Thank you for your response. I still have a problem,
I carried out these steps:
1-git clone --depth=2 GitHub - spack/spack: A flexible package manager that supports multiple versions, configurations, platforms, and compilers. · GitHub
2-. spack/share/spack/setup-env.sh
3- spack env create fenicsx-env
spack env activate fenicsx-env
4-spack repo add GitHub - FEniCS/spack-fenics: Spack package repository overlay for FEniCS · GitHub
5-spack repo add ``https://github.com/scientificcomputing/spack
6-spack add py-fenics-dolfinx@main+petsc4py ^fenics-dolfinx+adios2 ^petsc+mumps+hypre
7-spack concretize
8-spack install
and I got this error:
inoeqrq fenics-dolfinx@main failed: /tmp/izahed/spack-stage/spack-stage-fenics-dolfinx-main-inoeqrqtrocw5pgqns4ztt7vm5xykldr-2urz53um.log (15s)
– lines 168 to 328 –
/tmp/izahed/spack-stage/spack-stage-fenics-dolfinx-main-inoeqrqtrocw5pgqns4ztt7vm5xykldr/spack-src/cpp/dolfinx/fem/assemble_matrix_impl.h:116:31: error: reference to local binding ‘bs1’ declared in enclosing function ‘dolfinx::fem::impl::assemble_cells_matrix’
for (int k = 0; k < bs1; ++k)
/tmp/izahed/spack-stage/spack-stage-fenics-dolfinx-main-inoeqrqtrocw5pgqns4ztt7vm5xykldr/spack-src/cpp/dolfinx/fem/assemble_matrix_impl.h:85:22: note: ‘bs1’ declared here
const auto [dmap1, bs1, cells1] = dofmap1;
/tmp/izahed/spack-stage/spack-stage-fenics-dolfinx-main-inoeqrqtrocw5pgqns4ztt7vm5xykldr/spack-src/cpp/dolfinx/fem/assemble_matrix_impl.h:118:21: error: reference to local binding ‘bs1’ declared in enclosing function ‘dolfinx::fem::impl::assemble_cells_matrix’
if (bc1[bs1 * dof + k])
/tmp/izahed/spack-stage/spack-stage-fenics-dolfinx-main-inoeqrqtrocw5pgqns4ztt7vm5xykldr/spack-src/cpp/dolfinx/fem/assemble_matrix_impl.h:290:31: error: reference to local binding ‘bs1’ declared in enclosing function ‘dolfinx::fem::impl::assemble_entities’
/tmp/izahed/spack-stage/spack-stage-fenics-dolfinx-main-inoeqrqtrocw5pgqns4ztt7vm5xykldr/spack-src/cpp/dolfinx/fem/assemble_matrix_impl.h:258:22: note: ‘bs1’ declared here
const auto [dmap1, bs1, entities1] = dofmap1;
/tmp/izahed/spack-stage/spack-stage-fenics-dolfinx-main-inoeqrqtrocw5pgqns4ztt7vm5xykldr/spack-src/cpp/dolfinx/fem/assemble_matrix_impl.h:292:21: error: reference to local binding ‘bs1’ declared in enclosing function ‘dolfinx::fem::impl::assemble_entities’
/tmp/izahed/spack-stage/spack-stage-fenics-dolfinx-main-inoeqrqtrocw5pgqns4ztt7vm5xykldr/spack-src/cpp/dolfinx/fem/assemble_matrix_impl.h:498:31: error: reference to local binding ‘bs1’ declared in enclosing function ‘dolfinx::fem::impl::assemble_interior_facets’
/tmp/izahed/spack-stage/spack-stage-fenics-dolfinx-main-inoeqrqtrocw5pgqns4ztt7vm5xykldr/spack-src/cpp/dolfinx/fem/assemble_matrix_impl.h:427:22: note: ‘bs1’ declared here
const auto [dmap1, bs1, facets1] = dofmap1;
/tmp/izahed/spack-stage/spack-stage-fenics-dolfinx-main-inoeqrqtrocw5pgqns4ztt7vm5xykldr/spack-src/cpp/dolfinx/fem/assemble_matrix_impl.h:500:21: error: reference to local binding ‘bs1’ declared in enclosing function ‘dolfinx::fem::impl::assemble_interior_facets’
In file included from /tmp/izahed/spack-stage/spack-stage-fenics-dolfinx-main-inoeqrqtrocw5pgqns4ztt7vm5xykldr/spack-src/cpp/dolfinx/fem/DofMap.cpp:7:
In file included from /tmp/izahed/spack-stage/spack-stage-fenics-dolfinx-main-inoeqrqtrocw5pgqns4ztt7vm5xykldr/spack-src/cpp/dolfinx/fem/DofMap.h:12:
In file included from /tmp/izahed/spack-stage/spack-stage-fenics-dolfinx-main-inoeqrqtrocw5pgqns4ztt7vm5xykldr/spack-src/cpp/dolfinx/fem/ElementDofLayout.h:9:
In file included from /usr/bin/../lib/gcc/x86_64-linux-gnu/11/../../../../include/c++/11/array:40:
In file included from /usr/bin/../lib/gcc/x86_64-linux-gnu/11/../../../../include/c++/11/bits/stl_algobase.h:65:
In file included from /usr/bin/../lib/gcc/x86_64-linux-gnu/11/../../../../include/c++/11/bits/stl_iterator_base_types.h:71:
/usr/bin/../lib/gcc/x86_64-linux-gnu/11/../../../../include/c++/11/bits/iterator_concepts.h:979:13: error: no matching function for call to ‘__begin’
= decltype(ranges::__cust_access::__begin(std::declval<_Tp&>()));
/usr/bin/../lib/gcc/x86_64-linux-gnu/11/../../../../include/c++/11/bits/ranges_base.h:590:5: note: in instantiation of template type alias ‘__range_iter_t’ requested here
using iterator_t = std::__detail::__range_iter_t<_Tp>;
/usr/bin/../lib/gcc/x86_64-linux-gnu/11/../../../../include/c++/11/bits/ranges_util.h:98:43: note: in instantiation of template type alias ‘iterator_t’ requested here
data() requires contiguous_iterator<iterator_t<_Derived>>
/usr/bin/../lib/gcc/x86_64-linux-gnu/11/../../../../include/c++/11/bits/ranges_util.h:203:29: note: in instantiation of template class ‘std::ranges::view_interface<std::ranges::subrange<__gnu_cxx::__normal_iterator<std::array<int, 2> *, std::vector<std::array<int, 2>>>, __gnu_cxx::__normal_iterator<std::array<int, 2> *, std::vector<std::array<int, 2>>>, std::ranges::subrange_kind::sized>>’ requested here
class subrange : public view_interface<subrange<_It, _Sent, _Kind>>
/usr/bin/../lib/gcc/x86_64-linux-gnu/11/../../../../include/c++/11/bits/ranges_algo.h:1179:7: note: in instantiation of template class ‘std::ranges::subrange<__gnu_cxx::__normal_iterator<std::array<int, 2> *, std::vector<std::array<int, 2>>>, __gnu_cxx::__normal_iterator<std::array<int, 2> *, std::vector<std::array<int, 2>>>, std::ranges::subrange_kind::sized>’ requested here
operator()(_Range&& __r, _Comp __comp = {}, _Proj __proj = {}) const
/tmp/izahed/spack-stage/spack-stage-fenics-dolfinx-main-inoeqrqtrocw5pgqns4ztt7vm5xykldr/spack-src/cpp/dolfinx/fem/DirichletBC.h:234:53: note: in instantiation of function template specialization ‘std::ranges::__unique_fn::operator()<std::vector<std::array<int, 2>> &, std::identity, std::ranges::equal_to>’ requested here
auto [unique_end, range_end] = std::ranges::unique(bc_dofs);
/usr/bin/../lib/gcc/x86_64-linux-gnu/11/../../../../include/c++/11/bits/iterator_concepts.h:963:7: note: candidate template ignored: constraints not satisfied [with _Tp = std::ranges::subrange<__gnu_cxx::__normal_iterator<std::array<int, 2> *, std::vector<std::array<int, 2>>>, __gnu_cxx::__normal_iterator<std::array<int, 2> *, std::vector<std::array<int, 2>>>, std::ranges::subrange_kind::sized>]
__begin(_Tp& __t)
/usr/bin/../lib/gcc/x86_64-linux-gnu/11/../../../../include/c++/11/bits/iterator_concepts.h:961:16: note: because ‘is_array_v<std::ranges::subrange<__gnu_cxx::__normal_iterator<std::array<int, 2> *, std::vector<std::array<int, 2> > >, __gnu_cxx::__normal_iterator<std::array<int, 2> *, std::vector<std::array<int, 2> > >, std::ranges::subrange_kind::sized> >’ evaluated to false
requires is_array_v<_Tp> || __member_begin<_Tp&> || __adl_begin<_Tp&>
/usr/bin/../lib/gcc/x86_64-linux-gnu/11/../../../../include/c++/11/bits/iterator_concepts.h:961:35: note: and ‘std::ranges::subrange<__gnu_cxx::__normal_iterator<std::array<int, 2> *, std::vector<std::array<int, 2>>>, __gnu_cxx::__normal_iterator<std::array<int, 2> *, std::vector<std::array<int, 2>>>, std::ranges::subrange_kind::sized> &’ does not satisfy ‘__member_begin’
/usr/bin/../lib/gcc/x86_64-linux-gnu/11/../../../../include/c++/11/bits/iterator_concepts.h:944:23: note: because ‘__decay_copy(__t.begin())’ would be invalid: no member named ‘begin’ in ‘std::ranges::subrange<__gnu_cxx::__normal_iterator<std::array<int, 2> *, std::vector<std::array<int, 2>>>, __gnu_cxx::__normal_iterator<std::array<int, 2> *, std::vector<std::array<int, 2>>>, std::ranges::subrange_kind::sized>’
{ __decay_copy(__t.begin()) } → input_or_output_iterator;
/usr/bin/../lib/gcc/x86_64-linux-gnu/11/../../../../include/c++/11/bits/iterator_concepts.h:961:59: note: and ‘std::ranges::subrange<__gnu_cxx::__normal_iterator<std::array<int, 2> *, std::vector<std::array<int, 2>>>, __gnu_cxx::__normal_iterator<std::array<int, 2> *, std::vector<std::array<int, 2>>>, std::ranges::subrange_kind::sized> &’ does not satisfy ‘__adl_begin’
/usr/bin/../lib/gcc/x86_64-linux-gnu/11/../../../../include/c++/11/bits/iterator_concepts.h:955:19: note: because ‘__decay_copy(begin(__t))’ would be invalid: call to deleted function ‘begin’
{ __decay_copy(begin(__t)) } → input_or_output_iterator;
/usr/bin/../lib/gcc/x86_64-linux-gnu/11/../../../../include/c++/11/bits/iterator_concepts.h:979:13: error: no matching function for call to ‘__begin’“
