Mesh refinement in dolfinx
Hi everyone,
I need help translating some legacy dolfin code to dolfinx (0.6.0). The code is about marking cells depending on the value of the cell midpoint of function cn1_ and then refine all cells that are marked. This was my approach in legacy dolfin:
cell_markers = MeshFunction("bool", mesh_initial, mesh_initial.topology().dim())
            cell_markers.set_all(False)
            for cell in cells(mesh_initial):
                if cn1_(cell.midpoint()) > 0.01 and cn1_(cell.midpoint()) < 0.99:
                    cell_markers[cell] = True
            mesh = refine(mesh_initial, cell_markers)
any help is greatly appreciated.
Best regards,
Sven
Consider the following code, that avoids loops in Python by using vectorized numpy operations and DOLFINx functions (written in C++)
def cell_criterion(x):
    """Given mesh coordinates, return if each point
    satisfies x[0]<0.3 or x[1]>0.4
    :param x: Input coordinates, shape (num_points, 3)
    :returns: Boolean array of shape (num_points, )
    return (x[0] < 0.3) | (x[1] > 0.4)
# Compute midpoints for all cells on process
cells_local = np.arange(mesh.topology.index_map(
    mesh.topology.dim).size_local, dtype=np.int32)
midpoints = dolfinx.mesh.compute_midpoints(
    mesh, mesh.topology.dim, cells_local).T
# Check midpoint criterion and find edges connected to cells
should_refine = np.flatnonzero(cell_criterion(midpoints)).astype(np.int32)
mesh.topology.create_entities(1)
local_edges = dolfinx.mesh.compute_incident_entities(
    mesh, should_refine, mesh.topology.dim, 1)
refined_mesh = dolfinx.mesh.refine(mesh, local_edges)
with dolfinx.io.XDMFFile(refined_mesh.comm, "refined_mesh.xdmf", "w") as xdmf:
    xdmf.write_mesh(refined_mesh)
giving the mesh
This approach gives the following error in version v.0.8.0:
  File "/root/shared/refinement_dolfinx_test.py", line 27, in <module>
  File "/usr/local/dolfinx-real/lib/python3.10/dist-packages/dolfinx/mesh.py", line 216, in compute_incident_entities
    return _cpp.mesh.compute_incident_entities(topology, entities, d0, d1)
TypeError: compute_incident_entities(): incompatible function arguments. The following argument types are supported:
    1. compute_incident_entities(mesh: dolfinx.cpp.mesh.Topology, entities: ndarray[dtype=int32, writable=False, shape=(*), order='C'], d0: int, d1: int) -> numpy.ndarray[dtype=int32, ]
Invoked with types: dolfinx.mesh.Mesh, ndarray, int, int
Please read the error message carefully, as it was surely giving an hint on how to proceed: the first input argument is a mesh, while it was supposed to be a Topology object. mesh.topology is used all over the place in the code, so a simple guess would have been to replace mesh with mesh.topology.
The updated code is (changes highlighted with my initials FB)
mesh.topology.create_connectivity(mesh.topology.dim, mesh.topology.dim)  # FB: ADDED HERE
    mesh.topology, should_refine, mesh.topology.dim, 1)  # FB: CHANGED HERE
I appreciate the help, thank you!
