Equivalent to Expression for a vector valued function in dolfinx?
I would like to define the exact solution for a time dependent stokes problem. I used to use Expression in fenics to do this. How can I define a vector valued function in fenicsx?
I have written the following code but it does not work
class exact_solution1():
def init(self):
self.t = 0.0
def eval(self, x):
print(x.shape[1])
t = self.t
return np.full(x.shape[1], (pow(t,2)(pow(x[0],4)-2pow(x[0],3)+ pow(x[0],2))(4pow(x[1],3)-6pow(x[1],2)+ 2x[1]), -pow(t,2)(pow(x[1],4)-2pow(x[1],3)+ pow(x[1],2))(4pow(x[0],3)-6pow(x[0],2)+ 2x[0])))
I would be grateful if someone can help me with this!
Thank you in advance!
Fotini
See e.g: This vector function definition which is interpolated into an appropriate space for error computation.
Thank you so much! Very helpful!
