Efficiently evaluatuating surface integrals on each cell in mesh
Question
Is there a way to efficiently evaluate line/surface integrals on each cell?
Below is some example code which should demonstrate what I’m trying to do. My issue seems to be that repeated evaluations of either form() or assemble_scalar() is very slow.
For the case of volume/area integrals, I found that I could project the function of interest onto a DG 0 function space, and then use assemble_vector. I’m having trouble adapting that approach to the boundaries, as it requires some additional restriction on the discontinuity.
Code
from mpi4py import MPI     # Parallel communication
from dolfinx import mesh   # Mesh tools
from dolfinx import fem
#%% Domain
nx = 5
ny = 5
domain = mesh.create_unit_square(MPI.COMM_WORLD, nx, ny, mesh.CellType.quadrilateral)
#%% Mesh Characterization
tdim = domain.topology.dim
domain.topology.create_connectivity(tdim, 1)     # Compute cells
c_to_e = domain.topology.connectivity(tdim, 1)   # Map cells to edges
num_cells = domain.topology.index_map(tdim).size_local + domain.topology.index_map(tdim).num_ghosts
# Tag each edge
num_edges = domain.topology.index_map(1).size_local + domain.topology.index_map(1).num_ghosts
tag_list = np.arange(num_edges, dtype=np.int32)
edge_tags = mesh.meshtags(domain, 1, tag_list, tag_list)
# Form Components
dE = ufl.Measure("dS", domain, subdomain_data=edge_tags)
cnst = fem.Constant(domain, ScalarType(1))
#%% Integration
L_calc = np.zeros(num_cells)
for itr in range(num_cells):
    L_val = 0
    for itrE in c_to_e.links(itr):
        L_val += fem.assemble_scalar( fem.form(cnst*dE(itr)) )
    L_calc[itr] = L_val
Could you please add the code where you tried to use a DG-0 test function?
For the boundary integrals, I am trying something like:
#%% DG-0 Projection
Vd = fem.FunctionSpace(domain, ("DG", 0))
v = ufl.TestFunction(Vd)
F_form = fem.form( ufl.inner(cnst, v)*dE )
F_asse = fem.assemble_vector(F_form)
Which gives the error:
UFLException: Discontinuous type Argument must be restricted.
My understanding is that I must specify something like the inner/outer edge of the discontinuity, so I try things like v(‘+’), or the following
F_form = fem.form( ufl.inner(cnst, ufl.avg(v))*dE )
F_vals = F_asse.array
The second attempt will produce results, but I expect it should be an array with all values equal to 0.8, the perimeter of the quadrilateral mesh elements.
I should note that I am just trying things to see what works at this point. I don’t understand the “restrictions” very well.
So I’ve made some progress on this, but I still don’t quite understand how restrictions in DG-0 work.
I’m able to get the answer I expect by using 2*avg(v), but I don’t know why the factor of 2 is necessary. My thinking was that the value on either side of the discontinuity should be the same, as I am projecting a constant c = 1 onto the space, so
\text{avg}(v) = \dfrac{1}{2}(v^+ \ + \ v^-) = v^+ = v^- \ ,
but this does not appear to be the case.
Below is a code snippet which seems to correctly evaluate the boundary integrals on each cell, excluding the exterior facets.
Code
#%% Domain
nx = 100
ny = nx
#%% DG-0 Projection
F_form = fem.form( ufl.inner(cnst, 2*ufl.avg(v))*ufl.dS ) # *** Not sure why factor of 2 is necessary
#%% Checking
# Count the occurances of each integral value
FU_vals, FU_count = np.unique( np.round(F_vals, 4), return_counts=True)
# Formulas for integrals in a unit square with quadrilateral mesh
# Integrals will not be evaluated on boundary, due to use of dS as measure
#   Types of Elements: [corners, edges, interior]
#                      ie, [2 exterior, 1 exterior, 0 exterior]
ref_vals = np.round( np.array([2, 3, 4])/nx, 4)
ref_count = [4, 4*(nx - 2), nx**2 - 4*(nx-1)]
if (all(FU_vals == ref_vals)):
    print('Values Correct')
if (all(FU_count == ref_count)):
    print('Count Correct')
