Dear all,
I am currently trying to follow a matrix-free approach to model a dynamic elasticity problem using Dolfinx 0.6.0. For this, in each time iteration, I solve for the acceleration values on each node by dividing the total force (which is a function of the displacement values at the previous time step) by lumped mass vector and then iterating the velocity and displacement fields accordingly. I am not sure if it is the most efficient way to do it but it looks like it works for the specific problem that I am interested in.
Here is my MWE:
from dolfinx import fem
from dolfinx.fem.petsc import (assemble_vector, set_bc)
Lx = 0.01
Ly = 0.1
meshsize = Lx/20.0
comm = MPI.COMM_WORLD
if comm.rank == 0:
print("Number of Parallel Threads: ", comm.size)
nx = round(Lx/meshsize)
ny = round(Ly/meshsize)
# domain = dolfinx.mesh.create_unit_square(MPI.COMM_WORLD,nx,ny)
domain = dolfinx.mesh.create_rectangle(MPI.COMM_WORLD,
[np.array([0.0,0.0]), np.array([Lx,Ly])],
[nx, ny], dolfinx.mesh.CellType.quadrilateral,
ghost_mode = dolfinx.cpp.mesh.GhostMode.none)
# # Define material properties
young = 210.0e9
nu = 0.3
density = 7800.0
sigma0 = 17.5e3/Lx
lmbda_ = young/((1.0+nu)*(1.0-2.0*nu))
mu = young/(2.0*(1.0+nu))
kappa = lmbda_ + mu #for 2D #kappa = lmbda + 2/3 * mu #for 3D
t=0
dt = 1.0e-9
totalT = 2.0
numsteps = round(totalT/dt)
tsave = 0.1
nsave = round(tsave/dt)
nprint = 500
e0 = ufl.VectorElement("CG", domain.ufl_cell(), 1)
V = dolfinx.fem.FunctionSpace(domain, e0) # V = dolfinx.VectorFunctionSpace(mesh, ("CG", 1))
crack_indices, crack_markers = [], []
domain_boundaries = [(1, lambda x: np.isclose(x[0], 0.0)),
(2, lambda x: np.isclose(x[0], Lx)),
(3, lambda x: np.isclose(x[1], 0.0)),
(4, lambda x: np.isclose(x[1], Ly))]
for (marker, locator) in domain_boundaries:
facets = dolfinx.mesh.locate_entities(domain, fdim, locator)
facet_indices.append(facets)
facet_tags = dolfinx.mesh.meshtags(domain, fdim, np.array(np.hstack(facet_indices), dtype=np.int32),
np.array(np.hstack(facet_markers), dtype=np.int32))
domain.topology.create_connectivity(domain.topology.dim-1, domain.topology.dim)
ds = ufl.Measure("ds", domain=domain, subdomain_data=facet_tags)
n = ufl.FacetNormal(domain) # normal
def top(x):
return np.isclose(x[1], Ly)
def bot(x):
return np.isclose(x[1], 0.0)
boundary_facets_top = dolfinx.mesh.locate_entities(domain, domain.topology.dim - 1,top)
boundary_facets_bot = dolfinx.mesh.locate_entities(domain, domain.topology.dim - 1,bot)
class MyExpression:
def __init__(self):
self.t = 0.0
def eval(self, x):
return np.full(x.shape[1], self.t) # Added some spatial variation here. Expression is sin(t)*x
bc_u =[]
boundary_dofs_botxy_disp = dolfinx.fem.locate_dofs_topological(V, domain.topology.dim-1, boundary_facets_bot)
disp_bot_val = dolfinx.fem.Constant(domain, (0.0, 0.0))
bc_bot_xy = dolfinx.fem.dirichletbc(disp_bot_val, boundary_dofs_botxy_disp, V)
bc_u.append(bc_bot_xy)
return ufl.sym(ufl.grad(u))
def sigma(u):
temp2 = epsilon(u)
return 2.0*mu*temp2 + lmbda_* ufl.tr(temp2)*ufl.Identity(len(u))
def project(expression, V):
u_, v_ = ufl.TrialFunction(V), ufl.TestFunction(V)
a_p = ufl.inner(u_, v_) * ufl.dx - ufl.inner(expression, v_) * ufl.dx
projection = dolfinx.fem.petsc.LinearProblem(ufl.lhs(a_p), ufl.rhs(a_p))
return projection.solve()
def DensityExpression(x):
vals0 = np.zeros((2, x.shape[1]))
vals0[0] = density
vals0[1] = density
return vals0
dens_vals_for_acc = dolfinx.fem.Function(V)
dens_vals_for_acc.interpolate(DensityExpression)
def Constant_one_expression(x):
vals0[0] = 1.0
vals0[1] = 1.0
return vals0
Constant_one = dolfinx.fem.Function(V)
Constant_one.interpolate(Constant_one_expression)
vel_, vel_n = fem.Function(V), fem.Function(V)
a_, a_n = fem.Function(V), fem.Function(V)
u_, u_n = fem.Function(V), fem.Function(V)
u = ufl.TrialFunction(V)
with u_n.vector.localForm() as uold_loc:
uold_loc.set(0)
with vel_n.vector.localForm() as uold_loc:
uold_loc.set(0)
with a_n.vector.localForm() as uold_loc:
uold_loc.set(0)
def Surf_Force_exp(x):
vals = np.zeros((domain.geometry.dim, x.shape[1]))
vals[1] = 0.0
for i in range(x.shape[1]):
if(np.isclose(x[1][i], Ly)):
vals[0][i] = sigma0
return vals
surf_force = dolfinx.fem.Function(V)
surf_force.interpolate(Surf_Force_exp)
mass_form = ufl.inner(u,v)*ufl.dx
mass_action_form = ufl.action(mass_form, dens_vals_for_acc)
L_lumped = dolfinx.fem.form(mass_action_form)
M_lumped = assemble_vector(L_lumped)
M_lumped.assemble()
B = dolfinx.fem.Constant(domain, PETSc.ScalarType((0.0, 0.0))) # body force N/mm/m
external_form = ufl.inner(B, v) * ufl.dx + ufl.inner(surf_force, v) * ds
F_external = assemble_vector(dolfinx.fem.form(external_form))
F_external.assemble()
F_external.ghostUpdate(PETSc.InsertMode.ADD_VALUES, PETSc.ScatterMode.REVERSE)
set_bc(F_external, bc_u)
i=0
filename_disp='./1_Result/Result_disp.pvd'
outfile_disp = dolfinx.io.VTKFile(MPI.COMM_WORLD,filename_disp,"w")
while i<=numsteps:
i+=1
t = t + dt
internal_form = ufl.inner(sigma(u_n), ufl.grad(v)) * ufl.dx
F_internal = assemble_vector(dolfinx.fem.form(internal_form))
F_internal.assemble()
F_internal.ghostUpdate(PETSc.InsertMode.ADD_VALUES, PETSc.ScatterMode.REVERSE)
set_bc(F_internal, bc_u)
aaa = -(F_internal[:]-F_external[:])/M_lumped[:]
a_.x.array[:] = aaa
vel_ = vel_n + dt * a_
u_ = u_n + dt * vel_
u_n = project(u_, V)
vel_n = project(vel_, V)
if(i%100 == 0):
if MPI.COMM_WORLD.rank == 0:
print(f"TimeStep: {i}, Time: {t}", flush=True)
if(i%200 == 0):
a_n = project(a_, V)
u_n.name = "Displacement"
a_n.name = "Acceleration"
vel_n.name = "Velocity"
outfile_disp.write_function([u_n,a_n,vel_n],t)
outfile_disp.close()
Everything seems to be working as expected when I run the code using one processor. However, when I increase the number of processors to 2 or more, I get the following error:
File "script.py", line 185, in <module>
File "PETSc/Vec.pyx", line 107, in petsc4py.PETSc.Vec.__getitem__
File "PETSc/petscvec.pxi", line 430, in petsc4py.PETSc.vec_getitem
File "PETSc/petscvec.pxi", line 382, in petsc4py.PETSc.vecgetvalues
petsc4py.PETSc.Error: error code 63
[0] VecGetValues() at /home/conda/feedstock_root/build_artifacts/petsc_1661243737224/work/src/vec/vec/interface/rvector.c:849
[0] VecGetValues_MPI() at /home/conda/feedstock_root/build_artifacts/petsc_1661243737224/work/src/vec/vec/impls/mpi/pdvec.c:848
[0] Argument out of range
[0] Can only get local values, trying 4216
[1] VecGetValues() at /home/conda/feedstock_root/build_artifacts/petsc_1661243737224/work/src/vec/vec/interface/rvector.c:849
[1] VecGetValues_MPI() at /home/conda/feedstock_root/build_artifacts/petsc_1661243737224/work/src/vec/vec/impls/mpi/pdvec.c:848
[1] Argument out of range
[1] Can only get local values, trying 0
Based on what I have learned so far from the previous questions, I guess this is related to the distributed mesh and perhaps the ghost cells. However, since I am very new to fenics and I couldnt find any matrix-free demo, I could not solve the problem yet. I also suspect that the code might have some efficiency flaws. I would really appreciate if someone helps me with:
- How to solve the above error? and
- If possible, how to increase the efficiency of the code.
I installed dolfinx using anaconda.
