Don't understand why this solver is not converging
I based myself on some code I found in a paper. It’s a simulation of a molten polymer extruding through a nozzle. The mesh deforms so I can get the die swell. I added a pressure boundary condition because it is important for my use case to be able to update the pressure during iterations.
The problem is that when I set Newtonian to False, it does not converge. When I remove the pressure it will actually converge. I tried making the mesh more detailed, adding mesh smoothing, initializing the solution to something other than 0’s. Removing the velocity BC or making it constant. Tried different solvers and preconditioners … To no avail.
Anyone can help me? I’d greatly appreciate it. I don’t have a physics background but I’ve tried my best to research.
import sys
import time
import os
import shutil
from math import floor, ceil
parameters['allow_extrapolation'] = True
parameters["form_compiler"]["quadrature_degree"] = 12
parameters['linear_algebra_backend'] = "PETSc"
print('Linear algebra backend:',parameters['linear_algebra_backend'])
# Delete existing folders/files and generate new files
dir_path = os.path.dirname(os.path.realpath(__file__))
fileName = os.path.splitext(__file__)[0]
myfile=("%s.results" % (fileName))
if os.path.exists(myfile):
   shutil.rmtree("%s/%s.results" % (dir_path,fileName), ignore_errors=True)
pfile = File("%s.results/p.pvd" % (fileName))
vfile = File("%s.results/v.pvd" % (fileName))
taufile = File("%s.results/tau.pvd" % (fileName))
mfile = File("%s.results/m.pvd" % (fileName))
ufile = File("%s.results/u.pvd" % (fileName))
# Time step
t = 0.0
dt = .001
TOL = 1E-8
degree = 2
pdegree = 1
# Material parameters
alpha = 1./9.
Wi = 1.05
De = Wi / 3.
Newtonian = True
if Newtonian:
   alpha = 1.
   De = 0.
list_krylov_solver_preconditioners()
# Generate mesh
LH = 1.; LW1=2.; LI=3.; LW2=LI+LW1
mesh = RectangleMesh(Point(0,0), Point(LW2,LH),128,16)
print('Number of nodes: %d, Number of elements: %d'%(mesh.num_vertices(),mesh.num_cells()))
mfile << mesh
# Mixed element
P = FiniteElement("CG", 'triangle', 1)    # Pressure
V = VectorElement("CG", 'triangle', 2)    # Velocity
Tau = TensorElement("CG", 'triangle', 2)  # Extra stress
E = MixedElement([P, V, Tau])
# Elements and space
W = FunctionSpace(mesh,E); w = Function(W)
(p,v,tau) = split(w); (p_,v_,tau_) = TestFunctions(W)
I = Identity(2)
V1 = VectorFunctionSpace(mesh, "CG", 1)
v_tilde = Function(V1)
V2 = VectorFunctionSpace(mesh, "CG", 2)
u = Function(V1); ufinal = Function(V2); uinit = Function(V2)
#tried initializing with non null values to get better conversion, doesn't work
u.vector()[:] = 100.0
uinit.vector()[:] = 100.0
ufinal.vector()[:] = 100.0
# Save initial coordinates of the mesh
coord = Expression(('x[0]','x[1]'), degree=degree)
uinit.assign(interpolate(coord, V2))
# Generate DoF map for mesh
mmap = vertex_to_dof_map(V1)
mmap.resize((int(len(mmap)/2), mesh.geometry().dim()))
# Define boundaries
def top(x, on_boundary):
   return on_boundary and x[1]>LH-TOL and x[0]<LW1+TOL
def bottom(x, on_boundary):
   return on_boundary and x[1]<TOL
def inlet(x, on_boundary):
   return on_boundary and x[0]<TOL
def outlet(x, on_boundary):
   return on_boundary and x[0]>LW2-TOL
def inlet2(x,on_boundary):
   return on_boundary and x[0]>TOL
# Define boundary conditions
bcs = list()
velocity = Expression(('1.5*(1. - x[1]*x[1])*t', '0'), t=t, degree=degree)
#velocity = Expression(('30', '0'), t=t, degree=degree)
p_in = Expression("10000*sin(10000.0*t)", t=0.0,degree=1)#"10000*sin(3.0*t)"
p_in_constant = Expression("50" ,t=0.0,degree=2)
bc_pressure_inlet = DirichletBC(W.sub(0), p_in_constant, inlet2)
bcs.append(bc_pressure_inlet)
bcs.append( DirichletBC(W.sub(1),Constant((0,0)),top) )
bcs.append( DirichletBC(W.sub(1).sub(1),Constant(0),bottom))
bcs.append( DirichletBC(W.sub(1),velocity,inlet) )
bcs.append( DirichletBC(W.sub(1).sub(1),Constant(0),outlet))
# Functions
def Constitutive(v, tau):
   L = grad(v)
   D = (grad(v)+grad(v).T)/2.0
   return tau + De * (dot(v,nabla_grad(tau)) - dot(L,tau) - dot(tau,L.T) ) - 2.*(1.-alpha)*D
def T(p,v,tau):
   return -p*I + 2.*alpha*D + tau
# SUPG Coefficient
def eta(v):
   he=CellDiameter(mesh)
   nb=sqrt(dot(v,v))
   nb=conditional(le(nb,TOL), 1., nb)
   return he/nb
# Problem definition
Fsol = div(v)*p_*dx \
      + inner(T(p,v,tau),grad(v_))*dx \
      + inner(Constitutive(v,tau),tau_)*dx \
      + inner(Constitutive(v,tau),dot(eta(v)*v,nabla_grad(tau_)))*dx
Jsol = derivative(Fsol,w)
problem=NonlinearVariationalProblem(Fsol,w,bcs,Jsol)
solver=NonlinearVariationalSolver(problem)
#solver.parameters['nonlinear_solver'] = 'mumps'
# Solver parameters
prm = solver.parameters
prm['nonlinear_solver'] = 'newton'
# Tried to change the solver to mumps, this gets rid of the out of memory error for non newtonion fluids, still doesn't converge
prm['newton_solver']['linear_solver'] = 'mumps'
prm['newton_solver']['absolute_tolerance'] = 1.E-10
prm['newton_solver']['relative_tolerance'] = 1.E-9
prm['newton_solver']['maximum_iterations'] = 1000
prm['newton_solver']['relaxation_parameter'] = 1.0
# Free surface nodes
coords = mesh.coordinates()
fsnodes=list()
for i in range(len(coords)):
   if coords[i][0] > LW1-TOL and coords[i][1] > LH-TOL:
      fsnodes.append((i,coords[i][0],coords[i][1]))
fsnodes = np.array(fsnodes, dtype=[('index', int),('x', float),('y', float)])
fsnodes = np.sort(fsnodes, order='x')
u=np.zeros(len(fsnodes))
u_old=np.zeros(len(fsnodes))
delta_u=np.zeros(len(fsnodes))
vhat=np.zeros((2,len(fsnodes)))
# Outlet nodes
rbnodes=list()
   if coords[i][0] > LW2-TOL:
      rbnodes.append((i,coords[i][0],coords[i][1]))
rbnodes = np.array(rbnodes, dtype=[('index', int),('x', float),('y', float)])
rbnodes = np.sort(rbnodes, order='y')
run = True
if run:
   # Solve problem
   iflag = 0; nflag = 0;
   t = 0
   ufinal.rename("u", "u"); ufile << (ufinal, t)
   L2TOL=1
   while iflag < 11 or L2TOL > 1E-4:
      # Increment
      if Newtonian:
         iflag = 11; nflag += 1;
         velocity.t = 1.
         print("\n Newtonian Iteration: %d \n"%(nflag))
         iflag += 1; t += dt;
         if iflag<=10: velocity.t = t
         print("\n Iteration: %d \n"%(iflag))
      # Solve
      solver.solve()
      (p,v,tau) = w.split(True);
      # Interpolate the velocity to a 1st order space
      v_tilde.assign(interpolate(v,V1))
      # Get the velocity components for the free surface nodes
      for i in range(len(fsnodes)):
         vhat[0][i] = v_tilde.vector().get_local()[mmap[fsnodes[i][0]][0]]
         vhat[1][i] = v_tilde.vector().get_local()[mmap[fsnodes[i][0]][1]]
      # Calculate the displacement of the free surface nodes using the streamline method
      for i in range(len(fsnodes)-1):
            u[i+1] = u[i] + (vhat[1][i+1] / vhat[0][i+1] + vhat[1][i] / vhat[0][i] ) \
                     /2. *(fsnodes[i+1][1]-fsnodes[i][1])
      # Calculate the incremental displacement and assign the current displacement to use in the next step
      delta_u = np.subtract(u,u_old)
      for i in range(len(u)):
         u_old[i]=u[i]
      # Calculate the L2 norm of the incremental displacements to use as a stopping criteria
      L2TOL = 0
         L2TOL += delta_u[i]*delta_u[i]
      L2TOL = sqrt(L2TOL)
      print("L2TOL: %.8f"%(L2TOL))
      # Move the free surface nodes
         coords[fsnodes[i][0]][1] += delta_u[i]
      # Move the outlet nodes
      enddisp = delta_u[len(fsnodes)-1]
      for i in range(len(rbnodes)-2):
         coords[rbnodes[i+1][0]][1] += enddisp * rbnodes[i+1][2] / rbnodes[len(rbnodes)-1][2]
      # Mesh smoothing
      mesh.smooth(20)
      # Save final coordinates of the mesh and calculate displacement of each node
      ufinal.assign(interpolate(coord, V2))
      ufinal.assign(project(ufinal-uinit, V2))
      # Save solution
      p.rename("p", "p"); pfile << (p , t)
      v.rename("v", "v"); vfile << (v , t)
      tau.rename("tau", "tau"); taufile << (tau , t)
      ufinal.rename("u", "u"); ufile << (ufinal , t)
      # Print swelling ratio
      maxdisp = np.max(ufinal.vector().get_local())
      swelling = maxdisp + LH
      print('Swelling ratio: %.4f'%(swelling))
Please keep in mind that the best way to get help in this forum is to post questions with a minimal working (or failing) code. The entry level to read your code is quite high, since it’s basically a research code: the code is long, it contains non-trivial physical phenomena (non-Newtonian fluids, free surface flows, …) which drastically reduces the number of people who will be able to have an intuition of what may be going wrong.
Even with a limited understanding of what’s going on, a suggestion could be: you said that the Newtonian case is converging. If so, try and use the converged solution as an initial guess to the non-Newtonian solver.
