Hello dolfinx users,
This question is related to this topic as well as that one elsewhere on the forum. It relates to adaptative mesh refinement in dolfinx.
Apparently the issue will be solved with a simple interpolate for lucky users of version 0.6 onwards, but I’d like not to wait until then.
Consider the following code, adapted from the Non-linear Poisson example :
from petsc4py import PETSc as pet
from dolfinx import mesh, io, fem, nls, log, geometry
# Non linear Poisson
def q(u): return 1 + u**2
domain = mesh.create_unit_square(MPI.COMM_WORLD, 10, 10)
p0 = domain.comm.rank == 0
u_ufl = 1 + x[0] + 2*x[1]
f = - ufl.div(q(u_ufl)*ufl.grad(u_ufl))
u_exact = lambda x: eval(str(u_ufl))
u_D = fem.Function(V)
u_D.interpolate(u_exact)
boundary_facets = mesh.locate_entities_boundary(domain, fdim, lambda x: np.full(x.shape[1], True, dtype=bool))
bc = fem.dirichletbc(u_D, fem.locate_dofs_topological(V, fdim, boundary_facets))
uh = fem.Function(V)
F = q(uh)*ufl.dot(ufl.grad(uh), ufl.grad(v))*ufl.dx - f*v*ufl.dx
problem = fem.petsc.NonlinearProblem(F, uh, bcs=[bc])
solver = nls.petsc.NewtonSolver(MPI.COMM_WORLD, problem)
solver.rtol = 1e-6
solver.report = True
ksp = solver.krylov_solver
opts = pet.Options()
ksp.setFromOptions()
n, converged = solver.solve(uh)
assert(converged)
if p0:print(f"Number of interations: {n:d}")
# Compute L2 error and error at nodes
V_ex = fem.FunctionSpace(domain, ("CG", 2))
u_ex = fem.Function(V_ex)
u_ex.interpolate(u_exact)
error_local = fem.assemble_scalar(fem.form((uh - u_ex)**2 * ufl.dx))
error_L2 = np.sqrt(domain.comm.allreduce(error_local, op=MPI.SUM))
if p0: print(f"L2-error: {error_L2:.2e}")
# Compute values at mesh vertices
error_max = domain.comm.allreduce(np.max(np.abs(uh.x.array -u_D.x.array)), op=MPI.MAX)
if p0: print(f"Error_max: {error_max:.2e}")
with io.XDMFFile(MPI.COMM_WORLD, "test_coarse.xdmf", "w") as xdmf:
xdmf.write_mesh(domain)
xdmf.write_function(uh)
# Adaptative Mesh Refinement
def high_error(x):
x = x.T
# Find cells whose bounding-box collide with the the points
bbtree = geometry.BoundingBoxTree(domain, 2)
cell_candidates = geometry.compute_collisions(bbtree, x)
# Choose one of the cells that contains the point
colliding_cells = geometry.compute_colliding_cells(domain, cell_candidates, x)
cells, points_on_proc = [], []
for i, xp in enumerate(x):
if len(colliding_cells.links(i))>0:
points_on_proc.append(xp)
uh_points = uh.eval( points_on_proc, cells)
u_ex_points = u_ex.eval(points_on_proc, cells)
res_points = (uh_points-u_ex_points)**2
max_res = domain.comm.allreduce(np.max(res_points), op=MPI.MAX)
return res_points>.8*max_res
edges = mesh.locate_entities(domain, domain.topology.dim-1, high_error)
domain.topology.create_entities(1)
# Mesh refinement
domain = mesh.refine(domain, edges, redistribute=False)
def uhf(x):
x = x.T
return uh.eval(points_on_proc, cells)
uh2 = fem.Function(V)
uh2.interpolate(uh)
with io.XDMFFile(MPI.COMM_WORLD, "test_fine.xdmf", "w") as xdmf:
The first part solves a nonlinear Poisson problem using a Newton solver, the second part refines part where the error is above 80% of the maximum then attempts to interpolate the Newton solution back onto the new mesh.
And there I obtain the nefarious :
[3]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation, probably memory access out of range
[3]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
[3]PETSC ERROR: or see https://petsc.org/release/faq/#valgrind
[3]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple MacOS to find memory corruption errors
[3]PETSC ERROR: configure using --with-debugging=yes, recompile, link, and run
[3]PETSC ERROR: to get more information on the crash.
[3]PETSC ERROR: Run with -malloc_debug to check if memory corruption is causing the crash.
Abort(59) on node 3 (rank 3 in comm 0): application called MPI_Abort(MPI_COMM_WORLD, 59) - process 3
My questions are :
- How do I interpolate the solution onto the adapted mesh without waiting for the next version of
dolfinx? I’m kind of dumbfounded thathigh_errorworks as intended butuhffails… - How can I estimate the Newton solver error without a manufactured solution ? My real problem is multi-dimensional and I’m having difficulty computing residual norm at every point.
- Is there a way to pilot the refinement to operate multiple steps at once or will it always cutting base elements in two once ?
