Efficient integration on a reduced mesh
Hello, I was curious to know how one can effectively assemble the residual only over a subset of the cells for hyper-reduction purposes in model order reduction?
So far I have been using a restricted dx measure but I wonder if there is a clean way to extract the kernel for the single element evaluation of the residual?
Thank you in advance.
If you want a subset of cells, it is clearly cleanest to use a restricted dx measure.
If you want the local kernel be, that is a bit of a different question.
Is the residual that you are computing for a discontinuous function?
If not, just getting the local kernel for a single cell will no be equivalent to the entries in the vector of dofs in be (as dofs shared between cells as going to have contributions to the same residual row).
Do you mind creating an illustrative example of what you would like to achieve?
Hi @dokken and thanks for your reply. The idea is that to accelerate the assembly of F I can perform reduced integration on a (small) subset of the cells, with proper weights obtained by sparse non-negative least squares.
Below an illustrative example on a Poiseuille flow, at the bottom I check that the full residual and the one assembled element by element are the same. These two components are then matrix and rhs of my sparse least squares, and I will get some weights. However, I then need to be able to quickly integrate over the non-zero weighted cells and this is where I wonder if there is a better way than to define a dx measure. For example, in the past I had used for immersed methods the following repo augustjohansson/customquad: Library for using custom quadrature rules at runtime in FEniCSx, where the kernel was extracted to allow the use of custom quadrature rules, so something around those lines should definitely be doable, and it should be even easier since the quadrature points are the standard ones and only the weights change.
I hope this clarifies what I am trying to do, if not I am happy to provide further insight.
from __future__ import annotations
import basix
from dolfinx.fem.petsc import apply_lifting, assemble_matrix, assemble_vector, set_bc
from dolfinx.fem.petsc import create_vector, assemble_vector, create_matrix, assemble_matrix
nx, ny = 50, 50
mesh = dolfinx.mesh.create_rectangle(
    MPI.COMM_WORLD,
    [(0.0, 0.0), (1.0, 1.0)],
    [nx, ny],
    cell_type=dolfinx.mesh.CellType.triangle,
ve = basix.ufl.element("CG", mesh.basix_cell(), 2, shape=(2,))
pe = basix.ufl.element("CG", mesh.basix_cell(), 1)
ve_space = dolfinx.fem.functionspace(mesh, ve)
pe_space = dolfinx.fem.functionspace(mesh, pe)
VP_elem = basix.ufl.mixed_element([ve, pe])
VP = dolfinx.fem.functionspace(mesh, VP_elem)
u, p = ufl.TrialFunctions(VP)
v, q = ufl.TestFunctions(VP)
up = dolfinx.fem.Function(VP)
u, p = ufl.split(up)
def inlet_boundary(x):
    return np.isclose(x[0], 0.0)
def wall_boundary(x):
    return np.logical_or(np.isclose(x[1], 0.0), np.isclose(x[1], 1.0))
def outlet_boundary(x):
    return np.isclose(x[0], 1.0)
boundaries = [
    (1, wall_boundary),
    (2, inlet_boundary),
    (3, outlet_boundary),
facetdim = mesh.topology.dim - 1
mesh.topology.create_connectivity(facetdim, mesh.topology.dim)
num_facets_local = (
    mesh.topology.index_map(facetdim).size_local
    + mesh.topology.index_map(facetdim).num_ghosts
facet_markers = np.full(num_facets_local, -1, dtype=np.int32)
for marker, locator in boundaries:
    boundary_facets = dolfinx.mesh.locate_entities_boundary(mesh, facetdim,  locator)
    midpoints = dolfinx.mesh.compute_midpoints(mesh, facetdim, boundary_facets)
    boundary_facets = boundary_facets[locator(midpoints.T)]
    facet_markers[boundary_facets] = marker
is_marked = facet_markers >= 0
facets = np.flatnonzero(is_marked)
values = facet_markers[facets]
facet_tag = dolfinx.mesh.meshtags(mesh, facetdim, facets, values)
bcs = []
inlet_facets = facet_tag.find(2)
inlet_dofs_p = dolfinx.fem.locate_dofs_topological(
    (VP.sub(1), pe_space), mesh.topology.dim - 1, inlet_facets
one_p_func = dolfinx.fem.Function(pe_space)
one_p_func.interpolate(lambda x: np.ones_like(x[1]))
p_inlet = dolfinx.fem.dirichletbc(one_p_func, inlet_dofs_p, VP.sub(1))
wall_facets = facet_tag.find(1)
wall_dofs_v = dolfinx.fem.locate_dofs_topological(
    (VP.sub(0), ve_space), mesh.topology.dim - 1, wall_facets
zero_v_func = dolfinx.fem.Function(ve_space)
u_wall = dolfinx.fem.dirichletbc(zero_v_func, wall_dofs_v, VP.sub(0))
outlet_facets = facet_tag.find(3)
outlet_dofs_p = dolfinx.fem.locate_dofs_topological(
    (VP.sub(1), pe_space), mesh.topology.dim - 1, outlet_facets
zero_p_func = dolfinx.fem.Function(pe_space)
p_outlet = dolfinx.fem.dirichletbc(zero_p_func, outlet_dofs_p, VP.sub(1))
bcs.extend([u_wall, p_inlet, p_outlet])
rho = 1.0
mu = 0.01
F_integrand = (
    rho * ufl.inner(ufl.grad(u) * u, v)
    + mu * ufl.inner(ufl.grad(u), ufl.grad(v))
    - p * ufl.div(v)
    + ufl.div(u) * q
F = F_integrand * ufl.dx
J = ufl.derivative(F, up)
J_form = dolfinx.fem.form(J)
F_form = dolfinx.fem.form(F)
vp_res = dolfinx.fem.Function(VP)
residual = 10**8
snapshots = []
iter = 0
ksp = PETSc.KSP().create(MPI.COMM_WORLD)
ksp.setType(PETSc.KSP.Type.PREONLY)
ksp.getPC().setType(PETSc.PC.Type.LU)
while residual > 1e-14 and iter < 10:
    b = assemble_vector(F_form)
    apply_lifting(b, [J_form], [bcs], x0=[up.x.petsc_vec], scale=-1.0)
    b.ghostUpdate(
        addv=PETSc.InsertMode.ADD_VALUES, mode=PETSc.ScatterMode.REVERSE
    set_bc(b, bcs, up.x.petsc_vec, scale=-1.0)
    b.ghostUpdate(
        addv=PETSc.InsertMode.INSERT_VALUES, mode=PETSc.ScatterMode.FORWARD
    b.scale(-1.0)
    A = assemble_matrix(J_form, bcs=bcs)
    ksp.setOperators(A)
    ksp.solve(b, vp_res.x.petsc_vec)
    vp_res.x.scatter_forward()
    up.x.petsc_vec.axpy(1.0, vp_res.x.petsc_vec)
    up.x.scatter_forward()
    residual = b.norm()
    snapshots.append(up.x.array.copy())
    A.destroy()
    b.destroy()
    vp_res.x.petsc_vec.zeroEntries()
    print(iter, residual)
    iter += 1
snapshots = np.array(snapshots)
n_cells_local = mesh.topology.index_map(tdim).size_local
cell_forms = []
for cell in range(n_cells_local):
        mesh,
        tdim,
        np.array([cell], dtype=np.int32),
        np.array([1], dtype=np.int32),
    dx_cell = ufl.Measure(
        "dx",
        domain=mesh,
        subdomain_data=tag,
    F_cell = F_integrand * dx_cell(1)
    J_cell = ufl.derivative(F_cell, up)
    cell_forms.append((dolfinx.fem.form(F_cell), dolfinx.fem.form(J_cell)))
def assemble_full_residual(state_vec: np.ndarray) -> np.ndarray:
    up.x.array[:] = state_vec
    b.ghostUpdate(addv=PETSc.InsertMode.INSERT_VALUES, mode=PETSc.ScatterMode.FORWARD)
    b.scale(-1.0)
    out = b.array.copy()
    b.destroy()
    return out
def assemble_cell_residuals(state_vec: np.ndarray) -> np.ndarray:
    cell_residuals = []
    for F_cell_form, J_cell_form in cell_forms:
        b = assemble_vector(F_cell_form)
        b.scale(-1.0)
        cell_residuals.append(b.array.copy())
        b.destroy()
    return np.sum(cell_residuals, axis=0)
for k, snap in enumerate(snapshots):
    r_full = assemble_full_residual(snap)
    r_cells = assemble_cell_residuals(snap)
    mismatch = np.linalg.norm(r_full - r_cells)
    print(f"Snapshot {k}: ||r_full - sum_i r_i|| = {mismatch:.3e}")
Currently I don’t see how making a kernel and vector per single cell will accelerate any assembly.
If you want to work in this fashion you should at least insert directly into the new vector, not make N copies:
Additionally, the ghost updates are not correct for parallel assembly here (you are missing a scatter reverse).
If you want to make this as fast as possible, I would recommend using
compile_form and create_form:
as described in:
