Dolfinx: Mesh refinement
The posted fixed example by @dokken no longer works, because the dolfinx API has changed.
The following code works with newer dolfinx versions (was tested with dolfinx 0.5.1)
import pyvista
from dolfinx.mesh import CellType, create_rectangle, locate_entities, refine
from dolfinx.plot import create_vtk_mesh
W = 380e-6  # width
H = 180e-6  # height
d_ele = 20e-6
delta = 1e-6
n_W = int(np.ceil(W / d_ele))  # number of elements along W
n_H = int(np.ceil(H / d_ele))  # number of elements along H
# Create mesh
mesh = create_rectangle(
    MPI.COMM_WORLD,
    points=((-W / 2, -H / 2), (W / 2, H / 2)),
    n=(n_W, n_H),
    cell_type=CellType.triangle,
def inside_delta(xs):
    # refine around the boundary
    return np.logical_or(
        W / 2 - abs(xs[0, :]) <= 30 * delta,
        H / 2 - abs(xs[1, :]) <= 30 * delta,
for _ in np.arange(5):
    dim = mesh.topology.dim
    edges = locate_entities(mesh, dim - 1, inside_delta)
    mesh.topology.create_entities(1)
    mesh = refine(mesh, edges, redistribute=False)
    vtkdata = create_vtk_mesh(mesh, mesh.topology.dim)
    plotter = pyvista.Plotter()
    grid = pyvista.UnstructuredGrid(*vtkdata)
    actor = plotter.add_mesh(grid, show_edges=True)
    plotter.view_xy()
    plotter.show()
and it generates plots of the refined mesh
