Hey,
this is probably super easy, but I can’t seem to find a suitable solution. I implemented my own Newton sovler. My boundary conditions of my system change with time. In every iteration in my newton solver I want to reuse the solution from my previous iteration, however since in my Newton solver the boundary conditions are only applied as homogenous ones, their values are not updated with time. Therefore I want to set the values at the boundaries manually (update u_k). How is this easiest done and still applicable for generic meshes?
This is a MWE hopefully showing my problem:
def CustomNewton(F, u,bc, V):
J = derivative(F,u)
U_inc = Function(V)
#homogenize boundary conditions
bc.homogenize()
# initialize the variables for the loop
nIter = 0
eps = 1e14
# Initialize the solver for the linear system
solver = KrylovSolver('gmres', 'ilu')
while eps > 1e-15 and nIter < 20:
# Newton iterations
nIter += 1
A = assemble(J, keep_diagonal=True)
b = assemble(-F)
bc.apply(A,b)
A.ident_zeros() # since we use mixedElements which are not all defined on the whole domain
eps = norm(U_inc)
solver.solve(A, U_inc.vector(), b) # Determine step direction and size
u.assign(u+0.5*U_inc)
print ('numIter = ',nIter,', eps = ' ,eps)
mesh = UnitSquareMesh(64,64)
V = FunctionSpace(mesh, 'Lagrange', 1)
u_k = Function(V)
u_k_1 = Function(V)
dt = 0.1
F = (u_k-u_k_1)/dt*v*dx - dot(u_k*grad(u_k), grad(v))*dx - 4*u_k*v*dx
bc_val = Expression('t+pow(x[0],2)+pow(x[1],2)', t=0, degree=2)
bc = DirichletBC(V,bc_val , 'on_boundary')
u_k.interpolate(Expression('pow(x[0],2)+pow(x[1],2)', degree=0)) # load initial solution
u_k_1.interpolate(Expression('pow(x[0],2)+pow(x[1],2)', degree=0))
for k in range(0,10):
t = k*dt
CustomNewton(F, u_k,bc, V)
# test value at (1,1)
print('Value at (1,1) ' + str(u_k(Point(1.,1.))) + ' (it should be ' + str(2+t) + ')')
#refresh Boundary
bc_val.t = t
u_k_1.assign(u_k)
# Here: update the boundary values of u_k in order to simulate the dynamic system
Thank you for your time
Best Regards
Emanuel
