I’m using macOS Mojave (10.14.6), miniconda, and FEniCS 2018 with Python. I have a function u: \mathbb{R}^d \rightarrow \mathbb{R}, d = 1, 2. What I want to compute now is the norm / length of its gradient, so | \nabla u| = \sqrt{\nabla u \cdot \nabla u}. Looking only at the dot product, then this should be nonnegative. But if I take u as this function
then |\nabla u| and \nabla u \cdot \nabla u should have (possibly hughe) jumps at x = 0.3 and 0.7. Instead I get something like this (on a mesh with 49 grid points)
Could it be that I have done something wrong with dot and grad here? I get similar results when doing this with a function \mathbb{R}^2 \rightarrow \mathbb{R}.
# constructing mesh on (0, 1)
N = 49;
mesh = UnitIntervalMesh(N); V = FunctionSpace(mesh, 'P', 1)
# (step)-function of interest
u = interpolate(Expression('x[0] >= 0.3 && x[0] <= 0.7 ? 2 : 1', degree = 2), V)
plot(u, title = 'u')
# plot dot product of grad(u) with itselfe
plot(project(dot(grad(u), grad(u))), title = 'dot(grad(u), grad(u))')
What is being plotted here is not \vert\nabla u\vert itself, but an L^2 projection of it onto a linear C^0 finite element space. L^2 projection to linears does not preserve sign, and the result will have oscillations when projecting discontinuous functions. Some options to get monotone plots are projecting to a DG space or using lumped-mass projection to linears. See, e.g., the following modification of your MWE:
N = 49
# Function to project and plot:
f = sqrt(dot(grad(u),grad(u)))
# Option 0: Consistent-mass projection to a continous space is oscillatory when
# projecting discontinuous functions.
plot(project(f))
# Option 1: Project to a DG0 space (i.e., elementwise averaging).
plot(project(f,FunctionSpace(mesh,"DG",0)))
# Option2: Lumped-mass projection to CG1, which remains monotone.
def lumpedProject(f):
lhs = assemble(inner(Constant(1.0),v)*dx)
rhs = assemble(inner(f,v)*dx)
as_backend_type(u.vector())\
.vec().pointwiseDivide(as_backend_type(rhs).vec(),
as_backend_type(lhs).vec())
return u
plot(lumpedProject(f))
plt.autoscale()
Awesome, thank you! Just one quick question. Is your lumpedProject equivalent to
u.vector()[:] = rhs[:]/lhs[:]
return u
I am not familiar with the as_beckend_type but I figured out what you did and tried to implement it “my way”. It gives the same output for this example, so I do not know if this is valid for those but will fail for other.
I’ve never tried to do that before, but it looks like that syntax performs the desired element-wise division. I just default to thinking in terms of PETSc operations, because I learned PETSc before I started using FEniCS.
About as_backend_type: In the current stable version of FEniCS, there are abstractions for linear algebra that are designed to interface with different “backend” libraries, but, in practice, everyone uses the default PETSc backend; according to the development roadmap, future versions of FEniCS will support PETSc exclusively.
