Using fenicsx 2:0.5.0.1
I took the function test_cell_h_prism() from https://github.com/FEniCS/dolfinx/blob/main/python/test/unit/mesh/test_mesh.py
to create the MWE below
from dolfinx.mesh import (CellType, create_unit_cube,)
def test_cell_h_prism():
N = 3
mesh = create_unit_cube(MPI.COMM_WORLD, N, N, N, CellType.tetrahedron)
tdim = mesh.topology.dim
num_cells = mesh.topology.index_map(tdim).size_local
cells = np.arange(num_cells, dtype=np.int32)
h = _cpp.mesh.h(mesh, tdim, cells)
assert np.allclose(h, np.sqrt(2 / (N**2)))
test_cell_h_prism()
but it yields the following error message
File "/home/bruno/Documents/Fenics/Heat_Spreading/test_h.py", line 17, in <module>
test_cell_h_prism()
File "/home/bruno/Documents/Fenics/Heat_Spreading/test_h.py", line 14, in test_cell_h_prism
TypeError: h(): incompatible function arguments. The following argument types are supported:
1. (mesh: dolfinx::mesh::Mesh, dim: int, entities: numpy.ndarray[numpy.int32]) -> numpy.ndarray[numpy.float64]
Invoked with: <dolfinx.mesh.Mesh object at 0x7f79f4786d50>, 3, array([ 0, 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12,
13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25,
26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38,
39, 40, 41, 42, 43, 44, 45, 46, 47, 48, 49, 50, 51,
52, 53, 54, 55, 56, 57, 58, 59, 60, 61, 62, 63, 64,
65, 66, 67, 68, 69, 70, 71, 72, 73, 74, 75, 76, 77,
78, 79, 80, 81, 82, 83, 84, 85, 86, 87, 88, 89, 90,
91, 92, 93, 94, 95, 96, 97, 98, 99, 100, 101, 102, 103,
104, 105, 106, 107, 108, 109, 110, 111, 112, 113, 114, 115, 116,
117, 118, 119, 120, 121, 122, 123, 124, 125, 126, 127, 128, 129,
130, 131, 132, 133, 134, 135, 136, 137, 138, 139, 140, 141, 142,
143, 144, 145, 146, 147, 148, 149, 150, 151, 152, 153, 154, 155,
156, 157, 158, 159, 160, 161], dtype=int32)
Has something changed in the h()function?
