Hello everyone,
I am working with a stabilized mixed formulation with displacement and strain fields in FEniCSx, and I would like to project a trial function into its corresponding tensor space. (At the end of this post I’m attaching a minimal test code.)
The issue is that projection only seems to work if I introduce an auxiliary tensor field, but this changes the nature of my trial function (it becomes just a Function instead of remaining a TrialFunction).
On the other hand, if I try to directly obtain the tensor subspace from the mixed problem, it does not behave as expected — the tensor space is automatically converted into a vector space, and I lose the original tensorial structure.
Concretely, after collapsing W.sub(1) (the symmetric tensor component), the resulting space has shape (3,) in 2D (Voigt-like representation), so TestFunction there is a vector, while my strain trial has shape (2,2) — leading to a shape mismatch in ufl.inner.
It is worth mentioning that in FEniCS Legacy, if the subspace of the mixed space was collapsed, this procedure did work as I intended.
Has anyone faced this issue in FEniCSx? Is there a way to project a trial function while keeping its tensorial nature, without having to introduce an auxiliary field? Alternatively, is there a recommended tensor↔Voigt mapping workflow when working with collapsed subspaces?
Any suggestions or experiences would be very helpful!
Thanks in advance.
import basix.ufl
import dolfinx.fem.petsc
def project(v, V):
"""Proyección L2 de una expresión UFL `v` al espacio `V`."""
bcs = []
u = ufl.TrialFunction(V)
w = ufl.TestFunction(V)
a = ufl.inner(u, w)*ufl.dx
L = ufl.inner(v, w)*ufl.dx
problem = dolfinx.fem.petsc.LinearProblem(a, L, bcs=bcs,
petsc_options={"ksp_type": "preonly", "pc_type": "lu"})
return problem.solve()
elem_e = basix.ufl.element("Lagrange", mesh.basix_cell(), 1, shape=(2,2), symmetry=True)
elem_u = basix.ufl.element("Lagrange", mesh.basix_cell(), 1, shape=(2,))
el_mixed = basix.ufl.mixed_element([elem_u, elem_e])
W = dolfinx.fem.functionspace(mesh, el_mixed)
u, eps = ufl.TrialFunctions(W)
v, eta = ufl.TestFunctions(W)
print(ufl.shape(u))
print(ufl.shape(eps))
print(ufl.shape(v))
print(ufl.shape(eta))
wh = dolfinx.fem.Function(W)
uh, epsh = ufl.split(wh)
print(ufl.shape(uh))
print(ufl.shape(epsh))
V0, _ = W.sub(1).collapse()
trial = dolfinx.fem.Function(V0)
print(ufl.shape(trial))
V1 = dolfinx.fem.functionspace(mesh, elem_e)
trial2 = dolfinx.fem.Function(V1)
print(ufl.shape(trial2))
This is what the prints gave:
(2,)
(2, 2)
(2,)
(2, 2)
(2,)
(2, 2)
(3,)
(2, 2)
Now I’m running tests with projections.
V_trial, _ = W.sub(0).collapse()
project(uh, V_trial)
#E_trial, _ = W.sub(1).collapse()
E_trial = dolfinx.fem.functionspace(mesh, elem_e)
project(epsh, E_trial)
The last one produces this error:
ValueError Traceback (most recent call last)
Cell In[8], line 3
1 E_trial, _ = W.sub(1).collapse()
----> 3 project(epsh, E_trial)
Cell In[2], line 29, in project(v, V)
27 w = ufl.TestFunction(V)
28 a = ufl.inner(u, w)*ufl.dx
---> 29 L = ufl.inner(v, w)*ufl.dx
30 problem = dolfinx.fem.petsc.LinearProblem(a, L, bcs=bcs,
31 petsc_options={"ksp_type": "preonly", "pc_type": "lu"})
32 return problem.solve()
File ~/anaconda3/envs/fenicsx0.9/lib/python3.10/site-packages/ufl/operators.py:213, in inner(a, b)
211 if a.ufl_shape == () and b.ufl_shape == ():
212 return a * Conj(b)
--> 213 return Inner(a, b)
File ~/anaconda3/envs/fenicsx0.9/lib/python3.10/site-packages/ufl/tensoralgebra.py:166, in Inner.__new__(cls, a, b)
164 ash, bsh = a.ufl_shape, b.ufl_shape
165 if ash != bsh:
--> 166 raise ValueError(f"Shapes do not match: {ufl_err_str(a)} and {ufl_err_str(b)}")
168 # Simplification
169 if isinstance(a, Zero) or isinstance(b, Zero):
ValueError: Shapes do not match: <ListTensor id=124046807197056> and <Argument id=124046785378048>
