I would like to be able to integrate some quantities on a single cell and on cells boundaries, with the aim to compute residual error estimates. For that particular case, I know that the residuals can be computed by assembling a bilinear form on all the domain, however I want to try to compute them by hand, element by element.
So my question is how to compute integrals on a single cell or on two or three facets. By searching on Fenics literature and forums I learnt something, and I wrote the following code (which should compute the area of each cell and the internal boundary length of the cells, but, the code does not work):
squareg = Rectangle(Point(-1.0, -1.0), Point(1.0,1.0))
mesh2d = generate_mesh(squareg, 1)
plot(mesh2d)
area_cells = [0] * mesh2d.num_cells()
int_bound_length_cells = [0] * mesh2d.num_cells()
domain_markers = MeshFunction("bool", mesh2d,mesh2d.topology().dim())
boundary_markers = MeshFunction("bool",mesh2d,mesh2d.topology().dim()-1)
for cell in cells(mesh2d):
domain_markers.set_all(False)
boundary_markers.set_all(False)
domain_markers[cell] = True
for fct in facets(cell):
if ~fct.exterior(): #### not working: facet connectivity not initialized
boundary_markers[fct]=True
## Just for testing ############
c=0
for cellj in cells(mesh2d):
if domain_markers[cellj]: c+=1
d=0
for f in facets(mesh2d):
if boundary_markers[f]: d+=1
print("cell ", cell.index())
print("cells integ: ", c)
print("edg integ: ", d)
dx_cell = Measure('dx',domain=mesh2d, subdomain_data=domain_markers)
ds_cell = Measure('ds',domain=mesh2d, subdomain_data=boundary_markers)
area_cells[cell.index()] = assemble(1.0*dx_cell) ##### gives error
int_bound_length_cells[cell.index()] = assemble(1.0*ds_cell) #### gives error
print(area_cells)
print(int_bound_length_cells)
Running this code gives the following error message (which is due to the “assemble” command):
File "/home/ariel/Documents/fenics/question_local_integral.py", line 38, in <module>
File "/usr/lib/petsc/lib/python3/dist-packages/dolfin/fem/assembling.py", line 202, in assemble
dolfin_form = _create_dolfin_form(form, form_compiler_parameters)
File "/usr/lib/petsc/lib/python3/dist-packages/dolfin/fem/assembling.py", line 60, in _create_dolfin_form
return Form(form,
File "/usr/lib/petsc/lib/python3/dist-packages/dolfin/fem/form.py", line 82, in __init__
self.set_cell_domains(subdomains)
TypeError: set_cell_domains(): incompatible function arguments. The following argument types are supported:
1. (self: dolfin.cpp.fem.Form, arg0: dolfin.cpp.mesh.MeshFunctionSizet) -> None
Invoked with: <dolfin.fem.form.Form object at 0x7f3816287a60>, <dolfin.cpp.mesh.MeshFunctionBool object at 0x7f381e53e4b0>
I have two questions:
- I can not find the way to perform the local integrations. Is that possible? and how?
- (A minor problem) My code to check if a facet is on the exterior boundary of the domain (“if ~fct.exterior(): …”) is not working, and it seems that is because the “facet connectivity” is not initialized. How can that be done?
Thanks in advance.
