Hyperelastic model with two different materials
hii all,
im trying to use the hyperplastic demo code and apply it on a model with 2 different materials and it seems to be failing on the boundary level.
as of now my code consist only the boundary and subdomain definition for the two materials with the material properties definition and it still failing.
any idea why?
import fenics as fe
E, nu = 10.0, 0.3
length, width, height = 1.0, 0.2, 0.2  # Dimensions of the rod
num_elements = 10  # Number of elements along each dimension
mesh = BoxMesh(Point(0, 0, 0), Point(length, width, height), num_elements, 5, 5)
class Omega_0(SubDomain):
        return x[0] <= length/2 + DOLFIN_EPS
class Omega_1(SubDomain):
        return x[0] > length/2 - DOLFIN_EPS
subdomain_0 = Omega_0()
subdomain_1 = Omega_1()
materials = MeshFunction('size_t', mesh, mesh.topology().dim())
materials.set_all(0)
subdomain_0.mark(materials, 1)
subdomain_1.mark(materials, 2)
# Boundary conditions
class left(SubDomain):
        return on_boundary and near(x[0], 0, DOLFIN_EPS)
class right(SubDomain):
        return on_boundary and near(x[0], 1, DOLFIN_EPS)
facets = MeshFunction("size_t", mesh, mesh.topology().dim()-1)
facets.set_all(0)
left().mark(facets, 1)
right().mark(facets, 2)
bc1 = DirichletBC(V.sub(0), Constant(0), facets, 1)
bc2 = DirichletBC(V.sub(1), Constant(0), facets, 1)
bc3 = DirichletBC(V.sub(2), Constant(0), facets, 1)
bc4 = DirichletBC(V.sub(0), Constant(5), facets, 2)
bc5 = DirichletBC(V.sub(1), Constant(5), facets, 2)
bc6 = DirichletBC(V.sub(2), Constant(5), facets, 2)
bcs = [bc1, bc2, bc3, bc4, bc5, bc6]
mu, lmbda = Constant(E/(2*(1 + nu))), Constant(E*nu/((1 + nu)*(1 - 2*nu)))
# Define functions
du = TrialFunction(V)            # Incremental displacement
v = TestFunction(V)             # Test function
u = Function(V)                 # Displacement from previous iteration
B = Constant((0.0, 0.0, 0.0))  # Body force per unit volume
T = Constant((0.0, 0.0, 0.0))  # Traction force on the boundary
# Kinematics
d = len(u)
I = Identity(d)             # Identity tensor
F = I + grad(u)             # Deformation gradient
C = F.T*F                   # Right Cauchy-Green tensor
Ic = tr(C)
J = det(F)
psi = (mu/2)*(Ic - 3) - mu*ln(J) + (lmbda/2)*(ln(J))**2
# Total potential energy
Pi = psi*dx - dot(B, u)*dx - dot(T, u)*ds
# Compute first variation of Pi (directional derivative about u in the direction of v)
F = derivative(Pi, u, v)
# Compute Jacobian of F
J = derivative(F, u, du)
# Solve variational problem
solve(F == 0, u, bcs, J=J)
# Save solution in VTK format
file = File("displacement.pvd");
file << u;
# Plot solution
plot(u)
this is the error
File “/home/mirialex/PycharmProjects/fewmaterials/hyperwithfewmaterials.py”, line 91, in
File “/usr/lib/petsc/lib/python3/dist-packages/dolfin/fem/solving.py”, line 233, in solve
File “/usr/lib/petsc/lib/python3/dist-packages/dolfin/fem/solving.py”, line 314, in _solve_varproblem
solver.solve()
RuntimeError:
*** Error: Unable to solve nonlinear system with NewtonSolver.
*** Reason: Newton solver did not converge because maximum number of iterations reached.
*** Where: This error was encountered inside NewtonSolver.cpp.
*** Process: 0
*** Git changeset: ubuntu
Process finished with exit code 1
Keep in mind that hyperelasticity is a nonlinear problem which you solve with a Newton method which might not always converge. You seem to apply very large displacements on the boundary, first try to apply much lower displacements for improving the convergence behavior.
