Dynamic b vector for linear problem
Hello everyone,
I am using dolfinx 0.5.2 and trying to solve a static electromagnetic problem. The problem in question needs dynamic creation of vector b for a linear resolution of type Ax=b.
Currently, a similar code is executed at each iteration:
from dolfinx.fem import (
    Function,
    FunctionSpace,
from ufl import (
    TestFunction,
    TrialFunction,
    dot,
    dx,
    grad,
    SpatialCoordinate,
V = FunctionSpace(mesh, ("CG", 2))
u = TrialFunctionV)
x = SpatialCoordinate(mesh)
a = 1 / (2.0 * np.pi * MU0) * (1 / x[0] * dot(grad(u), grad(v))) * dx
L = J * v * dx
u_h = Function(V)
problem = LinearProblem(a, L, u=u_h, bcs=dirichlet_bcs)
u_h = problem.solve()
Where MU0 is a constant and J is a dolfinx function that varies at each iteration. The idea would be to preliminarily create the matrix A, dynamically create the vector b from J, and then solve the linear system at each iteration in order to speed up calculations.
Thank you in advance for your help.
What type is J? You have not specified if it is a constant, a coefficient (dolfinx.fem.Function) or anything else?
For this I would probably not use the LinearProblem.solve, as it re-assembles the matrix at every step.
I would rather use dolfinx.fem.petsc.assemble_matrix and create a PETSc.KSP object that can cache things such as the LU factorization.
Thank you for the answer. Yes, J is dolfinx.fem.Function.
Meanwhile, I tried something like
    Function,
    FunctionSpace,
from ufl import (
    TestFunction,
    TrialFunction,
    dot,
    dx,
    grad,
    SpatialCoordinate,
u = TrialFunctionV)
a = dolfinx.fem.forms.form(
A = dolfinx.fem.petsc.assemble_matrix(a)
L = dolfinx.fem.forms.form(J * v * dx)
b = dolfinx.fem.petsc.assemble_vector(L)
b.assemble()
ksp = PETSc.KSP().create()
ksp.setOperators(A)
x = PETSc.Vec()
ksp.solve(b, x)
But I get:
[0]PETSC ERROR: or see https://petsc.org/release/faq/#valgrind
[0]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple MacOS to find memory corruption errors
application called MPI_Abort(MPI_COMM_WORLD, 59) - process 0
[unset]: write_line error; fd=-1 buf=:cmd=abort exitcode=59
system msg for write_line failure : Bad file descriptor
You need to call A.assemble() after using this command.
use
x_func = fem.Function(V)
x = x_func.vector
You should also send in the mpi communicator in the ksp.create, see: dolfinx/python/test/unit/fem/test_assembler.py at deac4f1cba124f09302f8bb501777f3e25a827c4 · FEniCS/dolfinx · GitHub
or A known analytical solution — FEniCSx tutorial
Thank you so much, seems working!
