I’m trying to learn python and get used to FenicsX, But I’m encountering a lot of issues, I’m trying to simulate 3d Wave Equation in a Steel Plate
from dolfinx import fem, mesh
import dolfinx.fem.petsc
import basix
# --- 1. Material Properties ---
density = 7850 # kg/m^3
E = 210e9 # Young's modulus in Pascals
# --- 2. Mesh Generation ---
length = 1.0 # Length of the plate in meters
width = 0.5 # Width of the plate in meters
height = 0.01 # Thickness of the plate in meters
# Creating the mesh
mesh = dolfinx.mesh.create_unit_cube(MPI.COMM_WORLD, 20, 10, 2, cell_type=dolfinx.mesh.CellType.hexahedron)
mesh.geometry.x[:, 0] *= length # Scale in x-direction
mesh.geometry.x[:, 1] *= width # Scale in y-direction
mesh.geometry.x[:, 2] *= height # Scale in z-direction
# --- 3. Function Space ---
element = basix.ufl.element("Lagrange", basix.CellType.hexahedron, 1, shape=(3,))
V = dolfinx.fem.functionspace(mesh, element)
# --- 4. Boundary Conditions ---
def boundary(x):
return np.isclose(x[0], 0.0) | np.isclose(x[0], length)
u_bc = fem.Function(V)
u_bc.x.array[:] = 0.0
bc = fem.dirichletbc(u_bc, fem.locate_dofs_geometrical(V, boundary))
# --- 5. Time Parameters ---
T = 0.5 # Total time in seconds
num_steps = 100 # Number of time steps
dt = T / num_steps # Time step size
# --- 6. Wave Speed ---
c = np.sqrt(E / density)
c_squared = fem.Constant(mesh, PETSc.ScalarType(c**2).real)
dt_sq = fem.Constant(mesh, PETSc.ScalarType(dt**2).real)
# --- 7. Trial and Test Functions ---
u = ufl.TrialFunction(V)
# --- 8. Initial Conditions ---
u_n = fem.Function(V)
u_n1 = fem.Function(V)
def initial_condition(x):
values = np.zeros((x.shape[0], 3), dtype=PETSc.ScalarType)
values[:, 0] = np.sin(np.pi * x[:, 0]) * np.sin(2 * np.pi * x[:, 1])
return values
u_n1.interpolate(initial_condition)
# --- 9. External Force ---
f = fem.Constant(mesh, np.array([0.0, 0.0, 0.0]))
# --- 10. Variational Formulation ---
dx = ufl.Measure("dx", domain=mesh)
# Define the variational forms
a = ufl.inner(u, v) * dx + dt_sq * c_squared * ufl.inner(ufl.grad(u), ufl.grad(v)) * dx
L = dt_sq * ufl.inner(f, v) * dx + ufl.inner(2 * u_n - u_n1, v) * dx
# --- 11. Time-Stepping Loop ---
u = fem.Function(V)
for n in range(num_steps):
petsc_options = {"ksp_type": "cg", "pc_type": "ilu"}
problem = dolfinx.fem.petsc.LinearProblem(a, L, u=u, bcs=[bc], petsc_options=petsc_options)
problem.solve()
if n % 10 == 0:
with dolfinx.io.XDMFFile(MPI.COMM_WORLD, f"displacement_3d_{n}.xdmf", "w") as file:
file.write_mesh(mesh)
file.write_function(u, n*dt)
# Update solution
u_n1.x.array[:] = u_n.x.array
u_n.x.array[:] = u.x.array
# --- 12. Plotting ---
# Get coordinates of the mesh nodes
x = mesh.geometry.x
# Reshape the displacement array (extract the x-component)
u_array = u.x.array.reshape(-1, 3)[:, 0]
# Get the number of nodes in x and y directions
num_nodes_x = 20
num_nodes_y = 10
u_array = u_array.reshape(num_nodes_y, num_nodes_x)
num_nodes_x = mesh.topology.index_map(0).size_local
num_nodes_y = mesh.topology.index_map(1).size_local
# Create the plot
fig = plt.figure()
ax = fig.add_subplot(111, projection='3d')
X, Y = np.meshgrid(np.linspace(0, length, num_nodes_x), np.linspace(0, width, num_nodes_y))
ax.plot_surface(X, Y, u_array, cmap='viridis')
ax.set_xlabel('X coordinate (m)')
ax.set_ylabel('Y coordinate (m)')
ax.set_zlabel('Displacement (m)')
ax.set_title('Displacement of the Steel Plate at Final Time')
And I get this error
TypeError Traceback (most recent call last)
Cell In[5], line 79
77 for n in range(num_steps):
78 petsc_options = {“ksp_type”: “cg”, “pc_type”: “ilu”}
—> 79 problem = dolfinx.fem.petsc.LinearProblem(a, L, u=u, bcs=[bc], petsc_options=petsc_options)
80 problem.solve()
82 if n % 10 == 0:
File /usr/local/dolfinx-complex/lib/python3.12/dist-packages/dolfinx/fem/petsc.py:782, in LinearProblem.init(self, a, L, bcs, u, petsc_options, form_compiler_options, jit_options)
744 def init(
745 self,
746 a: ufl.Form,
752 jit_options: typing.Optional[dict] = None,
753 ):
754 “”“Initialize solver for a linear variational problem.
755
756 Args:
780 “mumps”})
781 “””
→ 782 self._a = _create_form(
783 a,
784 dtype=PETSc.ScalarType,
785 form_compiler_options=form_compiler_options,
786 jit_options=jit_options,
787 )
788 self._A = create_matrix(self._a)
789 self._L = _create_form(
790 L,
791 dtype=PETSc.ScalarType,
792 form_compiler_options=form_compiler_options,
793 jit_options=jit_options,
794 )
File /usr/local/dolfinx-complex/lib/python3.12/dist-packages/dolfinx/fem/forms.py:337, in form(form, dtype, form_compiler_options, jit_options, entity_maps)
334 else:
335 return form
→ 337 return _create_form(form)
File /usr/local/dolfinx-complex/lib/python3.12/dist-packages/dolfinx/fem/forms.py:331, in form.._create_form(form)
329 return None
330 else:
→ 331 return _form(form)
332 elif isinstance(form, collections.abc.Iterable):
333 return list(map(lambda sub_form: _create_form(sub_form), form))
File /usr/local/dolfinx-complex/lib/python3.12/dist-packages/dolfinx/fem/forms.py:306, in form.._form(form)
303 else:
304 _entity_maps = {msh._cpp_object: emap for (msh, emap) in entity_maps.items()}
→ 306 f = ftype(
307 module.ffi.cast(“uintptr_t”, module.ffi.addressof(ufcx_form)),
308 V,
309 coeffs,
310 constants,
311 subdomains,
312 _entity_maps,
313 mesh,
314 )
315 return Form(f, ufcx_form, code, module)
TypeError: init(): incompatible function arguments. The following argument types are supported:
1. init(self, spaces: collections.abc.Sequence[dolfinx.cpp.fem.FunctionSpace_float64], integrals: collections.abc.Mapping[dolfinx.cpp.fem.IntegralType, collections.abc.Sequence[tuple[int, int, ndarray[dtype=int32, shape=(), order=‘C’, writable=False], ndarray[dtype=int8, shape=(), order=‘C’, writable=False]]]], coefficients: collections.abc.Sequence[dolfinx.cpp.fem.Function_complex128], constants: collections.abc.Sequence[dolfinx.cpp.fem.Constant_complex128], need_permutation_data: bool, entity_maps: collections.abc.Mapping[dolfinx.cpp.mesh.Mesh_float64, ndarray[dtype=int32, shape=(), order=‘C’, writable=False]], mesh: dolfinx.cpp.mesh.Mesh_float64 | None) → None
2. init(self, form: int, spaces: collections.abc.Sequence[dolfinx.cpp.fem.FunctionSpace_float64], coefficients: collections.abc.Sequence[dolfinx.cpp.fem.Function_complex128], constants: collections.abc.Sequence[dolfinx.cpp.fem.Constant_complex128], subdomains: collections.abc.Mapping[dolfinx.cpp.fem.IntegralType, collections.abc.Sequence[tuple[int, ndarray[dtype=int32, shape=(), order=‘C’, writable=False]]]], entity_maps: collections.abc.Mapping[dolfinx.cpp.mesh.Mesh_float64, ndarray[dtype=int32, shape=(*), order=‘C’, writable=False]], mesh: dolfinx.cpp.mesh.Mesh_float64 | None) → None
Invoked with types: dolfinx.cpp.fem.Form_complex128, _CDataBase, list, list, list, dict, dict, dolfinx.cpp.mesh.Mesh_float64
