Encountered PETSc error while running with MPI
Hi, I encountered the following error while running a multi-level monte carlo sampling. I am using dolfin solver c++. Each mpi process will run a single process PETScKrylovSolver using mumps and sample with different coefficient repetitively.
However, in occasions, I encounter the following error. And I could not reproduce it as if I run the solver for that particular failed coefficient alone with one process, I got a good solution.
I’m clueless now, not even sure where to look into for more info about what’s going on. I tried to output the ksp solver information, but thing seems all right before the error. Any recommendations on how to debug is appreciated.
Process 0: *** Warning: Verbose output for PETScKrylovSolver not implemented, calling PETSc KSPView directly.
KSP Object: 1 MPI processes
  type: preonly
  maximum iterations=10000, initial guess is zero
  tolerances:  relative=1e-05, absolute=1e-50, divergence=10000.
  left preconditioning
  using NONE norm type for convergence test
PC Object: 1 MPI processes
  type: cholesky
    out-of-place factorization
    tolerance for zero pivot 2.22045e-14
    matrix ordering: natural
    factor fill ratio given 0., needed 0.
      Factored matrix follows:
        Mat Object: 1 MPI processes
          type: mumps
          rows=240, cols=240
          package used to perform factorization: mumps
          total: nonzeros=3765, allocated nonzeros=3765
          total number of mallocs used during MatSetValues calls =0
            MUMPS run parameters:
              SYM (matrix type):                   2
              PAR (host participation):            1
              ICNTL(1) (output for error):         6
              ICNTL(2) (output of diagnostic msg): 0
              ICNTL(3) (output for global info):   0
              ICNTL(4) (level of printing):        0
              ICNTL(5) (input mat struct):         0
              ICNTL(6) (matrix prescaling):        7
              ICNTL(7) (sequential matrix ordering):2
              ICNTL(8) (scaling strategy):        77
              ICNTL(10) (max num of refinements):  0
              ICNTL(11) (error analysis):          0
              ICNTL(12) (efficiency control):                         0
              ICNTL(13) (efficiency control):                         1
              ICNTL(14) (percentage of estimated workspace increase): 20
              ICNTL(18) (input mat struct):                           0
              ICNTL(19) (Schur complement info):                      0
              ICNTL(20) (rhs sparse pattern):                         0
              ICNTL(21) (solution struct):                            0
              ICNTL(22) (in-core/out-of-core facility):               0
              ICNTL(23) (max size of memory can be allocated locally):0
              ICNTL(24) (detection of null pivot rows):               1
              ICNTL(25) (computation of a null space basis):          0
              ICNTL(26) (Schur options for rhs or solution):          0
              ICNTL(27) (experimental parameter):                     -32
              ICNTL(28) (use parallel or sequential ordering):        1
              ICNTL(29) (parallel ordering):                          0
              ICNTL(30) (user-specified set of entries in inv(A)):    0
              ICNTL(31) (factors is discarded in the solve phase):    0
              ICNTL(33) (compute determinant):                        0
              ICNTL(35) (activate BLR based factorization):           0
              CNTL(1) (relative pivoting threshold):      0.01
              CNTL(2) (stopping criterion of refinement): 1.49012e-08
              CNTL(3) (absolute pivoting threshold):      1e-08
              CNTL(4) (value of static pivoting):         -1.
              CNTL(5) (fixation for null pivots):         0.
              CNTL(7) (dropping parameter for BLR):       0.
              RINFO(1) (local estimated flops for the elimination after analysis):
                [0] 72793.
terminate called after throwing an instance of 'std::runtime_error'
  what():
*** Error:   Unable to solve linear system using PETSc Krylov solver.
*** Reason:  Solution failed to converge in 0 iterations (PETSc reason DIVERGED_PC_FAILED, residual norm ||r|| = 0.000000e+00).
*** Where:   This error was encountered inside PETScKrylovSolver.cpp.
*** Process: 1
*** DOLFIN version: 2019.1.0
*** Git changeset:  74d7efe1e84d65e9433fd96c50f1d278fa3e3f3f
I think this could be related to any of the suggestions in this post:
