Minimum element size hmin | FEniCSx 0.7.2
Hello everyone,
I recently upgraded from FEniCSx version 0.6.0 to 0.7.2. Now I get an error message when determining the minimum element size hmin, which I can’t fix myself.
Here is my code as it worked before:
mesh = dolfinx.mesh.create_unit_square(MPI.COMM_WORLD, 50, 50)
tdim = mesh.topology.dim
num_cells = mesh.topology.index_map(tdim).size_local
hmin = mesh.comm.allreduce(min(dolfinx.cpp.mesh.h(mesh, tdim, range(num_cells))), op=MPI.MIN)
I get the following error message:
  File "/root/shared/Thesis/Fenicsx/3Dcube-8Incls+14Pores/Dry/Monotonic/Battery/MWE_hmin.py", line 11, in <module>
TypeError: h(): incompatible function arguments. The following argument types are supported:
    1. (mesh: dolfinx.cpp.mesh.Mesh_float32, dim: int, entities: numpy.ndarray[numpy.int32]) -> numpy.ndarray[numpy.float32]
    2. (mesh: dolfinx.cpp.mesh.Mesh_float64, dim: int, entities: numpy.ndarray[numpy.int32]) -> numpy.ndarray[numpy.float64]
Invoked with: <dolfinx.mesh.Mesh object at 0x7fb98c292260>, 2, range(0, 5000)
FEniCSX: 0.7.2 (installed via docker-container)
Ubuntu: 22.04
Thank you in advance and have a nice weekend!
With kind regards
Dejan
Can you double check the dolfinx version with
python3 -c 'import dolfinx; print(dolfinx.__version__)'
My suspicion is that you pulled the nightly docker tag, rather than the stable, and thus you have the development version.
If you are indeed on 0.7.2, try with
mesh.h(tdim, range(num_cells))
If you are the nightly tag try instead
mesh.h(tdim, np.arange(num_cells))
where mesh is the actual mesh object (not dolfinx.mesh or dolfinx.cpp.mesh).
I have checked my version as you suggested and it is version 0.7.2.
Your solution for this version works perfectly! Thank you for the quick response.
