Hello everyone,
I want to simulate a simple strain Test with the help of a hyperelastic Material.
For the simulation of the load I defined a boundary condition for the displacement which is increased for each time step. At first everything is fine, but after the 34 th timestep the newton solver doesn’t converge anymore and I get the error Message:
*** Error: Unable to solve nonlinear system with NewtonSolver.
*** Reason: Newton solver did not converge because maximum number of iterations reached.
*** Where: This error was encountered inside NewtonSolver.cpp.
*** Process: 0
this has happened when I use a 2D mesh as well for a 3D one. Can you tell me what I did wrong and how I can change that?
Thanks a lot in advance!
Here is my code
import time
# Elasticity parameters
E = 220*1000
nu = 0.45
beta = Constant(nu/(1-2*nu))
mu= Constant(E/(2*(1 + nu)))
# Zeitvariablen
T = 10 # final time
num_steps = 100 # number of time steps
# Create mesh #
nx0 = 0
ny0 = 0
nz0 = 0
nx1 = 0.11 # in m
ny1 = 0.015/2 # in m
nz1 = 0.003/2 # in m
### number of elements in x.y und z-direction
nx = 20
ny = 6
nz = 3
mesh = BoxMesh(Point(nx0,ny0,nz0),Point(nx1,ny1,nz1), nx,ny, nz)
# FunctionSpace #
P2 = VectorElement('Lagrange', mesh.ufl_cell(), 2)
V = FunctionSpace(mesh, P2)
# Boundary Stuff #
############################### x-direction ####################################
class rechts(SubDomain):
tol = 1E-14
return on_boundary and near(x[0],nx1,tol)
class links(SubDomain):
tol = 1E-14
return on_boundary and near(x[0],nx0,tol)
# x
right = rechts()
left = links()
boundaries = MeshFunction('size_t',mesh,mesh.topology().dim()-1)
strainrate = 1*10**(-3) # in m
u_RB_lin = Expression(("strainrate*t"), degree=2, strainrate=strainrate, t=0)
bcr = DirichletBC(V.sub(0), u_RB_lin, right)
bcl = DirichletBC(V, Constant((0, 0, 0)), left)
bcs = [bcl, bcr]
# Functions #
# Define functions
du = TrialFunction(V) # Incremental displacement
v = TestFunction(V) # Test function
u = Function(V) # Displacement from previous iteration
# Kinematics
d = u.geometric_dimension()
I = Identity(d) # Identity tensor
invF = inv(F)
Ic = tr(C)
J = det(F)
# stress tensor
Piola = mu*(-J**(-2*beta)*invF.T)+mu*F
# Momentum balance (no external forces)
Imp = inner(Piola,nabla_grad(v))*dx
eqn = Imp
# Solving #
t = 0 # Definieren des Zeitpunkts t0
for n in range(num_steps):
start = time.time()
# Update current time
u_RB_lin.t=t
# Compute Jacobian of F
J = derivative(eqn, u, du)
# Solve variational problem
solve(eqn == 0, u, bcs, J=J,solver_parameters={"newton_solver":
{"relative_tolerance": 1e-6}})
