Dolfinx-mpc bad_cast
Hi Everyone,
I installed dolfinx and dolfinx_mpc on WSL2 using
sudo apt install python3-dolfinx
sudo apt install python3-dolfinx-mpc
When I try to solve a problem with periodic boundary conditions, the following RuntimeError is raised:
    mpc.create_periodic_constraint_geometrical(V, slave, master, bcs, scale)
  File "/usr/lib/python3/dist-packages/dolfinx_mpc/multipointconstraint.py", line 286, in create_periodic_constraint_geometrical
    mpc_data = dolfinx_mpc.cpp.mpc.create_periodic_constraint_geometrical(
RuntimeError: std::bad_cast
Could this be an installation issue? Or what are my options for debugging this?
Could you provide the full code you are running?
For instance, using docker to emulate your commands:
FROM ubuntu:24.04
RUN apt-get update && apt-get install -y software-properties-common
RUN add-apt-repository ppa:fenics-packages/fenics
RUN apt update && apt install -y python3-pip  python3-dolfinx  python3-dolfinx-mpc  git
WORKDIR /src
RUN git clone --single-branch --branch=v0.9.1 https://github.com/jorgensd/dolfinx_mpc.git
RUN python3 -m pip install pytest --break-system-packages
RUN python3 -m pytest -xvs dolfinx_mpc/python/tests
which I execute with
docker build -t test_dolfinx_mpc -f Dockerfile .
passes
Sorry I forgot to update the post.
Turns out I misinterpreted the indicator and relation variables that have to be supplied to
mpi.create_period_constraint_geometrical()
My bad for not reading the docs well enough.
