Hello fenics community,
I am currently porting my code from fenics2019 to fenicsx and I’m having some issues. I can probably explain myself better if I explain what my fenics2019 code did: I solve a scalar equation and then use that solution as initial condition for one of the components of a vector function (using a mixed element space)
import dolfin as fem
# solve the scalar equation (I understand how to do this in fenicsx)
Vs = fem.FunctionSpace(mesh, 'CG', 1)
u, v = fem.TrialFunction(Vs), fem.TestFunction(Vs)
a = (fem.dot(fem.grad(u), fem.grad(v)) + u*v)*fem.dx + u*v*fem.ds
eq_mag = fem.Function(Vs)
fem.solve(a == v*fem.dx, eq_mag)
# the idea is to solve a vector equation using the obtained scalar
# solution as initial condition for the first component of the
# vector solution and zero for the second component
P = fem.FiniteElement('P', mesh.ufl_cell(), 1)
V = fem.FunctionSpace(mesh, fem.MixedElement((P, P)))
u, v = fem.TestFunctions(V)
m = fem.Function(V)
# from here on I don't know how to translate this to fenicsx
vertex2dof = fem.vertex_to_dof_map(V)
m_local = m.vector().get_local()
meq_local = eq_mag.vector().get_local()
for i in range(mesh.coordinates().shape[0]):
m_local[vertex2dof[2*i+0]] = meq_local[vertex2dof[2*i]//2]
m_local[vertex2dof[2*i+1]] = 0.
m.vector().set_local(m_local)
m.vector().apply('insert')
# at this point I can split m into its components and solve my equations
mx, my = fem.split(m)
So my question is how to do this. Also, I can’t find the equivalent of vertex_to_dof_map which I would like to know even if it isn’t needed for this particular case.
Thank you,
Miguel
