checkpoint ?
Cheers
Rem
Hi, I think to read the xdmf, you can refer to this post
https://fenicsproject.org/qa/11348/read-in-mesh-and-functins-from-xdmf-file/
run the following
mesh = Mesh()
filename = “mesh.xdmf”
f = XDMFFile(mpi_comm_world(), filename)
f.read(mesh, True)
plot(mesh)
To use read, you need to use write. However, you can combine the two as follows:
u.vector()[:] = 2
with XDMFFile("out.xdmf") as outfile:
    outfile.write(mesh)
    outfile.write_checkpoint(u, "u", 0, append=True)
mesh2 = Mesh()
u2 = Function(V)
with XDMFFile("out.xdmf") as infile:
    infile.read(mesh2)
    infile.read_checkpoint(u2, "u")
print(u2.vector().get_local())
print(mesh.num_cells(), mesh2.num_cells())
Hi dokken!
I am using XDMFFile in c++ program, such as
  XDMFFile f0("f0.xdmf");
  for (std::size_t n = 0; n < N; n++)
    double t = n*dt;
    f0.write(*u, t);
  f0.close();
If N is too large and we terminate the program before f0.close();, how to show intermediate results in paraview?
I would then rather re-open and append to the file inside the loop to avoid issues with random shut-downs.
Setting a parameter can solve this problem:
f0.parameters["flush_output"] = true;
It might be also effective in python.
Hi, if I write the results at the end of the simulation with multi cpus, using
    outfile.write(mesh)
then I tried read it back in a serial way, and using plot(u) to visualize the results with:
mesh2 = Mesh()
infile=XDMFFile("out.xdmf")
infile.read(mesh2)
VV=FunctionSpace(mesh2,'CG','1')
u2 = Function(VV)
plot(u2)
it does not work. is there anyway to solve it?
Without a reproducible example its hard to give you any guidance.
Please create:
  1. A simple write to file script that can be executed with a given number of processes
  2. A simple read from file script that should be executed in serial and reproduces the error/issue
where and what is the failure?
