Error: Unable to solve linear system using PETSc Krylov solver
Hello everyone,
I am trying to run a script on a computer at my university after correctly activating the fenics module. The output I get is as follows:
nohup: ignoring input
Solving linear variational problem.
Evolution of the tumor up to the third cycle of chemo
Computing nutrient initial condition.
Solving CH + nutrient
  File "GBM_Besta_33_mox.py", line 409, in <module>
    solver.solve(problem, solution1.vector())
RuntimeError:
*** Error:   Unable to solve linear system using PETSc Krylov solver.
*** Reason:  Solution failed to converge in 0 iterations (PETSc reason DIVERGED_PC_FAILED, residual norm ||r|| = 0.000000e+00).
*** Where:   This error was encountered inside PETScKrylovSolver.cpp.
*** Process: 0
*** DOLFIN version: 2019.1.0
*** Git changeset:
While compiling that script on my computer I get a correct execution with an iterative process that I expect.
What could be the problem?
This is almost impossible to diagnose without a MWE or complete information about your builds on your computer and your institution’s facility. A quick check would be whether the underlying versions of FEniCS’s components and PETSc are exactly the same on both machines.
