Drift-Diffusion: Neumann BC with du/dx instead of du/dn
Hello all,
i want to impose a Neumann boundary condition to a drift–diffusion-problem that simply lets a flux pass through the boundaries. I do this by adding a boundary integral (ds) over the flux term to the variational form. To test this approach, I have implemented a simple example where a concentration peak moves through the cell with a constant drift velocity \mathbf{b} and, eventually, leaves the cell.
So the drift–diffusion equation looks like this:
\frac{\partial u}{\partial t} = -\nabla\mathbf{j}\\ \mathbf{j} = -D\left(\nabla u - \mathbf{b}\cdot u\right)
And, initially, I thought that the Neumann boundary condition can be set in a simple way, like this:
\int\limits_\Omega\left(u(t_{n+1})-u(t_n)\right)\cdot v\,\mathrm{d}x -\Delta t\cdot\int\limits_\Omega\mathbf{j}\cdot\nabla v\,\mathrm{d}x+\Delta t\cdot\int\limits_{\partial\Omega}\mathbf{j}\,v\,\mathrm{d}\mathbf{s} = 0
Minimal code example:
mesh = IntervalMesh(1000, -5, 5)
u, u_copy = Function(V), Function(V)
# Drift-Diffusion equation
D, dt, drift = Constant(1.), Constant(.01), Constant(+10.)
j = -D*(u.dx(0)-u*drift)
F = (u-u_copy)*v*dx - dt*j*v.dx(0)*dx + dt*j*v*ds
# initial concentration profile
u0 = Expression('exp(-(x[0]-m)*(x[0]-m)/(2*l*l))', m=0., l=.1, degree=1)
u.interpolate(u0)
# solve time propagation
for i in range(100):
    u_copy.vector()[:] = u.vector()[:]
    solve(F==Constant(0.), u, [])
    plot(u)
For b=+10, this appears to work, but, if I switch the sign to b=-10, the outcome of the simulation is completely different:
Basically, the Neumann boundary condition does what I want it to do on the right boundary, but not on the left one. I think this is because I actually want to prescribe gradients of the form \mathrm{d}/\mathrm{d}x, rather than \mathrm{d}/\mathrm{d}\mathbf{n} (with \mathbf{n} being the normal vector of the outer boundary).
For the 1-dimensional case, I could fix this by having separate terms (-dt*j*ds(1) for the right boundary, +dt*j*ds(2) for the left boundary) for the two boundaries. I am wondering, though, if there is a simpler and more general solution to this that would also work for more complex geometries in higher dimensions.
Why doesn’t n = ufl.FacetNormal(mesh) accommodate what you need? In 1D it will be n = -1 on the left and n = +1 on the right as you require.
There seems to be a problem with the dimensions in the variational expression then. I tried formulating the boundary term as + dt*n*j*v*ds, with n = FacetNormal(mesh)
But then, I get this error:
ufl.log.UFLException: Can only integrate scalar expressions. The integrand is a tensor expression with value shape (1,) and free indices with labels ().
Looks like a generalisation of the tensor formulated nature of the facet normal. You could just try n[0]. In 1D it will always have shape (1,).
Nice, thanks a lot! In case of higher dimensions, would I have to do the same?
I’ve only glanced at your formulation. The flux is typically written:
\frac{\partial u}{\partial \vec{n}} = \nabla u \cdot \vec{n}.
You can formulate these terms as necessary in UFL, it all depends on the weak formulation and boundary conditions you’re attempting to discretise.
Alright, thanks. Guess I’ll try it out in 2D to see if something like inner(j, n) works.
