Dolfinx version of "Plot unit normal vectors of facets (interior boundary) in a 2D mesh"
Hello, I am new to fenics. I came across this legacy implementation (shown below) in the forum to visualize the normal vector.
I would like to know if there is a way to do this in dolfinx, because I kind of get that “indent_zero()” and " keep_diagonal=True" are no longer available in dolfinx? In general, what I want to do is to visualize the jump quantities on an interior boundary.
mesh = Mesh(UnitDiscMesh.create(MPI.comm_world, 100, 1, 2))
V = VectorFunctionSpace(mesh, "CG", 1)
a = inner(u,v)*ds
l = inner(n, v)*ds
A = assemble(a, keep_diagonal=True)
L = assemble(l)
A.ident_zeros()
nh = Function(V)
solve(A, nh.vector(), L)
File("nh.pvd") << nh
This question has already been answered at:
Here is an updated version to DOLFINx v0.9, which also includes the project step.
import time
import dolfinx.fem.petsc
from dolfinx import cpp, fem
N = 10
degree = 1
mesh = dolfinx.mesh.create_unit_cube(MPI.COMM_WORLD, N, N, N)
V = dolfinx.fem.functionspace(mesh, ("CG", degree,(mesh.geometry.dim,)))
u = ufl.TrialFunction(V)
print(
    f"N={N}, Num dofs global {V.dofmap.index_map.size_global*V.dofmap.index_map_bs}")
# form is defined on the boundary => matrix wil have many zero diagonal entries
a_bnd = ufl.inner(u, v) * ufl.ds
form = fem.form(a_bnd)
# Find all dofs associated to the facets we are integrating over
exterior_facets = dolfinx.mesh.exterior_facet_indices(mesh.topology)
boundary_blocks = dolfinx.fem.locate_dofs_topological(
    V, V.mesh.topology.dim - 1, exterior_facets)
# Set diagonal for everything not associated with a facet in sparsity pattern
imap = V.dofmap.index_map
all_blocks = np.arange(imap.size_local+imap.num_ghosts, dtype=np.int32)
zero_blocks = np.delete(all_blocks, boundary_blocks)
start = time.perf_counter()
sp = fem.create_sparsity_pattern(form)
sp.insert_diagonal(zero_blocks)
sp.finalize()
end = time.perf_counter()
print(f"Create sparsity pattern {end-start}")
A = cpp.la.petsc.create_matrix(mesh.comm, sp)
A.setOption(A.Option.NEW_NONZERO_ALLOCATION_ERR, 1)
fem.petsc.assemble_matrix(A, form)
A.assemble(A.AssemblyType.FLUSH)
print(f"Assemble boundary {end-start}")
def bc_diag(A):
    bc = dolfinx.fem.dirichletbc(
        dolfinx.fem.Constant(mesh, np.zeros(u.ufl_shape, dtype=PETSc.ScalarType)), zero_blocks, V)
    dolfinx.cpp.fem.petsc.insert_diagonal(A, V._cpp_object, [bc._cpp_object], 1.)
    print(f"BC insert diag {end-start}s")
    return bc
bc = bc_diag(A)
print(f"Matrix communication {end-start}")
print(f"min(diag) = {A.getDiagonal().array.min()}")
print(f"number of diagonal zeros = {sum(A.getDiagonal().array == 0)}")
print(f"norm(A) = {A.norm()}")
b = dolfinx.fem.form(ufl.inner(ufl.FacetNormal(mesh), v) * ufl.ds)
b_vec = dolfinx.fem.petsc.assemble_vector(b)
dolfinx.fem.petsc.apply_lifting(b_vec, [form], [[bc]])
b_vec.ghostUpdate(addv=PETSc.InsertMode.ADD_VALUES, mode=PETSc.ScatterMode.REVERSE)
dolfinx.fem.petsc.set_bc(b_vec, [bc])
ksp = PETSc.KSP().create(mesh.comm)
ksp.setOperators(A)
ksp.setType("preonly")
ksp.getPC().setType("lu")
ksp.setErrorIfNotConverged(True)
uh = dolfinx.fem.Function(V)
ksp.solve(b_vec, uh.x.petsc_vec)
ksp.destroy()
b_vec.destroy()
uh.x.scatter_forward()
print(f"CG solve {end-start}s")
with dolfinx.io.VTXWriter(mesh.comm, "normal.bp", [uh]) as writer:
    writer.write(0.0)
Thank you very much, dokken!
Dear dokken,
I tried the method you provided and plotted the normal vector on the interface. I found an issue, but I don’t know what the issue is. Is there a simple way to restrict which direction the normal vector points to, like in the old dolfin:
a = inner(u, v)('+')*dS +  + Constant(0)*inner(u,v)*dx
I saw that you provided a one-sided integral entities solution to circumvent this issue, but I will need to project the jump qunatities u(“+”) - u(“-”) on the normal, so I am not sure if this solution could be used here.
Despite the arbitrary direction, I found that the magnitude is incorrect for a few facets in the adaptation of your previous solution. I’m not sure what went wrong with the ellipse. I tried a circle and got the correct result. I tried the old dolfin version, and the results were correct in both cases. Could you help me with this problem or give me a direction? Thank you! Here is my code:
import time
from ufl import Measure
from dolfinx.io import gmshio
gmsh.model.add("square_with_circle")
occ = gmsh.model.occ
# --- Parameters ---
h = 20
h2 = 0.5  # 1
L_half = 500
minor_axis = 40  # 4
major_axis = 80  # 8
# Ellipse orientation (90° domain)
minor_axis_x = minor_axis
minor_axis_y = 0
major_axis_x = 0
major_axis_y = major_axis
# --- Ellipse-defining points ---
occ.addPoint(minor_axis_x, -minor_axis_y, 0, h2, tag=1)
occ.addPoint(-minor_axis_x, minor_axis_y, 0, h2, tag=2)
occ.addPoint(major_axis_x, major_axis_y, 0, h2, tag=3)
occ.addPoint(-major_axis_x, -major_axis_y, 0, h2, tag=4)
# --- Square corners ---
occ.addPoint(L_half, L_half, 0, h, tag=5)
occ.addPoint(-L_half, L_half, 0, h, tag=6)
occ.addPoint(-L_half, -L_half, 0, h, tag=7)
occ.addPoint(L_half, -L_half, 0, h, tag=8)
# --- Square edges ---
occ.addLine(6, 5, tag=1)  # top
occ.addLine(5, 8, tag=2)  # right
occ.addLine(8, 7, tag=3)  # bottom
occ.addLine(7, 6, tag=4)  # left
# --- Center of ellipse ---
occ.addPoint(0, 0, 0, h, tag=9)
# --- Elliptical arcs ---
occ.addEllipseArc(1, 9, 3, 3, tag=5)  # (p1->p3 via center)
occ.addEllipseArc(3, 9, 3, 2, tag=6)  # (p3->p2)
occ.addEllipseArc(2, 9, 4, 4, tag=7)  # (p2->p4)
occ.addEllipseArc(4, 9, 4, 1, tag=8)  # (p4->p1)
# --- Curve loops ---
outer_loop = occ.addCurveLoop([1, 2, 3, 4], tag=1)  # square
ellipse_loop = occ.addCurveLoop([6, 7, 8, 5], tag=2)  # ellipse (consistent order)
# --- Surfaces ---
# Matrix = square with ellipse inside (like Plane Surface(1) = {1,2,3})
s_matrix = occ.addPlaneSurface([outer_loop, ellipse_loop], tag=1)
# Inclusion = ellipse alone (like Plane Surface(2) = {4})
s_incl = occ.addPlaneSurface([ellipse_loop], tag=2)
occ.synchronize()
# --- Physical groups ---
gmsh.model.addPhysicalGroup(1, [4], tag=1)  # left edge
gmsh.model.addPhysicalGroup(1, [1], tag=2)  # top edge
gmsh.model.addPhysicalGroup(1, [2], tag=3)  # right edge
gmsh.model.addPhysicalGroup(1, [3], tag=4)  # bottom edge
gmsh.model.addPhysicalGroup(1, [8, 5, 6, 7], tag=5)  # ellipse boundary
gmsh.model.addPhysicalGroup(2, [s_matrix], tag=1)  # matrix
gmsh.model.addPhysicalGroup(2, [s_incl], tag=2)  # inclusion
# Optional: add names
gmsh.model.setPhysicalName(2, 1, "Matrix")
gmsh.model.setPhysicalName(2, 2, "Inclusion")
gmsh.model.setPhysicalName(1, 5, "EllipseBoundary")
# --- Mesh ---
gmsh.option.setNumber("Mesh.Algorithm", 6)
gmsh.model.mesh.generate(2)
# gmsh.write("square_with_circle.msh")
model_rank = 0
gdim = 2
mesh, ct, ft = gmshio.model_to_mesh(gmsh.model, MPI.COMM_WORLD, model_rank, gdim)
# # gmsh.fltk.run()  # Uncomment to view GUI
gmsh.finalize()
################# Meshing complete ##################################
################# Projection starts ###################################
res = "-"
degree = 1
V = dolfinx.fem.functionspace(mesh, ("CG", degree, (mesh.geometry.dim,)))
print(f" Num dofs global {V.dofmap.index_map.size_global * V.dofmap.index_map_bs}")
# define integration measures
dS = Measure("dS", domain=mesh, subdomain_data=ft, subdomain_id=5)
a_bnd = ufl.inner(u(res), v(res)) * dS
interface_facets = ft.find(5)
    V, V.mesh.topology.dim - 1, interface_facets
all_blocks = np.arange(imap.size_local + imap.num_ghosts, dtype=np.int32)
sp.finalize()
print(f"Create sparsity pattern {end - start}")
print(f"Assemble boundary {end - start}")
def bc_diag(A):
        zero_blocks,
        V,
    dolfinx.cpp.fem.petsc.insert_diagonal(A, V._cpp_object, [bc._cpp_object], 1.0)
    print(f"BC insert diag {end - start}s")
    return bc
bc = bc_diag(A)
print(f"Matrix communication {end - start}")
normalVec = ufl.FacetNormal(mesh)
b = dolfinx.fem.form(ufl.inner(normalVec(res), v(res)) * dS)
ksp.setOperators(A)
ksp.destroy()
b_vec.destroy()
print(f"CG solve {end - start}s")
with dolfinx.io.VTXWriter(mesh.comm, "normal_ellipse.bp", [uh], engine="BP4") as writer:
    writer.write(0.0)
You need to order the the interior integration entities in a consistent order.
See for instance: Consistent side of interior boundaries with dolfinx - #2 by dokken
If you actually want a one-sided integral (where all data is evaluated on a specific side), see: Add one-sided integration example as example of custom integration · Issue #158 · jorgensd/dolfinx-tutorial · GitHub
Additionally, the code I have at presentations/icosahom/code/emi_primal_mixed.py at 96b425c30e0ba30b4ca75f84dd7d46c475b8638c · jorgensd/presentations · GitHub shows how to orient the + and - restrictions on an interior facet
Thank you very much, drokken, for your help and patience! I tried the integration entities method, and it worked. The magnitude is also correct now,
