Formulation with grad of function squared
Hi all,
The problem i’m trying to solve is:
\nabla( \nabla u^2) = 0
u = 1 on \delta \Omega
This is my implementation:
mesh = UnitIntervalMesh(10)
dt = Constant(0.1)
theta = u**2  # scaling
F = dot(grad(theta), grad(v))*dx
bcs = DirichletBC(V, 1, "on_boundary")
solve(F==0, u, bcs)
The above code diverges:
No Jacobian form specified for nonlinear variational problem.
Differentiating residual form F to obtain Jacobian J = F'.
  Newton iteration 0: r (abs) = 1.414e+00 (tol = 1.000e-10) r (rel) = 1.000e+00 (tol = 1.000e-09)
  Newton iteration 1: r (abs) = -nan (tol = 1.000e-10) r (rel) = -nan (tol = 1.000e-09)
  Newton iteration 2: r (abs) = -nan (tol = 1.000e-10) r (rel) = -nan (tol = 1.000e-09)
  Newton iteration 3: r (abs) = -nan (tol = 1.000e-10) r (rel) = -nan (tol = 1.000e-09)
  Newton iteration 4: r (abs) = -nan (tol = 1.000e-10) r (rel) = -nan (tol = 1.000e-09)
  Newton iteration 5: r (abs) = -nan (tol = 1.000e-10) r (rel) = -nan (tol = 1.000e-09)
  Newton iteration 6: r (abs) = -nan (tol = 1.000e-10) r (rel) = -nan (tol = 1.000e-09)
  Newton iteration 7: r (abs) = -nan (tol = 1.000e-10) r (rel) = -nan (tol = 1.000e-09)
  Newton iteration 8: r (abs) = -nan (tol = 1.000e-10) r (rel) = -nan (tol = 1.000e-09)
  Newton iteration 9: r (abs) = -nan (tol = 1.000e-10) r (rel) = -nan (tol = 1.000e-09)
  Newton iteration 10: r (abs) = -nan (tol = 1.000e-10) r (rel) = -nan (tol = 1.000e-09)
  Newton iteration 11: r (abs) = -nan (tol = 1.000e-10) r (rel) = -nan (tol = 1.000e-09)
  Newton iteration 12: r (abs) = -nan (tol = 1.000e-10) r (rel) = -nan (tol = 1.000e-09)
  Newton iteration 13: r (abs) = -nan (tol = 1.000e-10) r (rel) = -nan (tol = 1.000e-09)
  Newton iteration 14: r (abs) = -nan (tol = 1.000e-10) r (rel) = -nan (tol = 1.000e-09)
  Newton iteration 15: r (abs) = -nan (tol = 1.000e-10) r (rel) = -nan (tol = 1.000e-09)
  Newton iteration 16: r (abs) = -nan (tol = 1.000e-10) r (rel) = -nan (tol = 1.000e-09)
  Newton iteration 17: r (abs) = -nan (tol = 1.000e-10) r (rel) = -nan (tol = 1.000e-09)
  Newton iteration 18: r (abs) = -nan (tol = 1.000e-10) r (rel) = -nan (tol = 1.000e-09)
  Newton iteration 19: r (abs) = -nan (tol = 1.000e-10) r (rel) = -nan (tol = 1.000e-09)
  Newton iteration 20: r (abs) = -nan (tol = 1.000e-10) r (rel) = -nan (tol = 1.000e-09)
  Newton iteration 21: r (abs) = -nan (tol = 1.000e-10) r (rel) = -nan (tol = 1.000e-09)
  Newton iteration 22: r (abs) = -nan (tol = 1.000e-10) r (rel) = -nan (tol = 1.000e-09)
  Newton iteration 23: r (abs) = -nan (tol = 1.000e-10) r (rel) = -nan (tol = 1.000e-09)
  Newton iteration 24: r (abs) = -nan (tol = 1.000e-10) r (rel) = -nan (tol = 1.000e-09)
  Newton iteration 25: r (abs) = -nan (tol = 1.000e-10) r (rel) = -nan (tol = 1.000e-09)
  Newton iteration 26: r (abs) = -nan (tol = 1.000e-10) r (rel) = -nan (tol = 1.000e-09)
  Newton iteration 27: r (abs) = -nan (tol = 1.000e-10) r (rel) = -nan (tol = 1.000e-09)
  Newton iteration 28: r (abs) = -nan (tol = 1.000e-10) r (rel) = -nan (tol = 1.000e-09)
  Newton iteration 29: r (abs) = -nan (tol = 1.000e-10) r (rel) = -nan (tol = 1.000e-09)
  Newton iteration 30: r (abs) = -nan (tol = 1.000e-10) r (rel) = -nan (tol = 1.000e-09)
  Newton iteration 31: r (abs) = -nan (tol = 1.000e-10) r (rel) = -nan (tol = 1.000e-09)
  Newton iteration 32: r (abs) = -nan (tol = 1.000e-10) r (rel) = -nan (tol = 1.000e-09)
  Newton iteration 33: r (abs) = -nan (tol = 1.000e-10) r (rel) = -nan (tol = 1.000e-09)
  Newton iteration 34: r (abs) = -nan (tol = 1.000e-10) r (rel) = -nan (tol = 1.000e-09)
  Newton iteration 35: r (abs) = -nan (tol = 1.000e-10) r (rel) = -nan (tol = 1.000e-09)
  Newton iteration 36: r (abs) = -nan (tol = 1.000e-10) r (rel) = -nan (tol = 1.000e-09)
  Newton iteration 37: r (abs) = -nan (tol = 1.000e-10) r (rel) = -nan (tol = 1.000e-09)
  Newton iteration 38: r (abs) = -nan (tol = 1.000e-10) r (rel) = -nan (tol = 1.000e-09)
  Newton iteration 39: r (abs) = -nan (tol = 1.000e-10) r (rel) = -nan (tol = 1.000e-09)
  Newton iteration 40: r (abs) = -nan (tol = 1.000e-10) r (rel) = -nan (tol = 1.000e-09)
  Newton iteration 41: r (abs) = -nan (tol = 1.000e-10) r (rel) = -nan (tol = 1.000e-09)
  Newton iteration 42: r (abs) = -nan (tol = 1.000e-10) r (rel) = -nan (tol = 1.000e-09)
  Newton iteration 43: r (abs) = -nan (tol = 1.000e-10) r (rel) = -nan (tol = 1.000e-09)
  Newton iteration 44: r (abs) = -nan (tol = 1.000e-10) r (rel) = -nan (tol = 1.000e-09)
  Newton iteration 45: r (abs) = -nan (tol = 1.000e-10) r (rel) = -nan (tol = 1.000e-09)
  Newton iteration 46: r (abs) = -nan (tol = 1.000e-10) r (rel) = -nan (tol = 1.000e-09)
  Newton iteration 47: r (abs) = -nan (tol = 1.000e-10) r (rel) = -nan (tol = 1.000e-09)
  Newton iteration 48: r (abs) = -nan (tol = 1.000e-10) r (rel) = -nan (tol = 1.000e-09)
  Newton iteration 49: r (abs) = -nan (tol = 1.000e-10) r (rel) = -nan (tol = 1.000e-09)
  Newton iteration 50: r (abs) = -nan (tol = 1.000e-10) r (rel) = -nan (tol = 1.000e-09)
  File "mwe_scaling.py", line 18, in <module>
    solve(F==0, u, bcs)
  File "/usr/local/lib/python3.6/dist-packages/dolfin/fem/solving.py", line 220, in solve
  File "/usr/local/lib/python3.6/dist-packages/dolfin/fem/solving.py", line 266, in _solve_varproblem
    solver.solve()
RuntimeError:
*** Error:   Unable to solve nonlinear system with NewtonSolver.
*** Reason:  Newton solver did not converge because maximum number of iterations reached.
*** Where:   This error was encountered inside NewtonSolver.cpp.
*** Process: 0
*** DOLFIN version: 2019.1.0
*** Git changeset:  74d7efe1e84d65e9433fd96c50f1d278fa3e3f3f
Any idea how to solve this problem?
Cheers
Remi
I think you can think of this as
\nabla u ^2 = 2 u \nabla u
which leads to the nonlinear Poisson problem
- \nabla \cdot \kappa(u) \nabla u = 0
where \kappa(u) = 2 u. This is only well posed when \kappa \neq 0 which means we need a nonzero initial guess accordingly. So try:
u.interpolate(Constant(1.0))
solve(F==0, u, bcs)
Hi @nate thank you very much! It all makes perfect sense.
The following transient problem works:
num_steps = 3
u_n = Function(V)
dt = Constant(0.1)
theta = u**2
theta_n = u_n**2
F = (theta-theta_n)/dt*v*dx
F += dot(grad(theta), grad(v))*dx
u.assign(interpolate(Constant(DOLFIN_EPS), V))
for i in range(num_steps):
    solve(F==0, u, bcs)
    u_n.assign(u)
Although for some reason the first iteration converges slower:
  Newton iteration 1: r (abs) = 2.399e+00 (tol = 1.000e-10) r (rel) = 1.696e+00 (tol = 1.000e-09)
  Newton iteration 2: r (abs) = 4.505e-01 (tol = 1.000e-10) r (rel) = 3.185e-01 (tol = 1.000e-09)
  Newton iteration 3: r (abs) = 2.775e-02 (tol = 1.000e-10) r (rel) = 1.962e-02 (tol = 1.000e-09)
  Newton iteration 4: r (abs) = 1.077e-04 (tol = 1.000e-10) r (rel) = 7.616e-05 (tol = 1.000e-09)
  Newton iteration 5: r (abs) = 1.151e-09 (tol = 1.000e-10) r (rel) = 8.136e-10 (tol = 1.000e-09)
  Newton solver finished in 5 iterations and 5 linear solver iterations.
  Newton iteration 0: r (abs) = 1.688e+00 (tol = 1.000e-10) r (rel) = 1.000e+00 (tol = 1.000e-09)
  Newton iteration 1: r (abs) = 2.632e-01 (tol = 1.000e-10) r (rel) = 1.560e-01 (tol = 1.000e-09)
  Newton iteration 2: r (abs) = 6.272e-03 (tol = 1.000e-10) r (rel) = 3.716e-03 (tol = 1.000e-09)
  Newton iteration 3: r (abs) = 3.062e-06 (tol = 1.000e-10) r (rel) = 1.814e-06 (tol = 1.000e-09)
  Newton iteration 4: r (abs) = 5.172e-13 (tol = 1.000e-10) r (rel) = 3.065e-13 (tol = 1.000e-09)
  Newton solver finished in 4 iterations and 4 linear solver iterations.
  Newton iteration 0: r (abs) = 7.105e-01 (tol = 1.000e-10) r (rel) = 1.000e+00 (tol = 1.000e-09)
  Newton iteration 1: r (abs) = 4.813e-02 (tol = 1.000e-10) r (rel) = 6.774e-02 (tol = 1.000e-09)
  Newton iteration 2: r (abs) = 1.709e-04 (tol = 1.000e-10) r (rel) = 2.405e-04 (tol = 1.000e-09)
  Newton iteration 3: r (abs) = 1.712e-09 (tol = 1.000e-10) r (rel) = 2.409e-09 (tol = 1.000e-09)
  Newton iteration 4: r (abs) = 5.526e-15 (tol = 1.000e-10) r (rel) = 7.777e-15 (tol = 1.000e-09)
Any idea?
After you solve the system for the first time, you have a much better initial guess than a constant value of 1 everywhere. In essence you’re probably deeper in an attractor region. See some hints and tips here.
