El.evaluate_basis_all() gives different results
I’m having a hard time evaluating basis functions here. The following code creates a mesh of a triangle and evaluates the basis functions at a particular point inside the triangle.
import numpy
from dolfin import BoundingBoxTree, Cell, FunctionSpace, Mesh, MeshEditor, Point
import meshzoo
def create_dolfin_mesh(points, cells):
    # https://bitbucket.org/fenics-project/dolfin/issues/845/initialize-mesh-from-vertices
    editor = MeshEditor()
    mesh = Mesh()
    editor.open(mesh, "triangle", 2, 2)
    editor.init_vertices(points.shape[0])
    editor.init_cells(cells.shape[0])
    for k, point in enumerate(points):
        editor.add_vertex(k, point)
    for k, cell in enumerate(cells):
        editor.add_cell(k, cell)
    editor.close()
    return mesh
points, cells = meshzoo.triangle(
    n=8, corners=numpy.array([[0.0, 0.0], [1.0, 0.0], [0.0, 1.0]])
mesh = create_dolfin_mesh(points, cells)
bbt = BoundingBoxTree()
bbt.build(mesh)
dofmap = V.dofmap()
el = V.element()
rows = []
cols = []
data = []
xy = [0.38764254, 0.29652301]
cell_id = bbt.compute_first_entity_collision(Point(*xy))
cell = Cell(mesh, cell_id)
coordinate_dofs = cell.get_vertex_coordinates()
print(el.signature())
print(xy, coordinate_dofs, cell_id)
v = el.evaluate_basis_all(xy, coordinate_dofs, cell_id)
print(v)
Everything works fine:
FiniteElement('Lagrange', triangle, 1)
[0.38764254 0.29652301] [0.375, 0.25, 0.5, 0.25, 0.375, 0.375] 31
[0.5266756  0.10114032 0.37218408]
Unfortunately, when I execute the same code embedded in a larger code base, I get
[-0.72790868  0.10114035  1.62676833]
Everything is the same, except that the basis functions are evaluated wrong. They still add up to 1.0 though.
I have no idea what else I could do to debug. Any hints?
That’s odd; the only way I can think of to get negative basis function evaluations with linear triangles is to evaluate the shape functions at a parametric point outside of the reference element, but the xy position and coordinate_dofs are the same in both cases. Do you get the same behavior with the following settings?
fem.parameters["form_compiler"]["representation"] = "quadrature"
and/or
fem.parameters["form_compiler"]["representation"] = "tsfc"
Note that the second one requires installing TSFC for FEniCS, which can be done with
pip3 install git+https://github.com/blechta/tsfc.git@2018.1.0
pip3 install git+https://github.com/blechta/COFFEE.git@2018.1.0
pip3 install git+https://github.com/blechta/FInAT.git@2018.1.0
pip3 install singledispatch networkx pulp
Thanks @kamensky for the reply! It appears to be a memory issue after all: I found out that the error can be avoided by passing xy.copy(). Wow, yeah.
I’ve opened a bug at https://bitbucket.org/fenics-project/dolfin/issues/1090/evaluate_basis_all-gives-incorrect-result, perhaps that will turn up something.
