Error: fenics-dolfinx requires GCC-9 or newer for improved C++17 support but gcc version 10.2.1 in my system
I am trying to install it on cluster by spack, but I met this error after spack install. This is the output of gcc -v:
Using built-in specs.
COLLECT_GCC=gcc
COLLECT_LTO_WRAPPER=/opt/rh/devtoolset-10/root/usr/libexec/gcc/x86_64-redhat-linux/10/lto-wrapper
Target: x86_64-redhat-linux
Configured with: …/configure --enable-bootstrap --enable-languages=c,c++,fortran,lto --prefix=/opt/rh/devtoolset-10/root/usr --mandir=/opt/rh/devtoolset-10/root/usr/share/man --infodir=/opt/rh/devtoolset-10/root/usr/share/info --with-bugurl=http://bugzilla.redhat.com/bugzilla --enable-shared --enable-threads=posix --enable-checking=release --enable-multilib --with-system-zlib --enable-__cxa_atexit --disable-libunwind-exceptions --enable-gnu-unique-object --enable-linker-build-id --with-gcc-major-version-only --with-linker-hash-style=gnu --with-default-libstdcxx-abi=gcc4-compatible --enable-plugin --enable-initfini-array --with-isl=/builddir/build/BUILD/gcc-10.2.1-20210130/obj-x86_64-redhat-linux/isl-install --disable-libmpx --enable-gnu-indirect-function --with-tune=generic --with-arch_32=x86-64 --build=x86_64-redhat-linux
Thread model: posix
Supported LTO compression algorithms: zlib
gcc version 10.2.1 20210130 (Red Hat 10.2.1-11) (GCC).
What should I do to install it.
Could you post the full error message/output from spack as well, using 3x` encapsulation
this is the full output
[root@localhost jzz]# spack install
==> Error: fenics-dolfinx requires GCC-9 or newer for improved C++17 support
Could you show all commands that you have executed (i.e. Spack install etc.)
Also, what is the output of spack concretize?
I follow the guide on github step by step,here are the commands:
git clone https://github.com/spack/spack.git
. ./spack/share/spack/setup-env.sh
spack env create fenicsx-env
spack env activate fenicsx-env
spack add py-fenics-dolfinx cflags="-O3" fflags="-O3"
spack install
And the output of spack concretize is the same error:
[root@localhost jzz]# spack concretize
Could you call spack compiler find
and then
spack add py-fenics-dolfinx%gcc cflags="-O3" fflags="-O3"
You could also check
spack compiler list
Additional to @dokken’s comment here, if your system does not have a sufficient C/C++ compiler you can request spack to install the latest. Something along the lines of
spack install gcc
spack compiler find
then you can specify the compiler you want to use.
thank you for your help , but I meet another problem while installing:
[+] /home/jzz/spack/opt/spack/linux-centos7-skylake/gcc-10.2.1/py-petsc4py-3.18.2-mq3mkwgd2kl6u6nw32q7kyiqgmojekbj
==> Error: py-fenics-dolfinx-0.5.1-a3h3ikqpizu6fafkg7qaxhe4rxjckthe: Package was not installed
==> Updating view at /home/jzz/spack/var/spack/environments/fenicsx-env/.spack-env/view
==> Error: Installation request failed.  Refer to reported errors for failing package(s).
what should I do
It is unclear what instructions you have followed(both me and nate gave some suggestions) and if you made a new spack environment before executing any of the commands above.
I use spack compiler find and spack add py-fenics-dolfinx%gcc cflags="-O3" fflags="-O3" in the previous spack environment.
Try making a new spack env, and add all the instructions + all of the output in a reply.
These are all the commands:
spack install
And these are the full error information:
==> Installing intel-tbb-2021.7.0-na7fhxqgmydjud6qn3uxpm2mzk6pp4kz
==> intel-tbb exists in binary cache but with different hash
==> No binary for intel-tbb-2021.7.0-na7fhxqgmydjud6qn3uxpm2mzk6pp4kz found: installing from source
==> Using cached archive: /home/jzz/spack/var/spack/cache/_source-cache/archive/2c/2cae2a80cda7d45dc7c072e4295c675fff5ad8316691f26f40539f7e7e54c0cc.tar.gz
==> No patches needed for intel-tbb
==> intel-tbb: Executing phase: 'cmake'
==> intel-tbb: Executing phase: 'build'
==> Error: ProcessError: Command exited with status 2:
    'make' '-j1'
4 errors found in build log:
     257                     from /tmp/root/spack-stage/jzz/spack-stage-i
            ntel-tbb-2021.7.0-na7fhxqgmydjud6qn3uxpm2mzk6pp4kz/spack-src/
            src/tbb/../../include/tbb/../oneapi/tbb/concurrent_unordered_
            map.h:21,
     258                     from /tmp/root/spack-stage/jzz/spack-stage-i
            src/tbb/../../include/tbb/concurrent_unordered_map.h:17,
     259                     from /tmp/root/spack-stage/jzz/spack-stage-i
            test/tbb/test_concurrent_unordered_map.cpp:22:
     260    /opt/rh/devtoolset-10/root/usr/include/c++/10/bits/basic_stri
            ng.h: In instantiation of 'class std::basic_string<char, std:
            :char_traits<char>, tbb::detail::d1::tbb_allocator<char> >':
     261    /tmp/root/spack-stage/jzz/spack-stage-intel-tbb-2021.7.0-na7f
            hxqgmydjud6qn3uxpm2mzk6pp4kz/spack-src/test/common/concurrent
            _associative_common.h:964:29:   required from 'void test_map_
            specific_types() [with Checker = UnorderedMapTypesTester]'
     262    /tmp/root/spack-stage/jzz/spack-stage-intel-tbb-2021.7.0-na7f
            hxqgmydjud6qn3uxpm2mzk6pp4kz/spack-src/test/tbb/test_concurre
            nt_unordered_map.cpp:97:54:   required from here
  >> 263    /opt/rh/devtoolset-10/root/usr/include/c++/10/bits/basic_stri
            ng.h:3150:57: error: no type named 'size_type' in 'std::basic
            _string<char, std::char_traits<char>, tbb::detail::d1::tbb_al
            locator<char> >::_CharT_alloc_type' {aka 'std::allocator_trai
            ts<tbb::detail::d1::tbb_allocator<char> >::rebind_alloc<char>
     264     3150 |       typedef typename _CharT_alloc_type::size_type
               size_type;
     265          |
     266    compilation terminated due to -Wfatal-errors.
  >> 267    make[2]: *** [test/CMakeFiles/test_concurrent_unordered_map.d
            ir/build.make:79: test/CMakeFiles/test_concurrent_unordered_m
            ap.dir/tbb/test_concurrent_unordered_map.cpp.o] Error 1
     268    make[2]: Leaving directory '/tmp/root/spack-stage/jzz/spack-s
            tage-intel-tbb-2021.7.0-na7fhxqgmydjud6qn3uxpm2mzk6pp4kz/spac
            k-build-na7fhxq'
  >> 269    make[1]: *** [CMakeFiles/Makefile2:761: test/CMakeFiles/test_
            concurrent_unordered_map.dir/all] Error 2
     270    make[1]: Leaving directory '/tmp/root/spack-stage/jzz/spack-s
            k-build-na7fhxq'
  >> 271    make: *** [Makefile:169: all] Error 2
See build log for details:
  /tmp/root/spack-stage/jzz/spack-stage-intel-tbb-2021.7.0-na7fhxqgmydjud6qn3uxpm2mzk6pp4kz/spack-build-out.txt
==> Warning: Skipping build of xtensor-0.24.1-4kyqnb5psxilxmgxaxch3sbbte2x2dqw since intel-tbb-2021.7.0-na7fhxqgmydjud6qn3uxpm2mzk6pp4kz failed
==> Warning: Skipping build of py-fenics-dolfinx-0.5.1-a3h3ikqpizu6fafkg7qaxhe4rxjckthe since xtensor-0.24.1-4kyqnb5psxilxmgxaxch3sbbte2x2dqw failed
==> Warning: Skipping build of fenics-dolfinx-0.5.1-mcvoeggdrotril2r5xierzh2324gy6hu since xtensor-0.24.1-4kyqnb5psxilxmgxaxch3sbbte2x2dqw failed
[+] /home/jzz/spack/opt/spack/linux-centos7-skylake/gcc-10.2.1/fenics-basix-0.5.1-wewd5p55fmtcrry3onj7soqrvvb55ezp
[+] /home/jzz/spack/opt/spack/linux-centos7-skylake/gcc-10.2.1/pmix-4.1.2-7evfnj7bupkwpv2n5nwqe4jpqvqfdakg
[+] /home/jzz/spack/opt/spack/linux-centos7-skylake/gcc-10.2.1/ninja-1.11.1-bd62itogvfhpduvrw6wx5zb4uj77odbi
[+] /home/jzz/spack/opt/spack/linux-centos7-skylake/gcc-10.2.1/py-pip-22.2.2-wlmej2nlc6thdrpnkeo33hkum4ma526b
[+] /home/jzz/spack/opt/spack/linux-centos7-skylake/gcc-10.2.1/openssh-9.1p1-et7vcymi45czd5vyizlul6h6ajnip6c3
[+] /home/jzz/spack/opt/spack/linux-centos7-skylake/gcc-10.2.1/py-wheel-0.37.1-2rzwy7vmhvk3urokvqqzw3gdkrh4hpg4
[+] /home/jzz/spack/opt/spack/linux-centos7-skylake/gcc-10.2.1/py-setuptools-63.0.0-ngyw2yvvp42kp5aasu5niqxjmbj3y4pb
[+] /home/jzz/spack/opt/spack/linux-centos7-skylake/gcc-10.2.1/openmpi-4.1.4-beeap2njsxu4ljokqauismz3jtnj2lkg
[+] /home/jzz/spack/opt/spack/linux-centos7-skylake/gcc-10.2.1/py-cython-0.29.32-yl76rjizk23wh6wt4ntj4q42raeus4an
[+] /home/jzz/spack/opt/spack/linux-centos7-skylake/gcc-10.2.1/py-pycparser-2.21-xj5d6jgkxtzi2npn55k5gzhelpstyrdw
[+] /home/jzz/spack/opt/spack/linux-centos7-skylake/gcc-10.2.1/py-pybind11-2.10.1-b7ovu6n25bfq7qivoaj4ho3fife3gxe6
[+] /home/jzz/spack/opt/spack/linux-centos7-skylake/gcc-10.2.1/parmetis-4.0.3-7jkb3njroebv37lcig7x74zuc6ovtjxz
[+] /home/jzz/spack/opt/spack/linux-centos7-skylake/gcc-10.2.1/py-mpi4py-3.1.4-wp4jupxzqlao7ihifecrtgqgwp4xiqbe
[+] /home/jzz/spack/opt/spack/linux-centos7-skylake/gcc-10.2.1/hypre-2.27.0-xe2si7ljbny5mynk6cnn4vodko3h46en
[+] /home/jzz/spack/opt/spack/linux-centos7-skylake/gcc-10.2.1/hdf5-1.12.2-pvegraf7za7v5eim2ojtzy66a34vzo5s
[+] /home/jzz/spack/opt/spack/linux-centos7-skylake/gcc-10.2.1/py-numpy-1.24.0-upor5yuoif63lm3xqqevwcsotqjx5rny
[+] /home/jzz/spack/opt/spack/linux-centos7-skylake/gcc-10.2.1/py-cffi-1.15.1-h7nim5nyzfdknggbcd46vvp6hffkaf2h
[+] /home/jzz/spack/opt/spack/linux-centos7-skylake/gcc-10.2.1/superlu-dist-8.1.2-32xbqn2qdwdg47lwy5qrnvnnjiu54rch
[+] /home/jzz/spack/opt/spack/linux-centos7-skylake/gcc-10.2.1/py-fenics-ufl-2022.2.0-t6hvihpmxrhv73cmdkjqwumpnpprfw76
[+] /home/jzz/spack/opt/spack/linux-centos7-skylake/gcc-10.2.1/py-fenics-basix-0.5.1-77ii2xpm7u66lpzfrm4xqwkxytrwouz4
[+] /home/jzz/spack/opt/spack/linux-centos7-skylake/gcc-10.2.1/petsc-3.18.2-3q62uhdszxk5nmbukxndktgbusgctvn7
==> Waiting for py-fenics-ffcx-0.5.0.post0-k2ei5erjkpb5wr3hbkkl2hhuc3uqaz6[+] /home/jzz/spack/opt/spack/linux-centos7-skylake/gcc-10.2.1/py-fenics-ffcx-0.5.0.post0-k2ei5erjkpb5wr3hbkkl2hhuc3uqaz6e
