I am working on error convergence analysis for an diffusion example in 2D : Cube is the domain and initial condition is a point source at the centre. Below is the formulation and analytical solution. I am approximating point source as Gaussian function.
But the L2 error is increasing as I decrease the mesh size, can’t seem to find why this is happening. Tried changing the time w.r.t mesh size, but it didn’t work.
Here is the code:
import matplotlib as mpl
import pyvista
from dolfinx import fem, mesh, io, plot
from dolfinx.fem.petsc import assemble_vector, assemble_matrix, create_vector, apply_lifting, set_bc
from dolfinx.fem import (Expression, Function, functionspace,
assemble_scalar, dirichletbc, form, locate_dofs_topological)
class exact_solution():
def __init__(self, t, cnt, dim, S0 =100):
self.S0 = S0
self.t = t
self.cnt = cnt
self.dim = dim
def __call__(self, x):
sol_approx = 0
for i in range(self.cnt):
for j in range(self.cnt):
norm_factor = (2 if i > 0 else 1) * (2 if j > 0 else 1) ## Normalization factor for the Fourier series terms
lambda2 = ((np.pi**2) * (i**2 + j**2))/16 ## Eigenvalue for the Fourier series terms
sol_approx += (self.S0/16) * norm_factor * np.cos(i*np.pi*x[0]/4) * np.cos(j*np.pi*x[1]/4) * np.exp(-lambda2 * self.t) ## Fourier series term
return sol_approx
class heat_eq_2D():
def __init__(self, domain, strt_t, end_t, num_steps,cnt,uexact,u_D,sigma):
self.domain = domain
self.V = fem.functionspace(domain, ("Lagrange", 1))
self.dt = end_t / num_steps
self.t = strt_t
self.cnt = cnt
self.uexact = uexact
self.u_D = u_D
self.num_steps = num_steps
self.sigma = sigma
def initial_condition(self, x,scale=1,S0=100):
return scale*S0*np.exp(-0.5*(x[0]**2 + x[1]**2)/(self.sigma**2) )/(2*np.pi*self.sigma**2)
def scale_est(self):
u_n0 = fem.Function(self.V)
u_n0.interpolate(lambda x: self.initial_condition(x,S0 = 1))
dx = ufl.dx(domain=self.domain)
inital_condt_form = u_n0*dx
integral = self.domain.comm.allreduce(fem.assemble_scalar(fem.form(inital_condt_form)), op=MPI.SUM)
self.scale = 1/integral
# print("Scale factor: ", self.scale)
def error_L2(self, uh, u_ex, degree_raise=3):
# Create higher order function space
degree = uh.function_space.ufl_element().degree
family = uh.function_space.ufl_element().family_name
mesh = uh.function_space.mesh
W = functionspace(mesh, (family, degree + degree_raise))
# Interpolate approximate solution
u_W = Function(W)
u_W.interpolate(uh)
# Interpolate exact solution, special handling if exact solution
# is a ufl expression or a python lambda function
u_ex_W = Function(W)
u_ex_W.interpolate(u_ex)
# Compute the error in the higher order function space
e_W = Function(W)
e_W.x.array[:] = u_W.x.array - u_ex_W.x.array
# Integrate the error
error = form(ufl.inner(e_W, e_W) * ufl.dx)
error_local = assemble_scalar(error)
error_global = mesh.comm.allreduce(error_local, op=MPI.SUM)
return np.sqrt(error_global)
def solve_pde(self):
self.scale_est()
u_n = fem.Function(self.V)
u_n.name = "u_n"
u_n.interpolate(lambda x: self.initial_condition(x, scale = self.scale))
inital_condt_form = u_n*dx
# print(f"Integral of initial condition: {integral}")
# Define solution variable, and interpolate initial solution for visualization in Paraview
uh = fem.Function(self.V)
uh.name = "uh"
uh.interpolate(lambda x: self.initial_condition(x, scale=self.scale))
u, v = ufl.TrialFunction(self.V), ufl.TestFunction(self.V)
a = u * v * ufl.dx + self.dt * ufl.dot(ufl.grad(u), ufl.grad(v)) * ufl.dx
L = u_n * v * ufl.dx
bilinear_form = fem.form(a)
linear_form = fem.form(L)
A = assemble_matrix(bilinear_form)
b = create_vector(linear_form)
solver = PETSc.KSP().create(self.domain.comm)
solver.setOperators(A)
time_ls = []
error_L2_ls = []
# error_max_ls = []
for i in range(self.num_steps):
self.t += self.dt
self.uexact.t += self.dt
self.u_D.interpolate(self.uexact)
with b.localForm() as loc_b:
loc_b.set(0)
assemble_vector(b, linear_form)
# Solve linear problem
solver.solve(b, uh.x.petsc_vec)
uh.x.scatter_forward()
# Compute L2 error and error at nodes
# V_ex = fem.functionspace(self.domain, ("Lagrange", 1))
# u_ex = fem.Function(V_ex)
# u_ex.interpolate(self.uexact)
# error_L2 = np.sqrt(domain.comm.allreduce(fem.assemble_scalar(fem.form((uh - u_ex)**2 * ufl.dx)),
# op=MPI.SUM))
error_L2_ls.append(self.error_L2(uh,self.uexact))
time_ls.append(self.t)
# # Compute values at mesh vertices
# error_max = self.domain.comm.allreduce(np.max(np.abs(uh.x.array - self.u_D.x.array)), op=MPI.MAX)
# error_max_ls.append(error_max)
u_n.x.array[:] = uh.x.array
# self.end_num_sol = uh.x.array
# self.end_ana_sol = u_ex.x.array
# return error_L2_ls, error_max_ls
return error_L2_ls,time_ls
# Define temporal parameters
t = 0 # Start time
T = 2*60 # Final time
L2_error_dict_master = {}
for dt in [1,0.5,0.1,0.01,0.001]:
L2_error_dict = {}
for h in [1,0.8,0.5,0.25]:
print(f"Solving for mesh size = {h}")
num_steps = int(T/dt)
# Define mesh
nx, ny = int(4/h), int(4/h) # Number of elements in x and y directions
domain = mesh.create_rectangle(MPI.COMM_WORLD, [np.array([-2, -2]), np.array([2, 2])],
[nx, ny], mesh.CellType.triangle)
u_exact = exact_solution(0,cnt = 5)
u_D = fem.Function(V)
u_D.interpolate(u_exact)
pde_sol_obj = heat_eq_2D(domain, strt_t=0, end_t=T, num_steps=num_steps,
cnt=5, uexact=u_exact, u_D=u_D, sigma=h)
L2_error_dict[h] = pde_sol_obj.solve_pde()
L2_error_dict_master[dt] = L2_error_dict
