Is this how to project a function onto a vector space in Dolfinx?
I was following this post to figure out how to convert the following code written in Legacy Fenics
D0 = project(Expression("exp(-pow((-x[1]-1.0)/0.1, 2))"), V)
I first saw a link to this showing the process of solving a variational problem which provided the user-defined function for taking care of the variational problem. There was an error in the code running this on Dolfinx 0.9.0 on my end, but I made an update (which I’ve labeled with a comment) and it compiles now
import dolfinx as df
from dolfinx.fem.petsc import apply_lifting, assemble_matrix, assemble_vector, set_bc
def project(e, target_func, bcs=[]):
    """Project UFL expression.
    Note
    This method solves a linear system (using KSP defaults).
    # Ensure we have a mesh and attach to measure
    V = target_func.function_space
    dx = ufl.dx(V.mesh)
    # Define variational problem for projection
    w = ufl.TestFunction(V)
    v = ufl.TrialFunction(V)
    a = df.fem.form(ufl.inner(v, w) * dx)
    L = df.fem.form(ufl.inner(e, w) * dx)
    # Assemble linear system
    A = assemble_matrix(a, bcs)
    b = assemble_vector(L)
    apply_lifting(b, [a], [bcs])
    set_bc(b, bcs)
    # Solve linear system
    solver = PETSc.KSP().create(A.getComm())
    solver.setType("bcgs")
    solver.getPC().setType("bjacobi")
    solver.rtol = 1.0e-05
    solver.setOperators(A)
    solver.solve(b, target_func.x.petsc_vec) # ERROR: Changed from target_func.vector
    assert solver.reason > 0
    target_func.x.scatter_forward()
    # Destroy PETSc linear algebra objects and solver
    solver.destroy()
    A.destroy()
    b.destroy()
mesh = df.mesh.create_unit_square(MPI.COMM_WORLD,8,8) #Mesh is whatever you want it to be, in my use case it was a sphere of radius 1
V = df.fem.functionspace(mesh, ("DG", 1))
f = ufl.exp(-((-x[1]-1)/0.1)**2)
D0 = df.fem.Function(V)
project(f,D0)
Does this look correct for projecting function f on function space V? Also, is there maybe a simpler way to do this?
I would suggest making the projector reusable, as explained in:
which has the code in dropdown:
from typing import Optional
import pyvista
class Projector:
    Projector for a given function.
    Solves Ax=b, where
    .. highlight:: python
    .. code-block:: python
        u, v = ufl.TrialFunction(Space), ufl.TestFunction(space)
        dx = ufl.Measure("dx", metadata=metadata)
        A = inner(u, v) * dx
        b = inner(function, v) * dx(metadata=metadata)
    Args:
        function: UFL expression of function to project
        space: Space to project function into
        petsc_options: Options to pass to PETSc
        jit_options: Options to pass to just in time compiler
        form_compiler_options: Options to pass to the form compiler
        metadata: Data to pass to the integration measure
    _A: PETSc.Mat  # The mass matrix
    _b: PETSc.Vec  # The rhs vector
    _lhs: dolfinx.fem.Form  # The compiled form for the mass matrix
    _ksp: PETSc.KSP  # The PETSc solver
    _x: dolfinx.fem.Function  # The solution vector
    _dx: ufl.Measure  # Integration measure
    def __init__(
        self,
        space: dolfinx.fem.FunctionSpace,
        petsc_options: Optional[dict] = None,
        jit_options: Optional[dict] = None,
        form_compiler_options: Optional[dict] = None,
        metadata: Optional[dict] = None,
        petsc_options = {} if petsc_options is None else petsc_options
        jit_options = {} if jit_options is None else jit_options
        form_compiler_options = {} if form_compiler_options is None else form_compiler_options
        # Assemble projection matrix once
        u = ufl.TrialFunction(space)
        v = ufl.TestFunction(space)
        self._dx = ufl.Measure("dx", domain=space.mesh, metadata=metadata)
        a = ufl.inner(u, v) * self._dx(metadata=metadata)
        self._lhs = dolfinx.fem.form(a, jit_options=jit_options, form_compiler_options=form_compiler_options)
        self._A = dolfinx.fem.petsc.assemble_matrix(self._lhs)
        self._A.assemble()
        # Create vectors to store right hand side and the solution
        self._x = dolfinx.fem.Function(space)
        self._b = dolfinx.fem.Function(space)
        # Create Krylov Subspace solver
        self._ksp = PETSc.KSP().create(space.mesh.comm)
        self._ksp.setOperators(self._A)
        # Set PETSc options
        prefix = f"projector_{id(self)}"
        opts = PETSc.Options()
        opts.prefixPush(prefix)
        for k, v in petsc_options.items():
            opts[k] = v
        opts.prefixPop()
        self._ksp.setFromOptions()
        for opt in opts.getAll().keys():
            del opts[opt]
        # Set matrix and vector PETSc options
        self._A.setOptionsPrefix(prefix)
        self._A.setFromOptions()
        self._b.x.petsc_vec.setOptionsPrefix(prefix)
        self._b.x.petsc_vec.setFromOptions()
    def reassemble_lhs(self):
        dolfinx.fem.petsc.assemble_matrix(self._A, self._lhs)
        self._A.assemble()
    def assemble_rhs(self, h: ufl.core.expr.Expr):
        Assemble the right hand side of the problem
        v = ufl.TestFunction(self._b.function_space)
        rhs = ufl.inner(h, v) * self._dx
        rhs_compiled = dolfinx.fem.form(rhs)
        self._b.x.array[:] = 0.0
        dolfinx.fem.petsc.assemble_vector(self._b.x.petsc_vec, rhs_compiled)
        self._b.x.petsc_vec.ghostUpdate(addv=PETSc.InsertMode.ADD_VALUES, mode=PETSc.ScatterMode.REVERSE)
        self._b.x.petsc_vec.ghostUpdate(addv=PETSc.InsertMode.INSERT_VALUES, mode=PETSc.ScatterMode.FORWARD)
    def project(self, h: ufl.core.expr.Expr) -> dolfinx.fem.Function:
        Compute projection using a PETSc KSP solver
        Args:
            assemble_rhs: Re-assemble RHS and re-apply boundary conditions if true
        self.assemble_rhs(h)
        self._ksp.solve(self._b.x.petsc_vec, self._x.x.petsc_vec)
        return self._x
    def __del__(self):
        self._A.destroy()
        self._ksp.destroy()
Thank you! That answers both questions. I’ve created a separate file .py file with the class inside of it to call when needed so that it can be instantiated from other files for future use. The code you’ve provide works just as well without issue and provides the same results, so it looks like what I had was correct.
